Electrical Energy comes from Faraday's Law and Magnetomotive Force!
  • 987 Views
  • Last Post 08 May 2022
Chris posted this 30 April 2022
This thread is to reiterate all other threads in a single Thread.
There is no Magic! There never has been! Everyone needs to forget about the Voodoo Science!
Electrical Energy comes from Faraday's Law and Magnetomotive Force! Both Combined, not separate!
Faraday's Law: ( E.M.F = -N ΔΦB / Δt or E.M.F = Bvl ) is Incomplete!
Magnetomotive Force is still poorly understood by many Electrical Engineers even today! Most mistake Lenz's Law for the Magnetomotive Force Component, and most will never explain that "Generator" Shaft Torque is a direct Effect of Magnetomotive Force.
Most Electrical Engineers try to explain that Shaft Torque is converted into Electrical Energy, which is about as far from the truth as you could imagine!
Shaft Torque is an After Effect! It comes after Voltage has been Separated and Current then Flows! Not at the same Time or before! After! It is very easily proven in Experiment!
Shaft Torque is a direct result of Drawing Current, which is an Opposing Magnetomotive Force on the Rotor! Again, an After Effect of Faradays Law!
I have said many times before:
  1. Voltage is Separated via Faradays Law!
  2. Current is Pumped via Magnetomotive Force!
We all see Symmetrical Electromagnetic Induction today! Science has never introduced Asymmetrical Electromagnetic Induction! Ever! Symmetry of Electromagnetic Induction means: Equal and Opposite less Losses! Always a Below Unity System!
Asymmetrical Electromagnetic Induction means your Input is assisted by a factor of Magnitude and your Input is reduced to give you the same output! So an extra Source of Energy enters the System, via Electromagnetic Induction, and gives your Input the extra Force needed to Free, and Pump Electrons from their Source, the Copper ( Cu ) Atom, down the Insulated Wire, via Faradays Law and of course Magnetomotive Force. This means, you have no more Equal and opposite less losses! You can have a much greater output than input!
Science has completely missed the fact that ANY Changing Magnetic Field can create a Voltage!
Science tells you that the only Magnetic Field that can create a Voltage is the one you Change in Time, by turning a Shaft or modulating a Magnetic Field in an Electromagnet!
Science has never told you that the Secondary Coil has its own Modulating Magnetic Field! As di / dt, the Change in Current occurs over Time, in this Coil! Of course, which can be used as a Source of Energy!
I have shown you all Asymmetrical Electromagnetic Induction:
At approximately the 30 minute mark.
What I have shown here is a very simple, very cheap setup to get started! A much better system can be employed, with a much greater Output! Scale and Design is everything here!
All you need to learn this technology can be found here: Builders Guide to Aboveunity Machines
We have had many replications! Many successes! We are the only forum on the internet sharing this Technology with you! It takes a bit to learn, it takes a bit to make this useful, but I guarantee its the Future and you will see this very quickly when you do a few simple experiments!
I have more coming soon, more advanced experiments! So stay tuned! Catch up! And we will all make a difference together!
Chris posted this 01 May 2022
Electric Charge is the accumulation of, the Elementary Charge, which is the Electron, and other Subatomic Charge Carriers, including Electron Holes ( Ions ), are Separated by a means of Moving Free Charge Carriers:
The difference between Terminal T1 and Terminal T2 is the Potential Charge Difference we call Voltage.
After a Voltage has been "Generated", there is no more Force to either:
  1. Free more Charge from Source.
  2. Keep Accelerating Charge that has been Freed.
Unless...
However, this is only part of the actual Process!
As we load the Output Coil, a Current starts Flowing. Current I through Turns N is Ampere Turns! Symbol At. Ampere Turns NI = At, has nothing, at all, to do with Faraday's Law of Electromagnetic Induction! Its not Predicted, or accounted for! You need to move to Ohms Law for this Prediction!
Typically; Magnetomotive Force ( M.M.F ) is Fm = NI Ampere Turns ( At ). They are the very same things in most instances.
It is this M.M.F that creates "Generator" Shaft Torque, in the Opposing Direction, seen as Shaft Drag. This is Calculated: τ = F r sin( θ )
So, via simple Experiment, and from what I have explained, you can see Shaft Torque comes After the Voltage has been "Generated", which is never "Generated"! Charge is Separated from Source, the Copper Atom, and Accelerated to the Wire's Terminals. This is Newton's Second Law: F = ma.
This is a pretty universal Law, we send Rockets to space using this very Law!
So, via some very simple analysis we can see, there is a Force F, Required, which is NOT included in Faraday's Law, as Voltage is just a Potential and can do NO Work! It is the Flow of Charge, a Current, that Does Work, which is Kinetic Energy! Just as Nikola Tesla told us.
Any movement of Charge, a Current, constitutes a Magnetic Field, as one is the other, from a different Frame of Reference! A Current is a Magnetic Field and a Magnetic Field is a Current.
However, it is the Change of Current that "Generates" a Voltage, and not the Current itself! This is: Δi / Δt, where Δ is Delta, representing the Difference from Start to Finish: Δt = 2 seconds - 0 seconds = 2 seconds.
Any Time, and Every Time, a Magnetic Field Changes in Time, this Change in Magnetic Field MUST be realised as a Source of Electrical Energy! It is simply Ignorant to ignore this very simple Fact! No matter what Magnetic Field Source you observe!
Therefore, the Secondary Coil, that has a Magnetic Field, Changing in Time, must produce an E.M.F: Electromotive Force, a Voltage, in a Conductor which is in proximity to the Changing Magnetic Field, and experimentally, we can see this:
Again, Experiment, and looking for the Effects, that are currently un-explained, is a very important process to take on! I have shown, and tried to explain for many years, that Electromagnetic Induction can occur more than once in a System, which this above video proves!
 Imagine, the Electrical "Generator", with No Shaft Torque, if you can turn the Shaft with a 10Watt Motor and get 1000 Watts out! How would we go about this? Would we need to reduce the M.M.F? No! Would we need to give the "Generator" a fancy Geometry? No!
We need to remove the Magnetic Drag on the Rotor right! So how do we do this? By Creating an Equal and Opposite Force back on the Coil that Creates the Drag in the First place right? Yes!
In the right configuration, a "Generator" can be built to reduce all Shaft Drag, making the Shaft turn freely under load. This is known as Superposition, where each Wave, or Vector Sum, of each Vector Force, can become Zero. Very simple, very easy!
Vector Superposition is very well known in Antenna Theory:
Which applies in Partnered Output Coils! Floyd Sweet termed this as Magnetic Resonance, as did Don Smith.
 More coming very soon My Friends,
Chris posted this 02 May 2022
As Members have followed, and done the experiments, the successes have come. Success comes from Understanding and of course knowledge of what one is doing!
It does not take long to see who is going to succeed and who will not! Some just do not want to succeed and only want to create trouble, a distraction, to show everyone how 'Trolley' they really are!
Never before, in History, has this Knowledge been shared as I am with you now!
It is obvious, the greats before us; Floyd Sweet for example, had a fantastic knowledge of Electrodynamics, in particular Magnetics! He knew Electromagnetic Induction inside out and backwards! Don Smith also had a very good knowledge! Don had trouble conveying his thoughts clearly however.
Just like Don Smith said:
Coils are just antenna's! They are!
Floyd Sweet also hinted to a similar thing:
Resonance frequencies may be maintained quite constant at high power levels so long as the load remains constant. We are all familiar with AM and FM propagation, where in the case as AM, the voltage amplitude varies, and with FM, the frequency is modulated. However, the output power sees a constant load impedance, that of the matched antenna system. If this changes, the input to the antenna is mismatched, and standing waves are generated resulting in a loss of power.
Ref: Floyd Sweet - Magnetic Resonance
In the Thread; Dipole Antenna - Parasitic Capacitance and Resonance, we show exactly, with Peer Reviewed Paper, this is the case!
I have shown many times, Coil Resonance, and some even with Partnered Output Coils Resonance, how to find this Resonance:
Resonance is where each Coil has peak Amplitude as you all know! Magnetic Resonance is where each Coil has opposite Magnetic Field's and approximately equal in Amplitude. This is only one way to reach the Ideal Operating Point of Partnered Output Coils, there is another way, one which I have hinted to, but no one has realised this yet.
Captainloz's success used the first method, using Resonance. Finding Peak Amplitude.
When I shared my work, in the form of a Toy, I did say, there is more and that it could be made much better!
The basic Concept, its right there! Its how:
  1. Voltage is Separated!
  2. A Current is Pumped!
To Pump a Current, one must continue to Free Electrons and also Accelerate them down the Wire:
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.2418 electrons⁄second. Thus the duty factor of the copper changes. I2R Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load. This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field. Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
Ref: Floyd Sweet - The Space-Flux Coupled Alternator
The way in which we think is so very important! Think about this the right way, its easy! Think about this the wrong way, its hard!
My Friends, Trust is an important thing! Some here, some members, and some visitors are here to TRY to take all the credit for My Work! We have seen many times! They are NOT here to help Humanity! They are here because of Greed! They are here because of the desire to be Hero's, or at least to try to be a Hero!
We don't want to be Robbed by Suspect People, by Doggy Shysters, do we!
This is why I have tried to build a close Community, of Trustworthy People, unfortunately, I have not been a very good judge of Character of some! Some in the previous Inner-Circle, have been Exactly the type of People we don't want! We want good Honest Trustworthy People that wont break the Rules, go against My Wishes, and try to Sabotage My Website as we have seen recently!
Chris posted this 05 May 2022
In any case, the relative Energy Density of a System, is the amount of Energy a System can Store or Contain. In the Thread: Energy Density, we cover the aspects of Energy Density in greater detail.
The Fields we use to define the so called Fundamental Fields, Electric Field E, Magnetic Field Density B and Magnetic Field Strength H, are the Fields that can define the Energy Density!
Energy Density is the amount of Energy, that you can withdraw from a stored state! Its your total Energy Output from the System! Plain and Simple!
In the following Document: Comparing batteries to generators as power sources, you will find these two images:
It is a very clear winner, that "Generators" are a better option, except for the Fuel Source! Which is not needed, but because Science has not yet realised the Asymmetry of Electrodynamics, they have stuck to only one option of Magnetic Symmetry, which in turn requires a Fuel Source for a Symmetrical "Generator"!
It is important to note: As Each Field; E, B and or H increases, as does the Energy Density!
I have said for a long time now: "Get your Fields Up", and this is the reason why! More Energy Output is possible as your Magnetic Fields increase in Magnitude.
@R - When I say no, there is a point where a "Best" output is achieved. But this does not stop the device from working.
Tom Bearden and the others involved with the MEG, were exactly right, this simply is a "Generator" - The Motionless Electromagnetic "Generator"
If we refresh our memory's on Induction, what's the first rule?
   Time Rate of Change of the Magnetic Field
Feed Forward and Feed Back is what this is. This is how it works. So many think that Electrical Energy is totally Consumed by the Load! This is NOT TRUE - Some is. Some can be used to do Work.
E.G: To Assist in the Opperation of itself!!!
Thus the Video Title: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
It just so happens that the Magnetic Fields Interact with each other in such a way as to Reduce the Effects of Lenz's Law, Magnetic Fields that Oppose each other.
Like I have said, this can work many ways, but following the basic rules of Electromagnetic Induction will be the most simple.
   Chris Sykes
       hyiq.org
P.S: When I say a "Shorted Coil" This is supposed to represent the Maximum Possible Load for the Device. For example, These devices will never show any OU unless sufficient Load is connected to the Device. Why? Because Current (I) through Turns (N) with Core Permeability (&mu is the Magnetic Field (B) - We need a sufficient Magnetic Field in Each Coil to make the Device work. It is Magnetic Field Interactions that Give You Over Unity in these devices - So work on getting your Magnetic Fields Up!
Ref: EMJunkie (Me Chris) - Partnered Output Coils
Back to Tech:
@Itsu - Have you checked the few things above I asked?
Some things to look at:
50 Turns (N) x 0.5875 Amps (A) = 29.375 Ampere Turns (AT) = Gilberts (Gb) = 36.914
100 Turns (N) x 0.05948 Amps (A) = 5.948 Ampere turns (AT) = Gilberts (Gb) = 7.474
36.914 / 7.474 = 4.939 times less Magnetic Field in the Partnered Output Coils.
Which is not going to be close enough for any real work to be done! You really need to get your Magnetic Fields up on the Partnered Output Coils!
Also here, I have said this before here also.
The Thread: Coil Geometry goes into this in great detail!
Because the Magnetic Field for a given Current and a given geometry is defined by Amperes Law, we need to design a Geometry that maximises the Magnetic Fields. Don't forget, as the Magnetic Fields Change in Time, we also have an Electric Field present in the same space as the Magnetic Field that is moving.
Of course, it is obvious, that any Electrodynamic Machine increases in Size as the Power Output Increases!
The Hoover Dam is one example:
The huge size of those Rotor Coils is an example of Power Output as Size increases.
Jagau posted this 07 May 2022
These are very wise words Chris, the evidence is there.
Chris posted this 07 May 2022
The Magnetic Field of any Inductor is defined by Amperes Law, this we have covered in great detail in  the thread: Coil Geometry.
 Asymmetrical Regauging gives us the ability to do a very fundamental thing! We can Generate Electrical Energy, via Asymmetrical Electromagnetic Induction. which means we can have an Output Power that has no real Negative Effect back on the Input Coil! Essentially the "Generator" shaft spins freely, but we still have maximum Power Output!
This is all about Force, Magnetomotive Force, as explained above, Current I through Turns N, NI or Ampere Turns At, and the off balance of Force, or another way to think about it, is to make sure the Coil Impedance moves in the opposite direction to our Conventional Symmetrical Electromagnetic Induction! A very Simple Task, and yet totally Non-intuitive for so many!
In Video Four of the series : Chris's Non-Inductive Coil Experiment: @ approximately 14 : 49
I showed that Output Current requires the support of the Input Coil, which is Magnetomotive Forces to Excite, Free Electrons and Accelerate them, as a Current Flow!
In any event, careful and specific design is required to "Generate" a desired Voltage! The Magnetic Field B must be of a Sufficient Value! This value can be defined by Amperes Law, and the Voltage Generated is via Faradays Law.
This means POCOne needs a specific Design as does POCTwo! This Design must be capable of producing enough Magnetic Field and Voltage to do the required Work. This is hear as an audible Bucking Noise, heard in all of my technical videos.
Remember: It is the Magnetic Field, Changing in Time, that creates a Voltage, and it is Magnetomotive Force that pumps Current!
Shadow_ posted this 08 May 2022
I found a document about a dipole
https://mega.nz/file/V14TUSbQ#_qCBQ9wxklQ90rcEs8eo27GdZ36s0MnZiLPjRvlsNmg
Maybe will interest you too
Gandalf
“All we have to decide is what to do with the time that is given us.“
