This thread is a bit of a Heads Up thread as to what Electromagnetics, or Electrodynamics in general, is incomplete and dysfunctional for the most part, to be able to advance Electrodynamics, in General!
This quote:
gyula has asked me to comment on Melnichenko's statements he posted in Reply#40 above. The set up Itsu has just tested can be modeled in FEMM using the axisymmetric method which is a true 3D solution. I have done this modeling the core with greater mu in the r dimension (the radial dimension) than the z dimension (the length dimension). I used mu = 10,000 for the radial dimension and mu = 100 for the length dimension. There is no overunity in that situation. Melnichenko is correct in making observations that the anisotropy of the core will affect the magnetic energy stored for a given ampere turns of current, but I can find no evidence that this can lead to OU. My opinion on his other statements of dividing the core into individual sections each with its own winding is that also will not produce OU. I will have a go at doing a simulation of such an approach and report back.
Smudge
This shows how Crippled a bunch of Dyslexic Equations really are when attempting to discover new previously unforeseen Boundaries!
For example, modelling this waveform in current Electrodynamic Simulators:
Is achievable, but not by the method I have shown you! Not in a Sim! The Asymmetry of this Configuration is NOT accounted for in Electrodynamics to date! Its an Incomplete Science and does not have Equations for this sort of Science! By Design and on purpose!
I mean think about it, does any Textbook tell you how to build Free Energy Machines? NO!
We do! We tell you how to build Free Energy machines!!! We have had more continued Success than any other forum in History! EVER!
So, my advice: As soon as you hear anyone talking about Simulation of these machines, you should think:
- Not possible!
- Electrodynamics is Incomplete, or these machines would be common Place!
- Wasting Time!
Please My Friends, do not waste your time with this total Nonsense!
Let me tell you, something important happens, where I have marked: Important:
What Happens? Well its a little hard to explain, but here goes:
The Partnered Output Coils do work on each other, to "Generate" a Voltage via Charge Separation, and Pump a Current by Opposed Magnetomotive Forces, at this point, your Input Coil does the tiniest amount of Work! It requires very little Current to achieve this task:
So, your Partnered Output Coils "Generate" Voltage and Pump Current! This is largely a Self Regulating System, doing work entirely by the Geometrical Design of the Coils! The Magnetic Field Strength being the Component that does Work! Or M.M.F, the Magnetomotive Force does Work on each Coil, regulating the other Coil, exactly as I described in the Thread: Timing
The Magnetic Field can be entirely created from the existence of another Current:
There is nothing that says You MUST be the Source! This is Called Parasitic Inductance Or Stray Magnetic Fields, a phenomena that Electrical Engineers are Brain Washed into getting rid of by the very definition of the Term: Parasitic
We want this, its a Useful and Required Phenomena, the opposite of: Parasitic, is Symbiotic we want this! Its Natural, it is how Nature works and wants to work! Don't Fight it, encourage it!
Best Wishes
