Fluke IR Thermograph could help us discover Lepton's energy flow in partnered-scalar coils
  • 725 Views
  • Last Post 11 July 2017
alohalaoha posted this 10 July 2017
Chris and all researchers,
I have got very important and intriguing information about dependence of direction of Leptons energy flow from winding directions in so called Partnered-Scalar coils configuration.
Main proof for this statement is famous MR.PREVA experiment with partnered-scalar coil windings.To remember you - in one of coil winding run much bigger current than in other winding, which have different winding direction to the first. How is this possible and why ?
I think, we have a deal with undiscovered energetic substances far smaller than electrons. Some scientist called them Leptons. They are material in nature, have very-very low mass, very low radius and unknown attributes in contacts with ordinary mater and what is important they are always released in radiant and scalar field experiments. They are fathers of every anomalies in unusual experiments.
Message from my Anonymous friend,an Russian Energy Researcher guy.
Anonymous:
About the choice of ferrites, the higher the frequency, the lower the permeability shoul be,used, on the lower frequency - contrary. This is due to the saturation time of the ferrite. Ferrite works great and gives all the accumulated magnetic field in the range from zero to presaturation point, with the condition of having the correct demagnetization process. Otherwise, an uncontrolled growth in consumption from the source.
Anonymous:
The primary organization of an transformer, as well as his coils winding directions have UNKNOWN SECRET. The Leptonic energy flow of certain potential depends on direction of coil windings. Winding with anti-clockwise direction (CCW) will create an Leptonic energy flow stream from + to - , and winding in clockwise direction (CW) will create flow from - to +. In 1st. CCW case, switching transistor is ALWAYS COLD, while in a second CW case VERY HOT, due to different speed and directions of
Leptonic energy stream. Check yourself.
His P.S. If you are not able to understand Leptonic enregy flow according to different winding directions, then draw conclusion about your possibility of building BTG, Self-runner.
I think, we have deal with undiscovered energetic substances far smaller than electrons. Some Russian scientists called them Leptons. They are material in nature, have very-very low mass, very-very low radius and unknown attributes in contacts with ordinary mater and what is most important they are always released in radiant and scalar field experiments. They are fathers of every anomalies in unusual experiments.
Chris posted this 10 July 2017
This is an excellent Post! I think some data here may be a little too advanced for many. I urge others, Book mark this post for later reading if it does not yet make sense. It will be very helpful!
Energy extraction with very little Heat or even a cooling is not only possible, but very easy to achieve once the principles are understood, and a device has been built on these principles.
Several of my Videos I have shown, the Coils do not heat, or get cold.
P.S: One could use a Microsoft Kinect IR Sensor also. Very cheap now, code is easy also.
Thans Chris,
Maybe could help Arduino test board with non-stop temperature measurements of switching transitor via some cheap NTC or PTC resistor with complete hard logging data in flash memory or meybe some ssm card.
ps. I forget to say in some experiments with Tesla transformers there were being very cold hv capacitors after magnetic-quench spark gap and also cold heavy primary copper bar, have much-much lower temperature than ambient temperature. This anomaly was detected in many experiments with different Tesla transformer researchers.
ps-more. Also i have remembered that once Floud Sweet had made short-circuit in his VTA output windings, he had freezed both wires together with pair of fingers, He had one week pain in fingers after his small error.
Zanzal posted this 10 July 2017
Interesting ideas.. I assume by Lepton you mean Neutrinos. My personal speculation at this point for energy absorption from cooling in transformers would be a natural consequence of dipole alignment within the material. That is the material being aligned by magnetic flux needs to steal energy in the form of heat to regain disorder. This might not be detected is normal transformer activity since there may exist heating of the material due to Lenz and other losses. Systems that avoid Lenz and utilize permanent magnets to bias the cores may as a result absorb heat to provide some aspect of overunity.
This of course is just an opinion, without having observed it myself, I am just speculating based on the observations of others. While I am quite certain of the existence of overunity due to natural forces being thrown out of balance, the rumors of cold current seem uncertain. Even Sweet's claim of being shocked by something cold is not entirely convincing. Having burned myself on hot transformers I can testify that nerve endings don't always immediately register very hot differently than very cold and many overheated transistors have felt briefly cold on brush contact but clearly hot when touched for any length of time and if its carrying current through your body then all bets are off on accurate nerve signalling.
Of course if anyone has first hand measurements with IR device showing excessive cooling in the transistor below ambient then I hope they decide share it. One interesting thing I did encounter was when applying a permanent magnet to a transformer I'd very often melt a heat sinked transistor just by the act of moving the magnet around on the transformer. That's kind of the opposite end of the spectrum though.
alohalaoha posted this 11 July 2017
Hi Zanzal
Thanks for reply.
Well not quite a bit - Neutrinos or Anti-Neutrinos, but assumptions are more like similar with Joseph Cater's concept of "Soft Electrons" in his book - The Awesome Life Force - Orgone.
Joseph Cater - The Awesome Life Force- Orgone
https://yadi.sk/i/OPK8wfZC3Kw4p3
These "Soft Electrons" or like Real Russian scientists called them Leptons, Real German scientists called them Tachyons, Real American scientists called them - Orgone, are far-far smaller than ordinary "Hard Electrons" used in main stream science. These particles also had been mentioned by greatest Real American scientist ever John Worrell Keely (not compare with NIKOLA TESLA because Tesla had been a Serb), in his famous lifework "40 Laws of Sympathetic Vibrations" like "Atomolini ".
KEELYS' LAWS OF VIBRATIONS at Russian and English
http://x-faq.ru/index.php?topic=1911.0
http://ua-hho.do.am/index/zakony_kili/0-8
http://realstrannik.com/forum/dzhon-uorrel-kili/795-dzhon-uorrel-kili
John Worrell Keely (1827 — 1898)
P.S. As i could remembered at old realstrannik.ru forum was IR-Thermograph picture of Tesla transformer device in work with very cold HV sparking capacitors and couple of cold primary windings of heavy cooper bar.
I havent any more that IR-Thermograph picture in HARD disks.
