Hello from canada
  • 664 Views
  • Last Post 05 September 2023
Radi8 posted this 03 September 2023
Hello
Hello from Canada!
I am a software developer by trade but have been starting to learn some electronics skills recently. I have designed some simple circuit boards to make a DIY power wheels for my daughter, and a few other esp8266 projects. I am also in the process of building an electric car. I have a donor car and a tesla LDU, and am waiting on a board from openinverter. By any measure I am very much an amatuer in the electronics realm, but I am trying to learn what I can because it interests me and because I've always wanted to build am EV.
I have also been following the topic of "overunity" for almost 2 decades and have seen many incredible videos where "impossible" devices were shown, only to later disappear, or be explained away as measurement errors etc on overunity.com.
My conclusion thus far is that either this entire realm is simply the ravings of mad men, or there is a massive global conspiracy. The simplest explanation usually being the correct one, I have to assume the former is the reality, or at least give it a probability of 99.99%. That said,... i try to keep an open mind and having seen so many videos over the years that looked so credible (to me anyways, which doesnt say much), the probability of the latter isnt 0.... and thus I cant help from poking around to see if there is something out there with enough credibility, momentum and confirmed replications to justify the time investment required to learn the neccessary skills needed to try replicate myself. Putting on my tinfoil hat and continuing to explore the 0.01% scenario,... if it were true, someone would have had to have succeeded by now on OU.com, therefore OU.com must be part of the misinformation system,. Which brings me here.
I've read your build guide a few times and a number of your other videos on POCs etc,. And it's great that you have tried to lay out a learning path of sorts,. But before I invest alot of time going down that road,. I would really like to have some confidence that it leads to a self running device.
So all of that said, is there a detailed circuit diagram with prescriptive build instructions for a proven and replicated looped device you can provide and answer questions for?
Cheers -Radi8
Chris posted this 03 September 2023
Hello and welcome Radi8,
Yes: Non-Inductive Coil Experiment
Enjoy, understanding this and following our work will provide success.
Some non-genuine ex-members have tried to fake results, but majority are successful! There are a lot of real scum suckers out there!
Proof, and the Dumb Dumb Club cant see the Forest for the Trees! When too many Idiots flood the Forums, they make a mockery of the Truth! Right here, it's been here for nearly a Decade, you can SEE The Truth:
Cite: Master Shi Heng Yi
Tinman was the first:
Lighting up the Darkness!!!
Radi8 posted this 04 September 2023
Thanks!
I read through some of the links and I will be very honest, I am really struggling here as I don't have a physics background.
Could you tell me if I am understanding this roughly correctly?
(2) Non-Inductive Coil Experiment - Video One - YouTube
You have 3 coils:
  • 1 primary (L1) which is an alternating DC pulse via an H bridge.
  • 2 secondaries (L2,L3),
    • L2 and L3 are configured to partially overlap themselves such that 2/3 of their total weight is effectively bucking, cancelling out magnetically, leaving only 1/3 of the L2/L3 coil (half of L2) available to receive EMF from the L1 primary.
You place a capacitor across the secondary with lower inductance (L3), and then adjust the size of the C1 capacitor, the L1, L2 and L3 length and the L1 timing such that:
  • L3 inductance is lower than L2
  • L2 and L3 are 180 degrees out of phase (creating a “standing wave” or “scalar wave&rdquo
  • L3 is in resonance
  • L2 has a reasonably high voltage
Then somehow (for reasons I am trying hard to understand and are way over my head), while L2 and L3 magnetic fields cancel out, their electric fields are added, and as a result L2 begins generating excess current (which is somehow higher than L3's current despite L2 and L3 effectively being the same circuit)?
I have many questions:
  1. What is the reason the secondary is only configured such that 2/3 of its weight is bucking?  My assumption is that 1/3 must not buck so that the secondary can receive the EMF from the primary.  But if that’s the only reason, why couldn’t the secondary couldn’t just be pulsed directly? (Apologies in advance if this is a particularly dumb question)
  2. What is the difference between L2 and L3 being 180 degrees out of phase, and them being in resonance?
  3. It seems like the load is always powered by L2. In other variations and references it sounded like the load should only be connected to L2 when L1 is off.  Why are there no diodes in this circuit?
  4. Is this bucking phenomenon the only secret sauce in use?  Some of the patents and other articles referenced seemed to refer to magnetic saturation, or magnetic delays via the use of air gaps, or non-inductive barriers etc in the core? Do those play a factor here?
  5. How do you take the power from the circuit and loop it without disrupting the system? Placing A capacitor at BL1?
  6. Could you point me to the circuit diagram for "Our Flashlight"? I wasn't able to find it.
Chris posted this 05 September 2023
Hello Radi8,
Please study the entire thread, all 11 videos and all data in the thread, instead of just the first video, it will make sense once you do the study! Its very easy, but one needs to put a little effort in initially.
There is about a month's study in the thread I have given!
The Video description contains the links you asked for, and I believe also in the comments on the video, please study, I am not going to keep repeating myself all the time for people. Others need to put some work in.
Happy to help when you have done the study.
Radi8 posted this 05 September 2023
Understood. It will take me quite a while to go through it so I will likely not post much for a while. In the meantime please dont delete my account for inactivity.
Hey Radi8,
You're safe here, if you stay on track, I only Delete Time Wasters and Trolls.
We have many very good, dedicated people here, but I have Deleted a lot of Trolls also! On your ride, you will no doubt see that.
I am straight up and honest, this works, but you have to do some initial work to understand it. Its very easy and very cheap, but everyone needs to give it their best shot initially, the study must be put in, then the rest falls into place!
Many have shown, what I am sharing, Works:
Beware, there are a lot of Dumb Ass Idiot's, Real Time Wasters out there!
They have tried very hard to Debunk me, but they ALWAYS FAIL!!! They are just too damn Dumb to argue with the evidence! It works exactly as I have shared! What I have shared, it is only the beginning! Tomorrow comes very fast! The Trolls are dropping like Flies now!
