ISLab maximising magnetic resonance in POC
  • 4.4K Views
  • Last Post 2 days ago
ISLab posted this 04 November 2022
In my previous thread on ISLab's Replication of Basic POC Effect, I had many useful learning outcomes and got a good "feel" for the behaviour of POC coils under various kinds of situations. With help and encouragement from all of you, I was able to get the Sawtooth Wave and "generate" more power than "induced" within the coils.
This thread will focus on optimising the POC coils and maximising their magnetic resonance for optimum power generation.
Chris posted this 03 February 2023
Hi ISLab,
I think Mat is on the right track.
Is this spurious effect only at the Mosfet? Or can you trace this back further? If so, how far back? What Component?
ISLab posted this 04 February 2023
Hi Plasmonic and Chris, thank you for the tip!
Checking the voltage across IL610 pins 8 and 5, there is a short but large bump:
The bump happens exactly for the duration of the rising edge of the pulse:
It could also be on the falling edge. I did not check both at the same time.
The above is just with the signal in and no output fed through the MOSFET. When I feed about 7V on the MOSFET into a coil, this bump goes wild:
Removing the pulse input to CN2 removes the bump completely.
No change in the bump by adding an extra 100nF on Pin 8.
Any suggestions?
Chris posted this 04 February 2023
Hey ISLab,
Hmm, bad IC?
Without having more info, it appears there is a Power Dip on the IC ( IL610 ) that may be causing this instability. Check the Cap, C4, for the same dip:
If we have a stable DC Supply at 15 volts, if we do, then its not power.
If we don't, and you see the same dip, its possible the RK-0515S is struggling to keep up with the Isolated Supply Power to the circuit.
I believe there are a few models, each rated at different wattage output. Get the highest rated.
Any components getting hot?
  • Plasmonic
I have the RK-0515S/H6 which has output rated for 66mA and 1W. This does get slightly warm after being in use for 10 minutes when the MOSFET is driven, but not warm at all when it is not driven.
I recall the power dip was on the entire 15V line, but will check this again carefully. Will also try replacing this and check.
  • Plasmonic
donovan posted this 04 February 2023
The one waveform is interesting, showing a overshoot, followed by an undershoot, on the supply line, as the output waveform is rising (taking power).  I wonder if we are reaching the transient response time of DC-DC converter. A fast, large load and the converter overshoots, trying to keep up.
On my experiments, one thing I did last week was clean up the wiring for the power circuit that drives my L1.  I used heavier, shorter wires, and added some bypass capacitors close to the MOSFET.  Right beside my MOSFET/L1 I used a 15000 uf, 1uf, and .1uf in parallel.  The use of bypass capacitors in modern electronics seems to have fallen by the wayside.  In high power, fast circuits bypass really help.  And using 2/3 in parallel makes sure at least one of them is effective at the required frequency at any instant.  In my circuit, the extra bypass capacitors cleaned up the waveforms, and made it easier to see the magnetic resonance.
My two cents worth.
Some more checks on the 15V line placing the pulse (red)  next to the 15V line (yellow).
On the rising edge of the pulse:
On the falling edge of the pulse, again another dip, where 15V line is measured after L1 inductor:
The same measured before L1 inductor directly on the 15V output:
L1  does have a very slight effect to reduce the bump.
Note that the both ICs are inverting. So each may be drawing when it switches ON. Hence the difference between the rising and fallin edges. Perhaps?
The RK-0515S/H6 gets warm within a few seconds when there is load on the MOSFET (perhaps because the driver draws more current). Otherwise it is cool. The 7805 is always cool.
The RK-0515S/H6 is clearly overloaded. I will try with a different piece of RK-0515S/H6 next, and perhaps with several caps as suggested by Donovan.
Q1) @All, one difference in my circuit is that the MOSFET is IRF840. Could just this MOSFET be drawing too much current?
Q2) @Donovan, do you suggest I put caps of 1uF and 0.1uF on the 15V output in addition to the 470uF?
Hey ISLab,
A bigger cap at C4 may be helpful? I don't think the Ripple, is enough to create this issue, its not sufficient to Brown out the IC in my opinion.
Re-Check your Decoupling Caps at: C6 and C7, make sure they are Ceramic, 100nf caps.
Any issues with signal before the IL610?
EDIT:
Yes! But you said you disconnected the Mosfet, did you not?
donovan posted this 05 February 2023
Nice scope shots, showing both waveforms.
I would try a 1uf or a 10 uf, in parallel with C6, and see if it has any effect on the waveforms.  I would also try a 1uf or 10 uf in front of L1, after the RK0515.
These are the fun ones to troubleshoot!
Donovan
Chris posted this 05 February 2023
Hey ISLab,
What wattage is your inductor:
Getting bigger 1/2 watt, or a bit more, Inductor may be worth while:
Worth looking into!
This, I do not believe is causing the issue, but may help you in finding the issue!
ISLab posted this 05 February 2023
Hi Chris and Donovan, thank you for your inputs!
I disconnected the pulse power supply to the MOSFET but did not remove it from the circuit.
So now I removed then MOSFET, then IC2. But the frequency wobble did not go away.
Next I soldered the minimum of parts on Channel 3, just to activate IC1 and the power using all new components. Measured each component value to double check.
Same wobble in Channel 3.
Put 0.1, 1, 10, 100, 330uF in parallel with C6. No change.
Put 100nF in parallel with C2. No change.
My input pulse comes from 11V ouput of TL464 through 1K resistor to R1. Voltage drop on R1 is from 4.2V to 0.7V, meaning 7.5mA on IC1 input. I tried to reduce the 1K resistor to raise current on the input up to 11mA. I thought it made a very slight reduction in frequency wobble, but barely. But I did not want to risk higher current as recommended input current is 5mA.
Then finally I put a 20pF in parallel with C1, and the wobble stopped!
The existing C1 is suppod to be 15pF, but shows 20pF on LCR meter, as also the new one added in parallel, giving a total of 40pF.
I have yet to test on Channel 1 with larger C1. It it late now so will try tomorrow.
Just to show you the actual capacitor used, I have placed it beside 100nF. The 100nF is Polyester Film rated for 100V. The 15pF is ceramic, but I don't know its rating or how to find it.
My testing F = 1KHz. I don't know what exactly C1 does or how its value influences the pulse. Any inputs will be much valued on how this works and what to do next, and what value to finally use. Thank you all for your help!
@Plasmonic: .... JLCPCB but when I upload the files I get a digital equivalent of a blank stare in return
I figured out the problem and corrected it before I could make my PCBs. Will post the correction shortly in the original thread: https://www.aboveunity.com/thread/reliable-and-flexible-switching-system/
Hey ISLab,
You need to use Ceramics for Decoupling Caps:
Pleased you got it sorted!
ISLab posted this 06 February 2023
The story got even more strange.
Replacing Polyester Film on C2 with ceramic capacitor made no difference to the wobble or the voltage dip.
Looking for an optimum C1, I found that sometimes adding another 15pF in parallel worked fine but sometimes not. Then I found that the wobble stops when my hand touches the input signal and my foot is touching the floor and earthing the line.
The wobble stopped even if I touched the signal as it comes out of the TL464!
So I replaced the PSU on the TL464. No change. Connecting the scope probes to the TL464 was earthing the line and blocking the wobble. Removing the scope from the TL464 kept the wobble in the MOSFET output.
Touching the TL464 pins 1, 2, 4, 5 (all related to pulse timing) by hand makes the wobble dramatically worse. So I suspect the problem is some kind of parasitic capacitance in the TL464 output that was oscillating with the coil in the input of the IL610. Because so far I had no problem with the TL464 output. (Or perhaps the fact that I was monitoring its output on the scope was grounding the line and so suppressing the wobble.)
Finally I replaced the TL464 with a professional Signal Generator, and the wobble was gone!
But the voltage dip still remains. On the 5V line measured on Pin 9 of IC1, it is quite big -- nearly 3.6Vpp:
where Yellow is the 6V line and Red is the IC1 output on Pin 6.
Powering the MOSFET gives strong ripples on both:
but F on the MOSFET stays steady.
The Reliable and Flexible Switching System has stood its ground well, so I will leave the circuit as in the version 3 by Chris, and focus instead on building a "reliable and flexible pulsing system" to match it.
Looking back, I'm wondering how much this may have affected my experiments and results. It seems to me that if the F was wobbling a lot, I would definitely have noticed. I was alwayd monitoring the TL464 output to watch the F and D values and so the lines were grounded by the scope, preventing any wobble. But it does suggest that the stability of the TL464 circuit (or at least my board layout) had high parasitic and other influences which may have affected the precision of F and D values. I had noticed drift in F which I assumed was from temperature rising in components. But now I suspect it was from this.
My apologies to all for the trouble and false alarm. I hope my learning experiences will save similar troubles to many others.
Chris posted this 06 February 2023
Hi ISLab,
Fact: I don't have the issues you do!
Maybe the difference between cheap Chinese IC's and the originals!
ISLab posted this 09 February 2023
[Please note that my problems described with the Reliable and Flexible Switching System (RFSS) is in no way related to the RFSS design which is robust and well-tested by Chris. It is entirely specific to my implementation. I'm sharing my problems here in detail seeking help and guidance from all, and in the hope that others who face similar issues may be helped by whatever solutions are found.]
The voltage dip on the RFSS internal power is timed with the drop in the pulse when the coil throws a sharp Back-EMP which overlays a noise pulse. This ripples into my entire DC power line outside the RFSS and into the pulse timing circuit's power line. As the voltage on the MOSFET pulse rises, this dip grows with a large noise pulse until it swamps the entire circuits power line momentarily (5V for my pulsing timing) and resets it.
After much experimentation, I finally isolated the cause of the voltage dip and found a work-around: placing a 0.1uF across the MOSFET Source and Drain removes all the noise, and leaves the original power dip only, which does not pollute or swamp the circuits outside the RFSS.
This the measurement in the RFSS at the 5V line across the 5V Zener without pulse voltage on the MOSFET:
The dip is very short -- a little over 50nS. Seen only when you zoom in. It is related to the internal RFSS circuit but does not affect anything negatively, and does not go outside the RFSS. It can be safely ignored.
When placing 2.5V across the MOSFET, this overlays with a noise pulse:
When pulse voltage is increased to 5V the noise pulse grows proportionally:
But when a 0.1uF is placed across MOSFET Source and Drain, the noise vanishes:
The power dip is slightly larger than the original, but does not grow further, and the noise pulse is gone. All the connected circuits function normally all the way up to the 14V that I've tested.
I'm happy with the work-around. But I still do not know why this is happening. Perhaps it is specific to the MOSFET IRF840 which has a rather high Rds(on) of 800mΩ (compared to the Cree Wolfspeed which can go as low as 15m&Omega, and hence to be replaced soon. Or perhaps it comes from placing the MOSFET through a connector block like this:
Either way, this is specific to my current implementation, and the work-around will have to stay for now.
But I still want to understand why this is happening and why the 0.1uF solves it, and whether that would affect anything else in the coil pulsing and the POC effect. I request anyone here who understands this to please explain, as my knowledge in linear electronics is limited.
Further steps
I'm waiting for the new AMCC core and will wind a longer coil as soon as this arrives.
Meanwhile, I've been working on a high resolution programmable pulse timing circuit based on the Arduino and the AD9850 DDS signal generator. This is already giving very precise F (down to 0.3Hz) and can comfortably go up as high as 20MHz. I'm working on some options for the D control which is currently manual from a IC555 on-shot monostable -- not yet programmable.
This would allow automatic sweep at various speeds programmatically.
I intend to share the entire circuit and the code here once it is fully developed and stable.
ISLab posted this 16 February 2023
I've received my AMCC cores, and am already struggling with the metal flakes.
Could anyone please share some guidelines on safe use of AMCC material, and any way to wrap them safely to avoid injury and rusting?
I remember seeing a post with a document of handling AMCC in one of the threads, but cannot find it now.
Thank you for your help!
Plasmonic posted this 16 February 2023
Hey ISLab,
I sprayed mine with wd-40 wiped them down and wrapped each half with a continuous wrap of electrical tape on each leg.
Matt
ISLab posted this 20 February 2023
@Plasmonic: Thank you Matt! I will do the same.
Btw, I found the document. It was posted by Jagau here. It recommends Rustlick 631 which seems to be equivalent to WD-40.
New Switching Board
My new RFSS is ready, tested and working with C3M0015065D MOSFETs:
I've inserted switches at the power lines of all four channels so that I can use only the channels needed, and avoid needlessly heating in the unused ones.
The Cree C3M0015065D MOSFET has an Rds(On) of 15mΩ (compared to IRF840 which has a Rds(On) of 800mΩ ) and is soldered directly onto the board.
Power bump and solution
At first the change in MOSFET dramatically raised the current in the L1 coil, giving currents 0.4A for barely 3.5V input pulse at 6% duty cycle. The problem of voltage dip documented earlier also was present (suppressed by the 0.1uF on the MOSFET), but now the spike overload was reached at 3.5V instead of 7V or above earlier. And the Sawtooth Waveform was no more seen.
I noticed also that if the 0.1uF ceramic capacitor touches loosely or is moved (as when held by hand) there were sparks at the point of contact!
After many hours of debugging, I found that removing the oscilloscope probes from inside the RFSS isolated portion of the circuit solved everything! Now the sawtooth waveform on the coils output was restored, the power glitch which was knocking out the pulsing circuit vanished, and the high current draw on the pulse dropped to normal.
The problem was from some ground loop created by the oscilloscope ground / probe which was allowing the sharp pulse to induce large ripples in the isolated portion of the RFSS circuit.
Now I can raise the pulse voltage to 30V without any problems or side-effects! The MOSFETs stay cool even at high voltage and current up to 1A without needing heatsink.
One Remaining anomally
I noticed early on that if I connected the live input pulse circuit to the RFSS first and then switched on the RFSS, then it would not come on, and the RK-0515S has at output of 2.5V instead of 15V. I thought it might be a bad piece, but now I find this is the case with all of the channels.
My input pulse is about 3.5V height from a 5V Arduino circuit and IC555; the RFSS runs from a separate 7V PSU. Could this be causing this? Any advice is welcome.
For now I find it necessary to switch on the RFSS first, without any signal on the input. Then all works fine.
Next steps
My Arduino + AD9850 is working well with manual and auto-sweep modes with a selection accuracy of 0.3Hz and rock solid stability.
The duty cycle is currently manual using an IC555. This must be automated now and made to be software controllable to as small as possible.
ISLab posted this 28 February 2023
Hi Friends,
I've been fully immersed these last eight days building my high precision pulsing circuit. At this point I finally have it working to my satisfaction and with the convenient features needed for POC research.
The top leff is an Arduino Vidor 400 which contains an FPGA (Field Programmable Gate Array) and which is the master controller for the entire circuit. Top right is an AD9850 DDS Signal Generator with high precision frequency ranging from below 1Hz to above 20MHz, available as square as well as sine waves.
The FPGA is "programmed" into a custom circuit that fully manages real-time data from the three Rotary Encoders (with internal debounce) and their three pushbuttons (with internal debounce), and most importantly a high precision Monostable pulser that is fully programmable and controllable from the Arduino code. The entire FPGA operates internally at 150MHz, offering very high precision and timing totally independent of the Arduino software speed. This could be further improved by replacing with a still higher frequency FPGA.
The customr circuit looks like this in its heart:
The Arduino code programs the FPGA and the AD9850 to give precise frequency (down to 0.3 Hz precision) and precise pulse width (down to about 8.5nS precision). The three Rotary encoders and their buttons are used to select the frequency F and pulse duration D. Pushing their buttons allows for selecting the speed of change of F and D to easily scroll large steps or slow down to very small steps.
There are also special modes which sweep the F up or down automatically at various speeds and steps, all of which can be manually changed while the auto-sweep is ongoing. The LCD screen shows current values of F and D, and the current mode of operation.
The pulse duration is set by the number value placed in the mono-pulse counter in the FPGA which clocks at 150MHZ internally. This should give an effective precision of about 8nS duration for the counter value of 1. This is largely borne out by testing with an oscilloscope.
A counter value of 2 gives:
Counter value of 12 gives:
Counter value of 100 gives (zoomed out):
which measures as 830nS and appears as about 0.1% duty cycle for the selected F=1200Hz.
For counter value of 500, zooming in on the pulse shows 4.16uS duration:
Since the entire pulsing circuit is purely digital, there is very little of the distortion which is typical of analog components or even IC555 and such others. Furthermore, since the timing is bound by the FPGA master-clock, the precision is the same whether at nano-second ranges or at micro-second ranges of pulses.
I've reserved 3 output pins for future use for generating sync pulses at 1/4 wave, 1/2 wave and 3/4 wave points, needed for more advanced POC work that Chris has introduced on other threads on this site.
For now, this is perfect for my current work. I've decided to name this the Pulsar v1, and hope that it will be a worthy companion to the many existing high precision pulsing circuits posted on this website.
If there is sufficient interest in the Pulsar, I could create a more detailed video demo. And if enough people show interest in building it, I will be happy to share the circuit and code in a separate thread.
In combination with the RFSS/Quadratron, this takes care of all my timing and high voltage pulsing issues, and hopefully will free me to concentrate purely on the coils and cores from this point on.
ISLab posted this 02 March 2023
The next step for testing was to try out everything on the existing coil / core but with varying loads.
The input pulse settings were selected with some experimentation to find best F and D that give a good output for pulse of 31V.
Input settings:
(I updated the Arduino code to show exacf F, pulse duration and calculated duty cycle!)
Setting
F=3299Hz, Pulse=10.68uS, Duty cycle=3.52%. Pulse voltage was kept at 31.8V (which is the maximum for the PSU) for all the following readings. Input current was measured on an analog ammeter with a large capacitor after it to smooth out ripples.
Only the load was varied. All loads are 12V Halogen lamps of different power ratings and variations in series or parallel configurations.
I've sorted the readings in order of increasing input current, as there seems to be an obvious progression here. Scaling of scope levels has been kept the same for easy comparison.
Blue = input current, Pink = input voltage, Teal = output current, Yellow = output voltage
Readings
1) Load 5W single halogen. Input A=40mA.
2) Load 10W = 5W x 2 series halogen. Input A=40mA.
3) Load 10W = 5W x 2 parallel halogen. Input A=80mA.
4) Load 16W single halogen. Input A=110mA.
5) Load 32W = 16W x 2 series halogen. Input A=100mA.
6) Load 32W = 16W x 2 parallel halogen. Input A=220mA.
7) Load 50W single halogen. Input A=300mA.
8) Load 100W = 50W x 2 series halogen. Input A=230mA.
On this one I noticed a peculiar thing: when first the voltage reached peak the waveform was different, then in a few seconds as the lamps began to glow, thr input current dropped by 40mA and the input current waveform (Blue) changed. Both noted here:
Before the glow with current at about 270mA:
After the glow: (see the change in Blue)
9) Load 100W = 50W x 2 parallel halogen. Input A=500mA.
Here the input current (Blue) went so far out of the scope that I shifted the line up to get a full picture:
Observations
* The negative current (Blue) rises dramatically in 7, 8, and 9 -- so much in 9 that I had to shift the graticule line to view it fully!
* Output current (Teal) also has risen dramatically with the load, and clearly likes the lamps in parallel instead of series, as these allow for more current to flow.
* Based on the last reading of 9, I need only to drop the frequency to enjoy the full sawtooth wave generating so much more current!
This is so very interesting!
Next I plan to explore the readings in this direction.
Chris posted this 03 March 2023
Hello ISLab,
Remember what I said about the curvy bits.
  • Plasmonic
ISLab posted this 28 May 2023
I've been held up by work. So I took a long step back to review, re-read all the key posts by Chris and others. Based on all past experiences, everything now makes so much more sense. It is as if the mind has leart to see differently, and many past blocks have been cleared. So here I will summarise some of the steps and decisions I took.
  1. My last coil configurations were based on Wistiti's layout, and although I could show input current increase by removing the diodes,, I was not happy with it. It does not make sense that two diodes are needed. So I put a second diode in reverse to the first and the effect still remained. I replaced the single regular diode by a Schottky and the change in the input current was much less!
  2. Effectively, the diode was dropping th
I've been held up by work for a while. So I took a long step back to review and re-read all the key posts by Chris and others. Based on my past experiences, everything now makes so much more sense. It is as if the mind has learnt to see differently, and many past blocks have been cleared. So here I will summarise some of the steps, insights and decisions I made.
1. Wistiti's configuration
My last coil configurations were based on Wistiti's layout, and although I could show input current increase by removing the diodes,, I was not happy with it. It does not make sense that two diodes should be needed. So I put a third diode in reverse to one of them and the effect still remained even though the current could now flow in both directions -- in other words the diode was only serving to create a voltage drop. I replaced the single regular diode by a Schottky and the change in the input current was much less because now the voltage drop was much less!
Effectively, the diode was dropping the voltage on the load and hence reducing the input current. I also had other issues with coil directions which cause me to suspect that this is another Flyback Converter configuration. Also placing L1 across both L2 and L3 is against what Chris has been teaching (although in my configuration I had it only on L2). So I decided to drop this line of exploration.
2. Studying Jensen's UDT
Reading up the Jensen UDT explanation was an eye-opener. Seeing the diagram triggered an Aha!
And suddenly the whole POC layout and placement of coils became obvious. Some key insights:
a) the slapping together of the magnetic fields takes place both above and below in the core, and must be simultaneous. So the coils must be equidistant from the two ends (top and bottom) of the core.
b) L3 being CCW to L2 makes full sense when placed as above. Now effectively they both turn the same direction as seen from below (or above), but in one coil the current rises and in the other coil it descends. Why is this important? Because now rising and descending currents strengthen each other (see Chris' thread on this). But more:
c) If you think of the current turning around the core as dragging the aether, then both cores of L2 and L3 now turn the same direction, effectively creating a combined whirlpool around the two cores -- thus strengthening each other, and also opening out to the larger aether flow and making an open system which can draw in ambient energy.
d) The most important relationship of L3 inducing in L1 (which Chris has been highlighting) now becomes possible as they are correctly aligned. If L1, L2 and L3 are in the same common core in a row, the change in L3 will always oppose L1. But placed like this L3 will induce current in L1 supporting it. The verification of this is a bit complex and it made sense only after seeing this video:
e) One of the most important insights from this video in (d) is that when the magnetic field is decreasing, the induced current resists the collapse. This explains the dramatic extension of the collapsing fields by mutual induction between L2 and L3. This can only happen when both fields a collapsing. It cannot happen when any one of them is increasing.
But all of these points are valid only when L2 and L3 are set next to each other as above and with the coils set CW and CCW.
These insights represent for me a huge breakthrough in understanding of all that Chris has been sharing across so many threads, and have put everything together in one comprehensive whole. It really is as simple as Chris has been insisting!
Pulsing with AMCC cores
Having got my new AMCC cores I wound some braided speaker wire of about 4m on each coil and tested for resonance using Chris' method here. Yes, I wrapped the cores with insulation tape to protect from the little metal fragments that are so dangerous!
The resonance was found at about 1.07MHz and nothing lower (since the coils are too short). Depending on the direction of injection of signal in coil L2, the output Vmax was either 3.7V or a dramatic 5V for an input signal of 10V.
Initally I made the mistake of leaving L1 connected to my circuit board which drastically changes the resonant F as well as the Vmax -- painful but useful learning!
The quarter wave pulse (PW) needed is 232nS to equal the resonant F.
I then pulsed the coils with the new coil configuration, keeping pulse duration fixed at 232nS and raising frequency to above 1Mhz until suddenly the Sawtooth Wave (SW) appeared and the 5W Halogen lamp lit dimly! It was a surprise that this worked at such a high freqency; most likely the benefit of the AMCC core (?). There was also a strong feedback current pushing back in L1 during the generation phase.
What is fascinating is how the SW appears suddenly, and how it disappears suddenly if PW is dropped even to 225nS or F is dropped by even 10KHz. But it remains stable even if PW is raised much more or even if F is raised much more.
I'm posting just one scope shot here which is indicative, as this is a very low value result, but impressive nevertheless.
(Yellow = output voltage, Teal = output current, = input voltage, Blue = input current.)
Next Step
The next step is to wind a much longer wire on the coils to get my resonant F to become much lower.
I hope my learning steps are useful to others, at least to avoid all my newbie mistakes. 😇
Chris posted this 29 May 2023
Hey ISLab,
Very impressive! You have a very good understanding, and yes, one will see POC in many places once it is properly understood.
Like the Magnetic Induction Compass, the use of Non-Inductive method, gives us a gain if we use the right means to overcome the Negative effects of Symmetrical Electromagnetic Induction! If our Input see's no load, under loaded conditions, we are no longer using Symmetrical Electromagnetic Induction, we are now taking advantage of Asymmetrical Electromagnetic Induction!
This is what we have achieved!
Chris posted this 21 September 2023
Hey ISLab,
I wanted to reply to your post Here, on your thread:
Don’t worry” he said, “It’s a great result.” “Why?” I asked , to which he replied,  “Because there is more than twice the power out than in.”
Hi Aetherholic, thank you for sharing your story! It is indeed inspiring and motivating for the many here who are working in this direction!
I let him take pictures of the equipment, look at the results
Would you please share some pictures with us also?
I hope that we see more people following the very simple instructions here and not letting their "education" get in the way. ... The basic concepts are here as you have presented countless times and once understood and used correctly there will be success. ... Frankly speaking, I now find that everything I build is COP>1. Why is that? Because now I know how to design for overunity. How do I know that? Because I did the work, followed the concepts here, analyzed many historical devices and determined the common factors needed which are all contained within these forum pages
I truly hope that many more here and eventually all over the world will get to this point -- and sooner rather than later!
Thank you again! 😇
I want to point out, your progress has stopped, and you don't seem to be continuing?
What is POCOne's Magnetic Field at Peak Current? What is POCTwo's? At Peak Magnetic Field, what Voltage is "Generated" for the given turns you already have? Do both your POC's achieve the same variables?
Charge is Separated, and Current is Pumped, how does our simple Coil Arrangement produce this very simple requirement?
Bucking Magnetic Fields!
We have many Videos, many Diagrams / Images and many here have succeeded, you have been shown everything, nothing has been kept secret, all that is required by anyone that wants to gain access to this Technology, is Study and gain the understanding Required to Succeed! I promise you, its not hard and there are no more secrets! I have shared EVERYTHING Freely!
Don't be scared to use a little power on the Input, because you're gonna get all of it back and much more once you have the Config correct!
Please follow the guide we have given! If I were you I would ask Aetherholic, CaptainLoz and others what pieces of the Guide were the most helpful, that's what I would be asking! A few simple Images, or another video is not going to help, its just not.
Get familiar with Measurement Techniques we have already been through is the most detail ever, compared to other forums, learn to know what to look for! That's important, or you are just wasting your time!
Input:
Probes must be DC Coupled and only read the Mean or Average Power! V x I = Mean or Average Input Power. Understand, a DC Power Supply can not, ever, under any circumstances, supply an AC Waveform!
Output:
Probes must be DC Coupled, and you need to observe Waveform, because the Waveform will have Positive and Negative Polarities, in other words, an AC Waveform, you need to use RMS. Root Mean Square, or you need to use a Diode Bridge, dump the Output into a Capacitor, and load the Capacitor, then, and only then, you can measure the Mean or Average Output Power!
Of course we have been through all this, and we all have seen, many times, Members can very easily achieve Above Unity Results when the guides are followed properly!
Aetherholic is one of many that have verified, what I have given you, works if you follow it properly:
Chris has given everyone here the knowledge to be successful so you are in the right place.
Ref: Aetherholic
There is nothing hard about this! It is very easy and its about the cheapest experiment anyone could ever do to verify Energy Gain's Above Unity Factor of 1.0.
There are a lot of Total Idiots working very hard against us, and these dufusses are very easy to spot! Just look for Pure Dumb! A few Banned and Disgraced Ex-Members come to mind!
ISLab posted this 26 September 2023
Hi Chris, thank for reaching out!
Unfortunately, I got overloaded with urgent work and other issues and could not do as much as I wanted to. So I've spent what little time I could in re-reading your threads and re-watching your videos -- particularly the series on "Chris's Non-Inductive Coil Experiment" which I binge-watched in sequence while on a long journey. What I earlier saw as a series of experiments now is see as a deliberate development of ideas revealing the logic of the POC working, and even suggesting variations with other possible configurations. It has been eye-opening!
In between, I did manage to wind a pair of 16m coils of SWG 18 wire as below:
Unfortunately the two coils are pressing against each other, and I had to wind L1 on the side of L2. While I did some tests way back in June for resonant frequency, they were not impressive. The coils are probably too close and choke each other instead of freely resonating.
Only a few days ago I wound new coils with 16m of SWG 20 wires. I hope to get better results with these and will post soon.
I've read your guidelines and comments carefully and will implement as you say.
The reason why I would like to see a photo of working coils is to get some practical idea of a) how narrow the coils need to be to  raise the magnetic field high enough and where the tradeoff makes it too narrow, and more importantly, b) the winding of CW and CCW.
For (a) I have brought my coils to 1.5cm which I hope will be good enough.
For (b) I still am not sure. If we wind the coils left-right and right-left as is conventionally done on electromagnets, to the best of my understanding the windings will effectively be CW-CCW-CW-CCW.... on each coil! So this time I have gone back to my original attempt to wind one coil left-right on each layer and the other right-left on each layer. But this time the transition from one layer to the next is made by slanting the winding across so as to avoid making sharp turns (which were characteristic of my early coils!), since sharp turns will make internal reflections in the "antenna" that each coil is. I still do not know if this matters, although logically it should make a big difference.
I will hopefully return soon with something useful! 🤞😇
Thank you again Chris, for reaching out and for the guidance and encouragement!
Chris posted this 27 September 2023
Hey ISLab,
Keep on Keeping on My Friend!
Partnered Output Coils "Generate" each others Voltage via the opposite Coils Change in Current ( di/dt ), so yes, you're on the right track and always have been.
Magnetic Field Density works out to be Power Density, so by increasing the Magnetic Field, by Loading the Coils more and more, you get more and more Power Output.
You can do it!
ISLab posted this 28 September 2023
Keep on Keeping on My Friend! ... so yes, you're on the right track and always have been.
Thank you for your encouragement Chris!
I've made more progress, but this time I'm taking smaller intermediate steps and observing variations in detail.
The new coils are:
Coil Measurements
Both coils are 16m wound +0.3+0.3 leads of SWG 20 wire with 6.5 layers of 88 turns wound bottom to top only on each layer with insulation tape between layers. The first layer has 14 turns and most others are 13. I've mirrored the exact same count of turns on each layer in both coils. One quarter turn is used to bring the wire back from top to bottom without sharp turns so that the next layer can wind bottom to top again. Sharp turns are only at entry and exit from coils.
After winding, L2 had 7cm extra (half a turn extra) to complete the 16m length. Either L2 was wound tighter or it stretched a little while winding, or both.
L2: 88.5 turns CW. 0.5Ω, 489uH on air, 9.19mH on AMCC core.
L3: 88 turns CCW. 0.5Ω, 477uH on air, 8.82mH on AMCC core.
Finding Resonant Frequency
Following the method Chris taught here I tested every possible configuration for input and output, observing induced voltages and currents. The Signal Generator (SigGen) puts out 10.2Vpeak (20.4Vpp) Sine wave which was successively fed to L2 IN then OUT (see notation in image above) and then to L3 IN and then OUT, swapping the V and I measurements on the other coil for each case -- 8 configurations in all with multiple resonance F on each.
Only 4 of these configurations have magnetic fields opposing, and as expected these had the highest voltages of about 20V at about 207KHz. In all configurations there were at least two resonance points with the higher one being in the 700KHz to 800KHz ranges varying on exact frequencies in each configuration with output voltages ranging from 5V to 14V -- but nothing consistent.
Surprisingly there were two configurations in which magnetic fields were not opposting, yet the voltage was nearly 20V at F about 720KHz. The common feature of both these was that the SigGen was feeding the signal at the OUT end of the coils. Feeding signal at the IN end of the coils was consistently the worst.
Of the 4 valid configurations, the best results were when the SigGen was feeding OUT and the voltage measurement was on OUT of the other coil giving 21V each as opposed to 18.5V or so when SigGen feeds the IN and voltage is measured on the IN. All these are with conventional direction of current.
1: SigGen on L3IN gives 18.2V on L2IN at 206KHz
2: SigGen on L3OUT gives 21V on L2OUT at 208KHz
3: SigGen on L2IN gives 18.6V on L3IN at 209.7KHz
4: SigGen on L2OUT gives 21V on L3OUT at 209.3KHz (image below)
Pink = SigGen voltage, Yellow=POC voltage
The obvious conclusion is that the electron flow must enter the IN for best results. In all such cases the output voltage was nearly double of the input voltage.
Unusual obervation
I accidentally touched the open end of the input coil wire and the waveforms changed thus:
a) in the case where the two coils opposed each other, touching the open end caused the output wave to collapse and match the input:
b) in the case where the two coils do NOT opposed each other, touching the open end caused the output wave to shift 180° out of phase with the input and with nearly the same height:
I don't know how to interpret this, but I'm leaving this as an observation, in case anyone can explain.
Adjusting the Resonant Frequency
There is some variation in the F depending on which end of which coil we feed. I thought this might be due to the L2 being half a turn longer. So I tried to reduce L2 by removing the half turn or increase it by completing the turn into a full turn, while feeding the signal on L2 then on L3. I had expected that the peak resonant F would not change when feeding signal on L2 since the peak voltage depends purely on L3's resonance value which should not change as I did not change its coil length.
But surprisingly I found that in all cases the resonant F changed when L2 was changed, but in different ways:
a) When feeding SigGen to L2, and reading on L3: increasing L2 length (from no extra turn to full extra turn) increases F by about 2.5KHz.
b) When feeding SigGen to L3, and reading on L2: increasing L2 length (from no extra turn to full extra turn) reduces F by about 1KHz.
So it seems the peak resonant F is formed by some interdependence between both coils. Winding them to exactly mirror each other is therefore very important to get the best magnetic resonance!
The exact F was varying slightly each time because the long wire leads  moved too much (30cm leads seem to be tool long!)
I finally decided to remove the extra turn. Both coils now have exactly  88 turns. But L2 winding is shorter by about 7cm.
Preliminary Pulsing of Coils
Taking F=207KHz as an average, should give a wave duration of 4830nS or 4.83uS, and a quarter wavelength of 1.2uS. This value is for later use.
As a preliminary test, I loosely wound 4 turns of L1 around L2 and pulsed at 1.5V at 1.2Khz and 10% duty cycle as arbitrary values keeping both L2 and L3 in separate circuits and measuring currents in each using the 0.1Ω resistor.
The currents in both coils seem similar and mirrored, although L3 is slightly lower by about 15%. L3 also has a clear curve of current build up during the pulse, but L2 does not show such a build up. In the following images: Teal = L2 current, Blue = L3 current, Pink = pulse signal.
At 10% duty cycle (83uS pulse) the input of 1.5V drew 0.39A:
At 8% duty cycle (66.7uS) the input of 1.5V drew 0.3A:
At 2.97% duty cycle (24.7uS) the input of 1.5V drew 0.09A (a sudden and disproportionate reduction):
The change in the charging curve in L3 is interesting to notice. Raising above 12% duty cyle makes this curve turn back towards zero and both currents drop rapidly as duty cycle is further increased.
Next Steps
Next I plan to:
a) wind L1 tightly and with the correct length from suitable calculation.
b) recheck if resonant F has changed.
c) cut out excess lead wire if needed if it affects resonance F too much. Need to get F to be as stable as possible.
d) pulse at the correct F and D calculated from the resonant F.
e) rewire L2 and L3 circuit to drive a load separately or jointly. I'm not sure how to wire them to jointly run a single load. Any advice would be appreciate, @Chris.
Chris posted this 28 September 2023
Hey ISLab,
Looking Good! Use Conventional Current and the Right Hand Grip Rule, making sure POCOne and POCTwo oppose each other, and load each Coil with a reasonable load, say a 25 Ohm Resistor or a bit more, maybe a 30 Ohm.
Orient your Diodes as such, using Conventional Current and the Right Hand Grip Rule, again making sure each POC Oppose!
Drive your Input so each Coil's Current becomes approximately equal, but opposite.
Your Machine will become noisy when in proper operation, at low frequency anyway, so look for the Noise of Bucking Coils!
P.S: Applying your knowledge on Magnetic Field B and H, and why the Density ( B ) and Strength ( H ) are important, in all Energy Generating Machines, is very important to making steps forward. Why is it a fact then Energy Density is directly tied to the Magnetic Field B and H? What is Energy Density? Yup, all covered here on this forum already!
ISLab posted this 29 September 2023
Further steps.
Winding L1
I wound L1 with SWG18 wire without concern for length, but just enough to entirely cover the entire surface of the coil (1.5cm width). I got 2.30m on 11 turns with 20cm + 20cm extra for leads, wound in CW from bottom to top in one layer only. L1 impedance on air is 12.7uH, on core it is 147.3uH. The impedance of L2 seems slightly shifted: 475uH on air instead of 489uH; and on AMCC core it is 9.20mH (instead of 9.19mH).
This winding is not made for optimal length, but only a first step for experimentation.
Resonant Frequency
The resonant F has changed on L2. When feeding the Signal Generator on L2-OUT, the L3-OUT peaks at F=214.5KHz with 19V.
Feeding on L3-OUT give F=206.2KHz (same as before!) on L2-OUT with 19V.
Clearly the resonancet we measure is of the driving coil and not of the receiving coil as I had thought earlier as in my previous report.
Driving the POC
Pulsing at an arbitrary 1.2Khz as before gives an odd shape for the L2 current:
Since I could not find any cause for this, I tried again with a loose L1 on top of L2 as here:
The resulting pulse is now clean as before:
Adding a load of 22Ω on L2 and separately on L3 only reduced the heights of the waveforms, but did not change them.
Questions
@Chris,
Is the odd L2 waveform ok to proceed as is?
Should I try to get the resonant frequencies to be the same on both coils before proceeding? I could wind a dummy L1-mirror on L3 to get them to resonate the same again!
Should I change L1 in some way (perhaps on one edge of L2) to get back a clean current on L2?
Please advise.
Chris posted this 29 September 2023
Hey ISLab,
Well, I have to say, something looks wrong.
We have so many issues here, but the one issue you need to look at is:
  1. Wave Forms: Blue and Cyan are showing 200mV / Div, and only one Div Peak - Not enough to do anything with at all.
Like all Pumps, the Pressure we create, gives rise to the Volume we can Pump, for example, no Pressure, no Volume, so you need to work on getting the Voltage Up on both POCOne and POCTwo, once you get the Voltage up, then you will find the Machine will come to life.
Be careful, this can get very dangerous very quickly! Blowing a few Centimeters of 18 Gauge Wire out of the Coil is a very real possibility! Yes, I have done this and was absolutely amazed!
Get your POC up to about 10 Volts, then you will start to see something, 200mV is not enough to do anything with!
Remember, Pressure, the Magnetic Field of POCOne and the Magnetic Field of POCTwo oppose, creating a Pressure, and this is done via Ohms Law, Power P = V x I, because we are dealing with Real Power.
Small Steps, please be careful! You proceed at your own risk!
P.S: I think your aiming for High Frequency is Pointless. You're way to high in the Frequency Range. With very short pieces of wire, its a different story, so if you want to make steps forward, then you need to put aside all conceptions and focus on what you have on the bench.
ISLab posted this 30 September 2023
Thank you, Chris!
Are you referring to the 1.2KHz?
I will start lower around 300 or 400Hz or so which I vaguely recall as suggested in the guidelines.
Chris posted this 30 September 2023
Hey ISLab,
No, I mean when you mention High Frequencies, one example:
Other instances also.
Low Frequencies are very much easier to work with, and more is observable, more can be seen.
ISLab posted this 01 October 2023
I think you might have misunderstood the reference to 207KHz. This was when I was initially testing to find the magnetic resonance of the coils, and then later checking to see if the magnetic resonance has changed after adding L1.
This is not the frequency at which I am driving the coils. For driving them I used 1.2KHz arbitrarily to start, which I will immediately reduce to 400Hz from now.
The actual driving F will and duty cycle D will be selected from calculations derived from the 207KHz measurement. For example: if I pulse at 1.2Khz, the duty cycle should be about 0.14% to get a 1208nS pulse which would be 1/4 wavelength of 207KHz. Or else D should be 5.36% to get a 44.69uS pulse to give 10 full waves + 1/4 wave (or 41 quarter waves).
Is my understanding correct on this and in the calculations?
ISLab posted this 02 October 2023
I've just made a few more tests.
Raising the Input Voltage
Earlier I had noted that with my Arduino-based digital Frequency generator, I could not raise input voltage as the coil pulse somehow influenced the digital circuit and reset it. So now I replaced the digital generator by the analog TL494-based Swagatam circuit used earlier. This is more robust and does not trip. The switching is of course still done through the Quadratron.
Since my resistors are 1W I've put two 47Ω in parallel to make a 23.5Ω 2W as load on L2 and another separately on L3. (I will get higher wattage ones soon.)
Checked diode directions and raised input voltage to 10V. F=588.2Hz at D=9.4%.
L2 and L3 currents are now as below:
Yellow=L2 voltage, Teal=L2 current, Blue=L3 current, Pink = pulse.
Disconnecting the L3 coil raises L2 current as well as L1 current slightly -- less than 10%.
This is with L1 coil magnetic field pointing up and L2 and L3 fields pointing down.
Flipping coils
I tried wiring everything with all the fields in the opposite directions (which changes from which end the current enters the coils!) and did not see any difference.
I also tried flipping L3 upside down (and changing diode accordingly) and flipping fields in this mode also. No observable difference.
In all cases the load on L2 heats up rapdily and much more than the load on L3.
Using a loose coil
I replaced L1 which is tighly wound over L2 by 6 turns of the loose coil:
Recovering magnetic resonance
I came back to the question of magnetic resonance. Since winding L1, the resonance F of L2 and L3 are very different. So now I wound an extra L1-alt on top of L3 as an exact mirror image of L1: 11 turns CCW of SWG 18 of 230cm +20+20 for leads.
Testing by Chris' method for magnetic resonance gives:
  • SignGen driving L2-OUT gives L3-OUT = 19V at 201.5KHz
  • SignGen driving L3-OUT gives L2-OUT = 19V at 201.3KHz
  • for some reason when I tried again, I got peak resonance at 202KHz. Perhaps some shift in leads or coil position?
The resonance frequencies are now fairly consistent and equal. But it may be that the L1 and L1-alt are choking off the POC and preventing free resonance.
The currents now were (L3 leads swapped):
Root cause of the problem
Everything went off track from the point I wound the L1 coil. Actually I did a few more crazy experiments to solve the problem which I may report later, but nothing worked.
Reading further I came fortuitously on this note by Chris which seems to reveal the root cause of my problem. He says:
Sometimes Magnetic Fields don't Oppose?
In our configurations, it is the case that sometimes the Currents don't oppose. This is a very odd problem!
It is the case that the Input Current is greater than the amount of Electromagnetic Induction between the Partnered Output Coils! This is quite common! Personally I have not seen this very often, and I will explain why I believe this is so.
When the Magnetic Field (B) is not sufficient to Induce a E.M.F in the Opposing Coil, then the Current we put into the Circuit will become the dominant Current.
There will not be enough Electromagnetic Induction occurring in the System to Invoke Opposing Magnetic Fields!
The cause of this can be twofold:
  • Not enough Current flowing through the Coils!
  • Not enough Magnetic Field!
 Because this is a Chicken of the Egg scenario, we have to look at solving this problem from a few angles.
  • Increase the Current flowing.
  • Increase the Turns on the Coils and keep the Current the same.
Because the Turns are a quantity in the above equation, and by keeping the Current the same, we get more Magnetic Field as a result! This also increases the Electromagnetic Induction occurring.
I've highlighted in red the key. This really seems to be my problem.
Based on this insight, I will experiment a little more and revert soon.
  • strape
Chris posted this 02 October 2023
Hello ISLab,
I see no progress, I must say, I feel you are playing games, I have given you everything you need, and you keep making mistakes that I have very very clearly explained, in your attempt to play Games with the community!
I told you, right from day one, you need linear Scope Traces:
The Time Rate of Change of the Magnetic Field of the Primary Coil ( 25 turns on mine ), Induces a Voltage ( V , and because we have a Load, a Current ( I  in one Secondary Coil.
The Time Rate of Change of the Magnetic Field ( Current ( I  in this secondary ) creates a Voltage ( V  in the Tertiary Coil and because we have Loaded Conditions, we have a Current ( I . Both Secondary Currents Oppose each other, however one Current assists the Primary.
The time, I marked in the video @ 38 : 18:
Is Important!
This is where the Input Coil can bring the two Output Coils to maximum Amplitude as quickly as possible! This means we must look for this optimum point, Magnetic Resonance. Magnetic Resonance, where each Coil's Current is 180 Degrees out of phase, like we saw in The Mr Preva Experiment.
This point is where the two Coils reach Maximum Amplitude in the shortest possible time, the slap together, we have no Impedance of the Coils!
Here is one Cycle, marked in Red:
You can see the Ramp Up, or the Slap Together, this is important, it must be short, fast and have a good amplitude.
Compare to Tom Bearden's Asymmetrical Regauging:
And, here, you are deliberately showing Scope Traces that are very clearly WRONG!
WTF Man!!! This is so extremely Simple!!!
You also keep jumping to conclusions that has no bearing in this very SIMPLE Experiment! An experiment that people with very average EE Skills, can achieve with no problems at all, yet you keep showing everything wrong! You were close at the start and then went off the rails like you were attempting to mislead others with fake false deliberately manipulated false data!
I don't get it, why people try so hard to discredit such extremely simple and cheap tech!
You have followed none of my advice!
I am done with your Games, you're now on Moderation!
Chris posted this 08 October 2023
I have spoken to ISLab via PM and we have come to an agreement. I have jumped to conclusions a little too quickly, tied, and with dealing with many Trolls in the past, assumed I was being Trolled too early. For this, I am sorry, you are free to carry on, nut please follow advice given and video instructions.
I believe ISLab is and always was on the right track, I have said this before and stated this publicly.
@ISLab - Please focus directly on the Actions of the Partnered Output Coils, as the way, and the timing of how the Partnered Output Coils Slap together, this is where the Voltage is "Generated", via E.M.F = -N ∂ΦB / ∂t
We are using Asymmetrical Electromagnetic Induction, which incorporated Symmetrical Electromagnetic Induction, we have taken Electromagnetic Induction to the next level, we have Completed Holes in Science.
Your Input Coil is the Timing of the Action, it does not Drive this action!
Current through POCOne gives you a Magnetic Field of X, and the same is true of POCTwo, together, each "Generates" the others Voltage from this Rate of Change of this Magnetic Field.
Calculate your Magnetic Field with Load of 20 Ohms, here is the Calculator I have provided to help in this: Aboveunity.com Member Calculator
Thank You for your patience, I want you to succeed, please follow the Videos and advice I have given freely.
I enjoyed your video, Thank You!
ISLab posted this 09 October 2023
Reviewing my notes, I find that I lost my way after I inserted the 20 ohm loads and the currents dropped so low that the effect was gone. The rest was a series of desperate attempts clouded by sleep deprivation.
My sincere apologies to all for the confusion caused.
I realise my consistent problem has been low magnetic fields in POC from insufficient turns. So I will revert in a few weeks after winding new coils.
Thank you Chris and all others for your patience and your help!
Chris posted this 09 October 2023
Hey ISLab,
POC are Bucking Coils, so the more Buck we get, the more output is Pumped, its an Electron Pump, to free and Accelerate Electrons down the Wire, the more Buck we induce, the more Electrons are freed and Accelerated.
We already know this from Electromagnetic Induction:
It is very very simple, we have moved the Bucking from Input vs Output, to Output vs Output, Asymmetrical Electromagnetic Induction, that's why POC must Buck, but one must force ones self to stay on target and focus on the simple fact that the more Magnetic Field, the more Energy is Pumped!
Voltage is "Generated", via Charge Separation, and Current is Pumped.
ISLab posted this 3 days ago
I've made some progress in getting my fields up and reducing resonant frequency by winding coils with much longer lengths. I made two coils as below.
1) Wound coils of SWG 22 wire of 40m length of per coil. The resonant frequency is about 73Khz. The L1 coil is 10m of SWG 20 wire (a quarter of the POC coil length). I was easily able to get the general Sawtooth Waveforn on the outputs using any arbitrary frequency, say 1KHz but with large duty cycle of 8%.
But in order to get it to the resonant frequency, I would need to pulse it at 3.4uS which is the 1/4 wave duration. But my L1 coil has an impedance of 2.23mH and resistance of 0.5 Ohms, giving a time-constant of about 4.5mS. The pulse can barely reach 10% of the peak value before it gets cut off.
Do I need to reduce the L1 length and impedance?
2) I wound another coil of 80m of SWG 24. The resonance frequency is about 42.2KHz. This would need a 1/4 wave input pulse of about 5.9uS.
This time I wound L1 of SWG18 with just 6 turns. The input pulse is much faster and higher, peaking in 45 uS. But the magnetic field of L1 is so weak that it barely drives L2 to any useful voltage.
I could increase the number of turns on L1, but that would also increase the time-constant.
In other words, increasing L1 length and magnetic field increases the time-constant by too much.
But reducing L1 length makes the driving magnetic field too weak to activate the POC effect.
Could you please indicate the way forward?
Chris posted this 2 days ago
Hey ISlab,
If we use Floyd Sweet as an indication of the path forward, we saw so much that we can validate with Science, and in combination with his writings, we have a Gold Mine of Solid Data to move forward!
For example, none of Floyd Sweets machines had a Length of more than 50mm, or 2 Inches, or as I mentioned in one post, 1 KN or One Knuckle Length:
The Thread Coil Geometry shows, with a free Calculator, how to improve your Magnetic Fields.
We have 100% solid in theory, quotes, like:
Thus the system is self-regulating. As the load current increases, the complimentary flux adds to the cross flux. The voltage output remains constant. The primary limiting factor is the cross sectional area of the phase winding conductor.
Of course there are many more very good quotes, this is just one, cherry picked, quote, because its relevant.
The Magnetic Field of POCOne can be calculated:
Coil Length l
Coil Length l, is another very important Variable! Again the Mathematical Experiment is required, and already shown previously, how such a simple change can make such a big difference to the over all Outcome!
Exp 01:
Exp 02:
By making a single change, to ONLY the Coil Length l, we have: 25132.7412287 / 2513.27412287 = 10 times more Magnetic Field B, for no extra Current I or Turns N! Our Magnetic Field is Stronger for No Cost, only a Geometry Change!
All we have done is make our Coils Shorter in Coil Length l by a Factor of 10. From 0.1 to 0.01 Meters, or 1Cm.
Of course, the Voltage Generated is a Function of the Magnetic Field, the time it takes to go through a cycle, and the turns on the Coils.
I have already given very accurate details on how to build these machines, and what's required, of course I have been doing this for nearly a decade now. Many do not pay any attention, many do not absorb the information and many dont correlate the Hard Facts with the Evidence.
I am happy to help, and again and again, I will redirect people to the data:
Its all there, its all easy, its all verifiable and its cheap to get a machine working!
Good luck My Friend, I hope this helps you along!
ISLab posted this 2 days ago
Hi Chris, thank you for the help. I have been following all the guidelines: coil length (width) is 17mm, cross-section is large:
The turns are 210 over 11 layers for a wire length of 40m of SWG 22.
The newer coils are 393 turns over 18 layers for a wire length of 80m of SWG 24. I had to use thinner wire to fit it into the narrow 17mm coils.
I used longer wires here in order to lower the resonant frequency.
In both cases the magnetic fields are much higher now and the Sawtooth wave is distinct.
My current effort is to make L1 optimal for driving the POC at the ideal frequency / duty cycle combination.
Should I be widening the coils a little more so that all the layers a closer to the core? Thicker wires will require this if we have to maintain lowers resonant frequencies.
Any hint will be helpful.
Hey ISLab,
When in operation, take the Current Peak, and calculate the Magnetic Fields using the free tool I provided: Member Calculator.
