Fringe Experiments With VTA Style POCs
  • 2.3K Views
  • Last Post 27 December 2025
FringeIdeas posted this 31 July 2025
Hey!
Starting a new thread for this. But it's sort of a continuation of this thread and post fringeideas-non-inductive-coil-experiment.
This is my experiments with the Floyd Sweet VTA style POCs.
Specs:
  • 0.8 mm wire, each coil is 250 turns, CW and CCW wound.
  • 3 mm gap in between the coils.
  • 3 mm gap between each magnet and its adjacent coil.
  • CSA is about 54 mm x 105 mm.
  • Coils length is about 14 mm or so.
  • Magnets are 150x102x12 mm (I also have a few 150x102x25 mm magnets).
  • The core material is taken from a microwave oven transformer, hacked to pieces.
First, Chris, kind of funny. I mentioned I had actually seen that slow rise of the voltage and brushed it off as a bad scope or probe. But also, when I first built this particular build I had also noticed the limited frequency range in which the bulb would light. I built the second setup with ferrite thinking that would help but it didn't. So I concluded that the coupling between the coils was just horrible, and I put them on the shelf. 😄 My my, I step over a lot of things that are right in my face.
So, I went ahead and replicated the effect shown in Chris's video here..
I noticed in the comments of that video that someone had mentioned it might be the bulb heating up. Which kind of makes sense, I guess. But if I am of the correct understanding, voltage should be there, over the bulb, immediately, despite the resistance of the load. Current of course should rise a little as the bulb heats up and the resistance drops. But not the voltage.
So, I made a video. Two parts. The first part I have a normal MOT with the coils and I show it's not the bulb. I address the flashing at lower frequencies, and the low (upper) frequency at which the bulb goes out. I also talk a bit about how this effect cannot be due to impedance, or core material, standard explainations, etc. Then in the second part of the video I show my build of this particular configuration, on which I threw a 100 turn input coil of 0.6 mm wire, and it shows the effect. Sorry it is not as pronounced as Chris's, but it's there no doubt.
Here is my video, it got kind of long, 15 minutes, but it's good I think.
Also, at the end of the video, I mention that the effect reminds me of Chris saying (somewhere?) that the POCs act like a capacitor, and two videos come to mind. One by Steven Marks and one by Akula.
In the Steven Marks video he turns the device upside down, and it starts "winding down". I think there are other videos of his where he talks about this effect. Winding up and/or winding down, even though in this video when he turns it back upright the voltage is immediately back up. Here at about the 2:40 mark
In Akula's video, he has a similar device which he hooks up to an incandescent light bulb and shows how it takes a while for the voltage to build. His takes a bit over one minute. Here at roughly 6 minutes into the video, he shows and uses the words "as the system accelerates".
Anyway, I'm not sure if that is what we are seeing here, but it really resembles it. It definitely seems like there is more of a separation between POC interactions and the input. I'll definitely be playing with this, while trying not to step over anymore obvious effect 😀
Thanks!
Chris posted this 01 August 2025
Hey Marcel,
Awesome work! Thank You for Sharing and also for confirming the same set of effects we have discussed.
Now, the Coil Structure you have built, it is by itself, a Solid State Electromagnetic Induction Black Box. For most people, this is no big deal, but there is more!
We have Voltage Generated via Charge Separation, and the Current is Pumped via Bucking/Opposing Magnetic Fields, this we already know from prior experiments. The Black Box we all were used to seeing, is now completely clear, see through and we have a full and complete understanding of how this works!
We need to, when you're ready, focus on the Feedforward and back techniques, meaning, we need two of these Coil Structures, the same, and we need to carefully feed the Output of One POC, P1, into the other, in the opposite Coil, P2:
We get a Self Oscillating effect going here:
Sparky explains that there is a little part in the Generator that he has withheld from disclosure – A $1.50 part from Radio Shack that could be gotten at 30c in quantity that is not a capacitor (no resonance effects) that divides the current somehow into the circuit being Spherical With light bulb filament parallel, that puts a small µa current into the Power Coil as well as the Excitation Coil, that works with the Magnets in such a way that there is halved A Vector Complementarity ( he calls this unit a: "Vector Oscillator" )
Ref: Floyd Sweet Lab Notes
Now, we must note, Walt Rosenthal gave us these gems:
The VTA "likes" to always see a minimum load of 25 watts.
And:
The VTA can be started by momentary connection of a 9 volt battery to the drive coils when the machine is operated in the self-powered mode. The operation is stopped by momentary interruption of power to the power coils.
The VTA was a: Vector Oscillator
My Friends, we are very close, you all have way more than you can imagine, the future is going to be Glorious! The other forums, the ones that have a track record of Zero Progress for Decades and Decades, well, they are obsolete and have been for a long time now! We are Light Years Ahead of the other forums!
FringeIdeas posted this 01 August 2025
Chris,
Glad to help! And just to be clear, I need to order another set of magnets I guess?
Strange thought, but I'm starting to feel that the magnets just served as a path for the coil flux, and nothing more. Like an iron plate would be a suitable replacement if the magnets broke. Just a funny thought. Don't read too deep into that anyone please. 😄
I'll get back to building and reading up a bit on the feedforward and feedback.
Thank you!
Hey Marcel,
No, you can use the one set, just build 2x Power Coils like Floyd Sweet did.
Later on, we will see, the Magnets Flux will move, its going to do work later on, in other Coils as well as add some energy to the Power Coils.
Ah ok, again, I stepped over the obvious. So four coils, basically utilizing the same space. That is good, I was running out of core material. 😀 I'll start building.
Edit: Chris. Speaking of core material, I've been meaning to ask, if I have not already. Where did you get your material from for this build? And what material is it exactly?
Thanks!
Hey Marcel,
I collected the I Laminations over the years. I collected the UPS's that my Clients were replacing, the Eaton 1K and 1.5K and stripped out the transformers.
There was an image here:
The I laminations:
After disassembly, you can collect the I Laminations:
I lugged around and took the time to strip down the transformers over the years.
FringeIdeas posted this 04 August 2025
Chris, thanks! I wish it was a bit easier to find parts in Finland. I have a friend who knows someone that works at ABB. He was trying to get us in to the factory so we could grab scrap metal from the large generators and motors they build. So far no permission, let's see. I'll have to keep trying to locate free microwaves online until then.
So.. build complete!
Four independent coils. Two wound cc and two ccw. The POCs will be paired so that, for example, the left side has POC1 on top and POC2 on bottom. Then the right side the same. The coils are 250 turns of 0.8 mm wire each. The core material is a MOT core cut up into pieces and jammed in like tetris with a bit of epoxy. Core cross section is 36x62 mm, and 25 mm wide, each. This time I took the core material straight to the edge, I did not build the gap into the former itself. I have also 3d printed spacers for between the coils and between each magnet and coil. 3mm, 2mm, and 1mm, so I can play with different spacing.
Today I have got a bit busy with house work, but tomorrow I plan to give this a bit of attention. First I'd like to see if I can use only two of the coils to find the same slow rise in voltage that existed with the bigger coils. Observe how it differs from the larger coils, and why. Then I'll get back to reading a bit more about feedforward and feedback, and try connecting the POCs criss-cross like the Floyd Sweet schematic.
Edit: My focus has been a bit scattered so I'll focus on this setup and shelf the RT experiments and spark gap stuff temporarily.
Thanks!
FringeIdeas posted this 06 August 2025
Hey!
So some experiments with the four coil setup.
Looking at the Floyd Sweet schematic, I followed the flux direction of the power coils to kind of assume which coil would be on top within the pairs, with flux pointing inward.
Just for the sake of looking for effects, I threw a 100 turn 0.6 mm wire input coil over both of the top coils, and I used my top/bottom coil assumptions to come up with my own diagram, which was a little easier to follow while wiring up the coils.
Ugly, I know, I'm sorry. So this is set up in the typical fashion where the input coil will fire a north downward, and because of the diode polarities the top coils will not run currents, but the bottom coils will. The bottom coils then feed into top coils and to the load.
I did see somewhere online, an animation where, at one single point in time, the coil pair on the left had inward N poles while the pair on the right had outward N poles, and it alternated. But I think this is wrong. From what Floyd Sweet said I believe that both pairs of coils should be opposing in the same direction at the same time..
When the current in one half of the conductors in the coils (i.e., one of the bifilar elements in each coil) of the device is moving up, both the current and the magnetic field follow the right-hand rule.
The resultant motional E-field would be vertical to both and inwardly directed.
At the same time the current in the other half of the conductors in the coils is moving down and both the current and magnetic field follow the right-hand rule.
The resulting motion E-field is again vertical to both and inwardly directed.
Assuming I understand that correctly. So...
Things to note:
  1. The output was quite bad. I believe the input coil placement is stuffing the output. Maybe the outboard drive coils are a solution to getting the input coil away from the power coils.
  2. The rise on the voltage of the output was much slower this time. It took maybe 4-5 seconds to get to full amplitude.
  3. No negative swing on the output. All voltage and current traces were on the positive side.
  4. Also there was zero impact on the input when removing the bulb from the output.
Here is the video.
Chris, two question for you if you don't mind.
1) You quoted Floyd Sweets lab notes with this.
I had read that before, but didn't give it much though then. I want to guess diodes. This sounds important. Can you elaborate a bit more on this?
2) This is digging in the memory a bit, but recently, within the past several months, somewhere you posted a quick comment It was something to the effect of "and how can we get a sinusoidal wave out of this? simply....". I'm quite certain it was in regards to Floyd Sweet, but I can't for the life of me find where you wrote that. Do you have any recollection of this comment?
Anyhow, I'll play with this setup, including this input coil, a bit more. But I think the drive coils might be necessary at this point to get the input away from the power coils. I ordered some more wire but it won't get here for another week. And I need to source a few more free microwaves for core material. But that seems like the direction I will probably go with this.
Thanks!
Chris posted this 07 August 2025
Marcel, My Friend,
Sorry for the late reply.
Your questions:
Yes, my research points towards Diodes, but I cant say for sure. We know he did use Stud Diodes on the input in the early machine:
I wish I was there and observed this Machine in operation as Floyd Sweet had it. Yeah I can make it work, but my machines are not as good as his was. In time I hope I can achieve his level as he was a guru!
Yes, I remember making the comment, several times actually, in different places. Yes, I believe you see now, how this works, as it was supposed to work! It is genius!
This machine is, at its heart, an Oscillator that runs on Feed Forward and Feed Backs.
I am so proud, that we, together, have come so far! You guys, that have stuck with me, and believed, you all deserve the credit here, and Jesus, because I feel he gave instructions to share and start this ball rolling. The future is going to be awesome! Glorious!
Those that wronged us, the world will forever know who they were and what they did. They will be held accountable!
Chris posted this 09 August 2025
Hey Marcel,
In my studies on Floyd Sweet and the VTA, I noticed the very extensive knowledge Floyd had on Electromagnetic Induction! He wrote in several places about it, but I feel one particular instance at the moment will be helpful?
The page, attached, talks about the Magnetic Field:
You can see a fundamental equation in Transformer Theory, one of the more commonly used equations.
It is well known, and we have spent a long time focusing on and studding the Magnetic Field and how important it is, that the Density of Φ, moving in time t, is important for the Generation of Voltage, and we know, B is dependent on Current I through Turns N, through Cross Sectional Area, A, at Frequency f.
This means, the Load is an important factor! We must use a Load that enforces Current I to Flow.
Walt gave us this Gem:
Best Wishes mate,
FringeIdeas posted this 09 August 2025
I do very much appreciate the information, and little bits of the puzzle within the forum you have laid out.
I'm still waiting for wire, so trying to use my time to read and make notes.
I think I might have spoke too fast when I shared this, I'm not sure.
I need to stare and meditate on a few schematics and pictures. In the meanwhile, I do have two questions if you don't mind.
1) The placement of FB1 and FB2, Am I correct to assume that these are wound on top of one of the POC coils, and that it doesn't matter really as long as the correct phase is taken into consideration? Picture of the schematic so readers know what I'm referring to.
2) This is a closeup picture I had grabbed from another thread, sorry I can't recall which one for reference. But you were talking about the size of the cores in the drive coils. I assume this part is what you are talking about? It's a bit hard to make out.
Edit: A second picture which is more clear..
If so, that is really interesting, they are quite large, extending far past the gap and over the sides of the power coils. Much to think about there.
Edit again, sorry this post is a mess. Found my answer here in your video, at about 5:50, Did Floyd Sweet's Vacuum Triode Amplifier have a Core?
Scratch question number 2, but question number 1 is still valid. 🙂
So, I'm still trying to gather information here and makes some notes for myself. And waiting on wire. Good chance I'll be quietly lurking around the forum only reading, not posting, for a week or two. Again, thank you for the direction and information you have given!
  • Drasko
Hey Marcel,
The point of view and the way we describe things, from person to person, especially things that are a little controversial, can be quite different.
With this image:
When you say: "Not this", we could see this from the point of view: "What goes up, must come down", but yes, your analogy is correct and the Power Coils must always Oppose at all times.
I believe FB1 and 2 were would over the top, yes, but I don't know for sure. There are several configurations I have found, but the best, which may not be correct, is on the bottom POC of each Power Coil, Aiding the Magnets Flux, so a Right Hand Grip addition to the Magnets North Pole, and the POC underneath will Oppose, the POC Above, not closely couples, will then Aid the bottom Magnets Flux, Oppose the Bottom POC, but assist/Aid, the Input Coil.
This is my preferred configuration, but there very well may be a better way, I just have not found it yet.
This is a good question:
Floyd Sweet, he was quite the Character, observing his body language, the way he spoke, how he was showing his machines, his level of Native Knowledge, I saw some unique traits. I think he was very smart, but he tried to hide it behind a facade of grunts and constructive criticism.
Walt Rosenthal, legend and guru, said:
The Vacuum Triode Amplifier (VTA) invented by Floyd Sweet consists of two ferrite magnets and two to four coreless wire coils.
But, what Walt was told, was likely a miscommunication of sorts, in my opinion.
I can imagine Floyd Sweet pointing, and saying:
In there, there is no core, in there, see.
And, this would mean, there is a small Gap, between the Partnered Output Coils, not Bifilar, because the definition for bifilar is:
A bifilar coil is  an electromagnetic coil consisting of two closely spaced, parallel windings. The term "bifilar" describes wire made of two filaments or strands, and it's commonly used for special types of winding wire in transformers.    Here's a more detailed explanation:
  • Two Parallel Windings: A bifilar coil is essentially two wires wound together, side-by-side, forming two separate but closely intertwined coils.
  • Bifilar Wire: The wire used to create the coil is often referred to as bifilar wire, which is essentially two wires bonded together.
We just did not have any evidence for this, so we must take a more board definition of the terms used.
Like Don Smith, Floyd Sweet had diabolical communication skills, and that was one reason that these machines have laid in wait for so long.
Now, I may not be entirely correct on all of this stuff, but I think I am pretty close. Certainly Experiments show much better results than any of the other forums have ever had!
  • Drasko
  • Plasmonic
FringeIdeas posted this 10 August 2025
Hey Chris, again thank you for the information and answers.
Above, concerning the core, I meant to link this video, but for some reason it didn't link and my edit time timed out. Again, around the 5:50 mark.
And, concerning the way in which the POCs buck, inward at the same time, or alternating.. this picture.
That actually also came from one of your videos too.
Around the 2 minute mark, there are this image with this animation.
Amazing, I've watched these videos 100 times each and there is still stuff I miss, and a lot I forget.
I just wanted to document where I was getting my questions, for other readers.
So, yes, wire is coming. I'll get some cores together as well. In the meanwhile I'll keep going over the videos and the information on www.hyiq.org. The feedforward/feedback is slowly coming together in my mind. It seems like quite a delicate balance, but should be fun to play around with. I'll post more when I can.
Edit: Actually one more question, just a thought that came to mind. You seem to quote Walt Rosenthal a lot, saying..
Is it a valid assumption that this 25 watts is the point where the coils became strong enough to, were able to, gate the full flux of the magnets? Or am I completely missing the point of why you highlight this quote so often.
Thank you again!
FringeIdeas posted this 12 August 2025
Ok, so I've been reading, watching videos, etc, and a couple comments and an answer to my own question. Then I'll share a small experiment that I did. First the question and comment.
The question was, why is the quote by Walt Rosenthal shared so often.
I found my answer here, in the pdf that is given, Guidelines to bucking coils, in this Floyd Sweet update https://www.hyiq.org/Updates/Update?Name=Update%2030-11-14
Long story short, current on the output equals more magnetic field movement in the system, which is what is making the system work in the first place. So a lot of energy machines, with certain coil configurations, especially when speaking of the VTA, will require a minimum amount of magnetic field movement to work properly. So 25 watts is not a magic number necessarily, it was just a magic number for Floyd Sweets machine. However, if we are building similar, we should expect similar.
So, the comment. I had asked Chris if he remembered where he had mentioned, in some post somewhere, about making the output AC by doing....yadda yadda. I could not remember where this was stated. I found it in the thread 3D Printing Bobbins/Formers for Coils.
The question Chris actually proposed, is here
Chris's answer is here
To sum it up, the answer was to have two units operating 180' out of phase. One providing the positive swing, and one providing the negative swing. Which is interesting, because it seems this is exactly what the VTA is if you divide the machine right down the middle.
Which leads to my small experiment.
For this experiment I have the four coils, top coils separated from bottom coils with a 3 mm gap. Magnets are present. And two power coils that I'm directly pulsing (pulse, not square wave) and observing the open coil emf on all the four output coils.
The idea was to see how the coils are responding to the power coils, and to try to get an idea of how the flux is moving in the overall system. The VTA schematic shows the power coils opposing.
Which I thought strange because Walt Rosenthal mentioned they were configured in a push-pull fashion. Here, at about 50 seconds into the video.
So, for the experiment, while observing the open end coil voltages, I tried both opposing and push-pull orientations. Again, with a pulse, not a square wave this time.
This is an example of the output on one coil.
Blue is the input signal, it's 50% duty cycle. Green is the voltage over the coil. We can see that there is a small dip during the on time of the power coils, and then a large positive when the power coils are turned off. If we assume this voltage polarity to be "positive", and test all the coils for the same (not inverted), and use the right hand rule, we get what is in the next picture.
On the left is with the power coils opposing. Assuming "positive polarity" of the coil wave forms, the right hand rule would show all coils would want to have flux outward at the same time. On the right side is with the push-pull configuration. We can see that the POC set on the right side flipped to where the flux would be inward, while the left side is still outward. Again, this is just a pulse, not a square wave. With a square wave push pull configuration we would see the picture of the right alternate, outward/inward -> inward/outward. I flipped the magnets polarity, from both N facing up to both S facing up, but saw no difference. I'm guessing I will once I get appropriate power coils and feedback coils.
Anyway, that is it for now. My wire was delivered today, but I still need to source core material (used microwaves) and design/print the formers for the power coils. I'm sure it will be several days before I get everything done and start experimenting again. Back with more soon!
Thanks!
FringeIdeas posted this 13 August 2025
Something interesting, in regards to diodes in the VTA.
I was watching Energy from the vacuum part 30, Floyd Sweet Memories. Moreso for entertainment. John Bedini is talking about Floyd Sweet using the TVs for viewing fields of the magnets, then he moves on to telling how Tom Bearden gave the name Vacuum Triode. He mentions it wasn't the VTA in the beginning, it was just the Sweet Device, that God gave Floyd Sweet. I think the "God gave him" part might have triggered a memory or something, because then the interesting part..
Quoting Bedini, as he is remembering speaking to Floyd Sweet.
You know I said well, well God told me too, and so I said, well what's the circuit? I said to him one night, and he drew the circuit and he put this diode in there, from one coil to the next coil, and he says.. God told me to do that.
And then he changes the subject to Floyd Sweet maybe not being Floyd Sweet, then changes back to previous discussion about the toaster oven. Here is the video, start at about 44 minutes in.
Very little information said there, and he didn't really draw anything on the chalk board while he was talking. But it's very interesting to hear about a diode being placed between two coils.
FringeIdeas posted this 08 September 2025
Amazing, it's been over a month already.
So, just a build update. My free time has been severely limited lately. And it took some time to source a few microwaves with the same spec transformers, cut them, glue, etc, and get the wire to wind the coils. And winding 2000 turns of 0.4 is no joke. But here is a quick pic of the finished product. The cores look like Tetris and a rubik's cube had a child. But they should do the job.
I left a bit of core on the end to hold another thin former. But maybe not needed, I might end up trimming the cores. If I need a small coil wound in that area I think I can put it on top of the drive coil.
The cores I did not make big enough to reach and cover the sides of the magnets. I tried to duplicate what I saw in Floyd Sweets pictures. So they extend up/down past the power coils and stop short a couple mm before coming flush with the magnets.
I had a couple questions I wanted to ask, but I neglected to write them down.
I do have a few experiments in mind. For example, if the power coil pairs (poc pairs) operate in an alternate fashion, for example one set fires then the next, does the "pinch zone" extend past the other power coil pair. And would this be the reason of needing to criss cross wires. The pinch zone, and the idea of gating the region of space into an "off" position, comes from this video.
Anyway, I can start experimenting now, time permitting. Start playing around with a few different wire configurations, and see if I can get this thing the breathe.
Chris, I didn't read over your post suggesting to start calculating the wire turns and voltages, etc. It's on the to-do list, I just wanted to get some wire and cores together first and see how these fields interact with each other. There is an ungodly amount of right-hand rule variations going on here. 😅
Hopefully back soon with some experimental data.
Chris posted this 08 September 2025
Hey Marcel,
Beautiful work My Friend! Very nice build!
Floyd Sweet used the Distributed Capacitance of the Excitation or Drive Coils as the RLC Resonator:
For this machine to work, some means would have to be formulated to instantaneously vary the frequency to match varying load impedances. Surely a most challenging task. First, the capacitor should be removed and the inductor designed with sufficient distributed capacitance to prove integral LC. Then calculate what frequency will resonate the R.C.L. network.
Ref: Magnetic Resonance by Floyd Sparky Sweet
Adjusting the RLC Circuit with a Capacitor I am sure is within the rules of engagement here. I am sure you are seeing the point I am trying to make here.
EDIT: Please note, the Natural Magnetic Resonance Frequency, Antenna Resonance, can be changed using extra Capacitance or Inductance or both.
Remembering, you have: E x 1.0 in this experiment, or: B x V + -B x -V = 2 B x V, so using one of the B x V's as a RLC Circuit  maybe bought to this same resonance using a Capacitor to change the natural operating frequency also, I mean, truly, we would be more than happy with E x 0.5 anyway wouldn't we:
If the directions of the two signals are such that opposite H-fields cancel and E-fields add, an apparently steady E-field will be created. The energy density of the fields remain as calculated above, but the value of the E-field will double from E/2 to E. It is a simple matter using the equations E/H = √με and C = 1/√με for a team wave to get rid of H and C and so convert the first equation into the well known equation for energy density in the so-called electrostatic field:
My Friend, you have taken the bull by the horns, and turned your path forward, in this world, to a path that you control, and not be led by very low intelligence politicians that could not organize a root in a brothel!
I commend you for your leadership Marcel! Thank You My Friend!
FringeIdeas posted this 05 November 2025
Hello!
So a little experimenting to show, and some thoughts. I feel lately I've been back-stepping, maybe just confusing myself a bit. And sorry I've been amazingly busy with work, and have had almost zero personal time. Yesterday and this morning I've managed to steal a few minutes from work time, to do a couple experiments. A couple of thoughts first. And disclaimer: I have no idea what I'm doing.
Purpose of the FB coils.
I was on the fence in regards to whether the FB coils were being used to induce a voltage in one of the P1/P2 coils, or if FB was taking from the P1/P2 coils and using that to power the EX1/2 coils. ERTW had mentioned something similar here
I would say I'm 99% leaning towards the FB coils operating in the exact same manner as the input coil on Chris's non-inductive experiments setup. Mostly because if the FB coils did not operate this way, Chris would not have spent so much time and effort focusing attention on that particular setup. 😀 And although the voltage on the FB coils would be rather high, we know from experiments that the bucking between the POC coils kills the voltage, so we do need this to be quite high.
Also, when the coils buck we end up with a pinch zone, or scaler north, shooting out the side, inducing a voltage in the EX1/2 coil. I'm guessing EX1 was actually crisscrossed to FB2, and EX2 over to FB1, so as to oscillate/alternate the FB(input) coils. One set regaging while the other is discharging.
Use of a diode.
I'm still 50/50 on this. Again, I think there has been a lot of attention on using a diode, or diodes, and probably for good reason. And though there might be another function going on here that in the end does the same as a diode, I'm thinking at least one per POC pair is necessary. It also seems that if no diode was present that we could not have that water gravity pump type action in the coils.
However, a new consideration has presented itself. Sweet has in the schematic that the coils in P1 and P2 crisscross. So if I was to take P1/POC1 (bottom) over to P2/POC2 (top), and have a diode on P1/POC1, the issue arises that I'm only allowed to apply the direction of current into P2/POC2 such that the resulting magnetic field is pointed down (inward). This is the regauge period of P2 so I would think we would want the top coil magnetic field either pointing up, or to be off. However, in the standard POC setup/experiment, we do see that the opposite POC does start to ramp up during the regauge period. One related concern is that this would oppose the input during the regauge period. But it's possible that the P1 coils, in a state of discharge/bucking, are creating this pinch zone that Chris talks about in his video. And maybe this pinch zone from the P1 coils is creating a no fly zone between the P2 coils, giving the input coil a chance to ramp up without opposition. Without reflected impedance from POC2. I tend to want to think about Floyd Sweets' quiet and noisy zones of space.
Pinch zone picture taken from this video, then rotated 90' to represent the set of P coils that is in a discharging (output) state.
My recent experiments.
I'm only messing with the four P coils currently. No magnets, no excitation coils. Just square pulsing (not wave) the FB (input) coils. I have diodes on the POC1 coils, and they are configured so that the input coil will oppose POC2 (opposite coil) and the diode stop POC1 (wound with input) from interacting until the pulse is turned off. POC1 is fed up into the other P coils POC2, so that the resulting magnetic field of P2/POC2 will be inward(down). Duty cycle is 50% simply because I have not had the time to set up a mosfet driver on the second channel of my function generator. Laborious task, I know. Frequency is somewhere around 2.5 KHz.
What I want to show from the video is simply the more lights I add in series, the more the output goes up and the input goes down. Far away from above unity, and the effects are not huge, but they should be considered.
So, that is where I'm at now. Still really fighting for bench time while trying not to confuse myself by overthinking/theorizing too much. I need to mess around enough to decide if I want the diodes in there or not, and in which manner I'm feeding a P1 coil into the P2 coils. But so far this setup is making some sense, as it seems to maintain that oscillation idea. Hopefully work slows down soon and I can start devoting some more time to this.
Thanks!
Chris posted this 06 November 2025
Hey Marcel,
My Friend, you are absolutely spot on on everything!
I have worked with a lot of different people over the years, you are definitely in the top ten best researchers I have worked with! You are very good at studding, putting the dots together and making sense of the topic and then making this work on the bench! Well done My Friend!
We have covered before, but again may be somewhat useful:
There's a fundamental relationship between the number of turns on a coil (N), the current flowing through them (I), and the core reluctance ($\mathcal{R}$) that determines the magnetic field, or magnetic flux density (B), inside the core. This is the core principle behind the design of electromagnets and inductors.
🧲 Relationship Between Parameters
The relationship is governed by the magnetic circuit equivalent of Ohm's Law, often called Hopkinson's Law:
$$\mathcal{F} = \Phi \mathcal{R}$$
  • $\mathcal{F}$ is the Magnetomotive Force (MMF), the driving force for magnetic flux.
  • $\Phi$ is the Magnetic Flux (in Webers, Wb), which is the total "gated" magnetic field.
  • $\mathcal{R}$ is the Magnetic Reluctance (in Ampere-turns per Weber, At/Wb), which represents the opposition to the magnetic flux.
1. Magnetomotive Force ($\mathcal{F}$)
The MMF is directly determined by the coil design and current:
$$\mathcal{F} = N I$$
($N$ is the number of turns, $I$ is the current in Amperes, and $\mathcal{F}$ is in Ampere-turns, At).
2. Magnetic Flux ($\Phi$) and Flux Density ($B$)
The total magnetic flux ($\Phi$) is the magnetic flux density ($B$) multiplied by the core's cross-sectional area ($A$):
$$\Phi = B A$$
($B$ is in Tesla, T, or Weber per square meter ($\text{Wb}/\text{m}^2$). 800 Gauss = 0.08 Tesla).
3. Magnetic Reluctance ($\mathcal{R}$)
The reluctance of a uniform magnetic path (like a core) is determined by its geometry and material:
$$\mathcal{R} = \frac{l}{\mu A} = \frac{l}{\mu_r \mu_0 A}$$
  • $l$ is the mean length of the magnetic path (m).
  • $A$ is the cross-sectional area ($\text{m}^2$).
  • $\mu$ is the absolute permeability of the core material (H/m).
  • $\mu_0$ is the permeability of free space ($\approx 4\pi \times 10^{-7} \text{H/m}$).
  • $\mu_r$ is the relative permeability of the core material (dimensionless). Silicon steel has a high $\mu_r$ (typically in the thousands, but it varies non-linearly with $B$).
📐 Coil Design Calculation Example
To "gate" (or establish) a magnetic flux density of 800 Gauss ($0.08 \text{ T}$) in your laminated Silicon Steel core, you can combine the equations above to solve for the required Ampere-Turns ($NI$).
$$\mathcal{F} = \Phi \mathcal{R}$$ $$N I = (B A) \left(\frac{l}{\mu_r \mu_0 A}\right)$$
Notice that the cross-sectional area ($A$) cancels out in the ideal case of a closed core with a uniform field:
$$N I = \frac{B l}{\mu_r \mu_0}$$
Step-by-Step Calculation
1. Define Target Flux Density ($B$):
$$B = 800 \text{ Gauss} = \mathbf{0.08} \text{ Tesla (T)}$$
2. Determine Core Geometry:
  • Cross-Sectional Area ($A$): $10 \text{ cm} \times 4 \text{ cm} = 40 \text{ cm}^2 = \mathbf{0.004} \text{ m}^2$. (This is needed if the $A$ didn't cancel out, or for a more rigorous calculation, or for the core loss calculation).
  • Mean Magnetic Path Length ($l$): This requires knowing the overall shape of the laminated core (e.g., E-core, toroid, simple rectangle). You must estimate this length (e.g., $l$ could be $\approx 2 \times (10 \text{ cm} + 4 \text{ cm}) = 28 \text{ cm}$ for a simple rectangular loop, or more depending on the geometry of the winding leg). Let's assume $l = 0.3 \text{ m}$ for this example.
3. Determine Relative Permeability ($\mu_r$):
  • For Silicon Steel, $\mu_r$ is highly variable and non-linear. You need the **magnetization curve (B-H curve)** for the specific grade of laminated silicon steel at $B=0.08 \text{ T}$.
  • As an approximation, let's assume a typical high $\mu_r$ value of $\mu_r \approx 4000$ at this flux density.
4. Calculate Required Ampere-Turns ($NI$):
Use $\mu_0 = 4\pi \times 10^{-7} \text{ H/m}$.
$$N I = \frac{0.08 \text{ T} \times 0.3 \text{ m}}{4000 \times (4\pi \times 10^{-7} \text{ H/m})}$$ $$N I \approx \frac{0.024}{0.0050265} \approx \mathbf{4.77} \text{ Ampere-Turns (At)}$$
5. Design the Coil
Once you have the required $NI$, you can choose a suitable combination of turns ($N$) and current ($I$):
  • Option 1 (Few turns, High current): $N=10$ turns, $I = 4.77/10 \approx \mathbf{0.477} \text{ A}$.
  • Option 2 (Many turns, Low current): $N=50$ turns, $I = 4.77/50 \approx \mathbf{0.095} \text{ A}$.
Your choice will depend on:
  1. Available power supply voltage and current.
  2. Maximum allowable coil resistance (to limit power loss and heating, $P = I^2 R$).
  3. Winding space available on the core.
Key Considerations
  • Non-Linearity: The biggest challenge is that **$\mu_r$ is not constant**; it changes with $B$. For accurate design, you must use the B-H curve for your material to find the **Magnetic Field Strength ($H$)** corresponding to your target $B=0.08 \text{ T}$. Then, the required MMF is $\mathcal{F} = H l$, where $H$ is in $\text{At/m}$. $$\mathbf{N I = H l}$$
  • Air Gaps: If there is any air gap in the core assembly, its reluctance ($\mathcal{R}_{\text{air}} = l_{\text{air}} / (\mu_0 A)$) will be much higher than the core's reluctance and will **dominate the total required MMF**. A rigorous design must include the reluctance of both the steel and the air gap(s).
  • Gating: Your term "gating" often implies a control mechanism, possibly involving **saturation** (where $\mu_r$ drops sharply) or a **flux-gate** configuration, which would require a different, more complex analysis involving two or more windings. The calculation above provides the basic $NI$ to achieve the desired $B$.
I want to ask you one thing at the moment, please keep this experiment as is, don't change it, and keep coming back to this experiment, make sure you don't change anything! It may be a week, or a month, maybe even six months, but you will see why I said this later on.
The effect: "Amplitude Increase", please study this, its very important as we have been through a few times. This is linked directly to the VTA Internal Working and how and what's required to move forward! "Amplitude Increase" is linked to NI, the Ampere Turns and the statement by Walt Rosenthal:
You should be very proud of yourself, of all the researchers I have seen, and the ones I haven't, I am going to say, you are the closest to having the VTA Replication completed, than any other researcher, ever!
The fact that we, here at above unity dot com, can work together, towards a common goal, without the negative, silly, jealous, bickering, that floods the other forums, means we have another Huge Feather in our cap, an advantage that they could never appreciate because of their Neanderthal Brain power, and approach. Here we show the proof, that Humanity can be better, if given the chance, and not infiltrated by Neanderthal Shills!
Well Done My Friend!
FringeIdeas posted this 06 November 2025
Chris, very nice compliments, thank you!
I would counter with, it's nice to have the dots and nudges to work with in the first place, so thank you again.
So I'll go ahead and keep this setup as is. I'll probably keep playing around a little but I won't make any big changes. Focus will be on this amplitude increase effect, and I'll take some time to brush up on my engineering math.
Again, much appreciated!
ERTW posted this 12 November 2025
this is great. i really wanted to say i appreciate your thought process that goes along with the videos. i have lots of questions/comments but i'm going to wait until i have my own experiments done so i can talk from experience. but just wanted to you to know your posts are appreciated.
FringeIdeas posted this 25 December 2025
Hey Chris, and everyone.
First I hope everyone is enjoying the holidays. Good change to connect with family and friends. I asked Santa for more bench time in 2026, let's see if he delivers. 😁
Chris, I've been trying to find time to play with math lately. Just to refamiliarise myself with how to throw around the Greek letters, and I've got a question. This is probably one of those moments where I'm stepping over the obvious, and I'm sorry, but I've internet searched quite a bit and I can't figure this out. In this pic you shared previously on this thread for me.
I wanted to kind of reverse solve a few variables, to see what kind of magnetic flux density he was working with, electron paramagnetic resonance being talked about now, things like that. But I cannot for the life of me figure out where the 10^8 is coming from up top.
N = (Ex10/ 4.44  BAf) x 1.11
The rest makes sense, from The Space-Flux Coupled Alternator
In passing it's interesting, because unless I'm mistaken, this formula is usually used to calculate the turns on the primary so that we are not saturating the core. So, it's kind of implying the existence of a core. Could be air core sure, but still interesting.
Anyway, the standard formula if I'm not mistaken, up top there, is just Vrms. So what is the 108?
Thanks! And again, 2026 and back to work is coming quick, I hope everyone is enjoying the holidays. Stay safe!
Drasko posted this 25 December 2025
Hey Marcel,
Im sure Chris will have a better explanation, but just trying to help and looking it up on google AI this is what the results show.
This formula is used in electrical engineering to calculate the
number of turns ( 𝑁 ) required for a transformer winding.
The equation N=E×10^8/4.44⋅B⋅A⋅f  is a rearranged version of the standard Transformer EMF Equation, specifically adjusted for units where magnetic flux is measured in Lines (Gauss) rather than Webers.
Key Components
  • 𝑁 (Number of Turns): The total count of wire loops in the primary or secondary winding.
  • 𝐸 (Voltage): The RMS induced electromotive force (EMF) in volts.
  • 10^8 to the eighth power 10^8 (Conversion Factor): This factor is used when the magnetic flux density ( 𝐵 ) is in Gauss (or lines per square inch) and area ( 𝐴 ) is in square inches. If using standard SI units (Tesla and square meters), this factor is removed.
  • 4.44 (Constant): A mathematical constant derived from 2π2the fraction with numerator 2 pi and denominator the square root of 2 end-root end-fraction 2𝜋2√ , which accounts for the sinusoidal nature of AC power and the conversion from peak to RMS values.
  • 𝐵 (Magnetic Flux Density): The maximum flux density the transformer core can handle before saturation.
  • 𝐴 (Core Area): The cross-sectional area of the iron core.
  • 𝑓 (Frequency): The frequency of the AC supply, typically measured in Hertz (Hz).
Hope this helps, Happy Holidays and all the best
Drasko.
  • Plasmonic
Chris posted this 26 December 2025
Yes, Drasko is correct, the number 108 relates to the conversion between Lines of Force (Maxwells) and Webers
$$1\text{ Weber} = 10^8\text{ Maxwells (Lines)}$$
I always forget this, so I added it into my Calculator, in the Code Comments.
Good question and good experiment!
Best Wishes and Happy New Year,
  • Drasko
  • Plasmonic
FringeIdeas posted this 26 December 2025
Ah ok! Drasko, Chris, thank you.
That makes sense of it. I'll make my own notes to remember.
Another quick question then. Chris, your members calculator. I have an older version, and I can find older version links. But is there one link that always points towards any updated versions?
Thanks again,
Chris posted this 27 December 2025
Hey Marcel,
There are a few Versions here: Aboveunity.com Member Calculator
I do have another version, one that I played with after the class EScience.cs started and one before, I am not sure what versions, from memory, are up on the Thread, but the math is basically the same.
The newer Version, it has a lot of unfinished math and science in there and I dont want to put badly finished code.
FringeIdeas posted this 27 December 2025
Ok, I'll have a look. Much appreciated!
