Floyd Sweet's VTA
  • 652 Views
  • Last Post 21 April 2018
cd_sharp posted this 24 March 2017
I've been researching the VTA for some time. I would like to share my experience about it and read other people's ideas. I will jump straight into the problem. Anybody that is not familiar with the VTA, please read the main website. It's the best online resource about it.
The first important thing that I noticed is the similitude between these pictures:
The first one shows the light emitted by two lamps fed by the VTA, but first rectified through a full wave bridge rectifier. Notice the center vertical beams which Bearden says they do not know what they are.
The next image is a screenshot from this video:
Notice that the load is a LED which is a diode. So, the current feeding the light we see is DC. This led me to believe that the type of induction happening inside the VTA is a linear movement of a Bloch Wall.
I also noticed there is a Bloch Wall forming between the two magnets in attractive configuration.
So, that is the Bloch Wall we most likely need to move.
  • admin
  • tribulationcoming
admin posted this 24 March 2017
Hi Cd_Sharp and welcome!
Yes, I agree with you! The Bloch Wall is the Equator, the absolute central meridian of the Magnetic Field Structure.
Faradays Law states, the Time Rate of change of the Magnetic Field/the Conductor in the presence of the Magnetic Field.
Any time, and every time the Magnetic Field Changes, and it does as Lenz's Law is invoked as we draw Current from our Load Coil, the Magnetic Field is changing and as this change happens, the Bloch Wall moves with this Change!
So you're exactly right! Here are some video's I did some time back:
  • tribulationcoming
 Thanks, Chris! I think your website and videos are amazing. I have been following your work also on OU.com for years, but I focused on quiet experiments. I think you understand why after all you have been through.
The next question in my mind was this: what is the minimal configuration for the VTA? I think this is the one:
Since we do not see any excitation coil, but we see a little protuberance (marked in red), I concluded this must be just half of this version:
So, in the minimal (version 4) configuration, there is a vertical output coil probably in 2 halves. Thanks Chris for POC configuration, this must be the output coils configuration in the VTA.
In the minimal configuration, there should also be an excitation coil in the end we do not see.
The next thing I noticed is that in the VTA we see edges on all the coils. A coil having lots of levels of turns stacked or very thick wire tends to look like this:
and hides the edges of the bobbin such that even if the section of the bobbin axis if rectangular, it looks circular on the outside.
So, the axis of the bobbins of the VTA are rectangular. Also, the axis look wide. I think there is no point in having this wide axis without having a big core inside and the core should have edges meaning it should be rectangular or wide toroidal shape. This also points to what Chris shows here:
the VTA coils most likely had cores. So we have 2 ways to indicate a probable thing. Again, thanks Chris! Fantastic intuition.
  • admin
  • tribulationcoming
Hi Cd_Sharp - A Good question!
Personally I am not yet at the stage of Floyd Sweet, so I can only guess at the end result.
Floyd Sweet had a lot of problems early on, Frequency, stability, many others, all problems I have seen to some varying degrees. It is really hard to figure out some of these problems, I am still learning a lot. Floyd Sweet was a genius, but for sure he saw the same problems.
The absolute minimum configuration to start, is the MrPreva Experiment!
Learning from the most simple experiments is so much easier on the Pocket! and also quicker. If you have done this experiment and wish to move on, I recommend attempting the replication of Ruslan's early work: @11m 11s
and with more detail here:
Of course, when any two waves meet, they can create a Standing Wave, which can have very much more Energy in this Standing Wave, than in the two fundamentals:
https://www.youtube.com/edit?o=U&video_id=FuH6u39acY8
Its worth keeping in mind, the very Action of drawing Current Begets Additional Power "Generation"  - What do I mean, by drawing a Current, this movement of Charge (Current (I)) invokes Magnetic Fields!
Each Oppose, changing in time! Which is Electromagnetic Induction in itself!
See: http://www.hyiq.org/Page/Details?Name=Support
I detail some concepts there. The words Figurea used are beautiful:
CLEMENTE FIGUERA
I hope this helps, I am sorry if you already know all this stuff, please pass it by if you do.
I have tried to really make a massive effort in the Reference Section, to show the devices by those before us, all using the same concepts. A good percentage, as they themselves said, they did not know how it worked, but it does!
All the best
Wistiti posted this 25 March 2017
Hi guys!
Moving Bloch wall through an inductor remember the concept of Figuera generator. Nice Chris you have point it! Until now my experiment was about a single primary and a POC as the secondary. But I think using the POC as the primary , for displacing the Bloch wall through a collecting inductor might be also a great idea... As Figuera does!
ps: Nice to have a working team again!
  • admin
admin posted this 25 March 2017
Hey Wistiti - Absolutely! No limitations! When One Partnered Output Coil is used as an Input, as Akula and Ruslan have shown, when in resonance, there can be very good and useful effects! Just takes a bit of work! @ about 4 and 1/2 minutes in:
Yes, this is feeling really good! Nice to have you back my Friend!
Chris posted this 30 March 2017
Hi Cd_Sharp, I remembered, the Kromrey Converter is another instance where the beam of light can be seen from Light Bulbs:
Of course, you are already well ahead! You can see what the main cause of this EMF is!
I hope you find the video enjoyable!
cd_sharp posted this 20 April 2018
Alright, I'd like to do my part in this, so here is the essence of what I learnt so far. Please note that the output is around unity and it can never go overunity in this exact configuration. It turns out self induced current is behaving strangely when separated by the main current using a diode. If we're looking for the cold current Floyd talks about, it is the no 1 suspect.
Any idea how we can use this in conjunction with The Mr Preva experiment?
Chris posted this 21 April 2018
Thanks for sharing! Always exciting to see others progress!
We seem to be getting: Video Unavailable
Looks like the video is private? If you set to unlisted, this will allow the video to play.
cd_sharp posted this 21 April 2018
Sorry about that. It is my first upload. I think it's fixed now.
Great Job CD! That's excellent!
We are seeing all the Effects we should be, this is great!
  • Input reduction
  • Magnets adding energy to the system
Great work! If you like, you can create a new thread for the Effects youre getting? Let me know if you need help with that?
Thank You very much for sharing! Its great to see others progressing and sharing their work! Larger Core Size will help and more turns if you want to increase this further.
Great Job!
Thanks for the good words, Chris. I'd keep everything in here for now.
I believe I owe some explanations because I've been experimenting with this exact circuit for a few years.
Larger core or more turns won't do any more good. Once it gets to unity that's it. So this must be just one piece of the puzzle. Next step should be similar to whatever Floyd describes in here and I can only try to guess at this point:
Once unity has been achieved and the gate to the Dirac Sea opened, over-unity is affected
by loading the open gate more and more which opens it further to the point where direct
communication/interaction with the nucleus of the atom itself is achieved.
