Homer Simpson Scientists in the Community
  • 833 Views
  • Last Post 21 September 2023
Chris posted this 22 August 2023
I see a Huge number of posts on other forums with total Homer Simpson Science, I would love to give you some examples, but the Homer Simpson Scientists would probably sue me! Because they know their High Tech, Highly Educated, Homer Simpson Science is total nonsense!
They try to baffle others with total Garbage and they have been doing it for decades! Across all the Forums!
They group together and attack anyone that is getting close! I used to call them the Goon Squad, and they are mostly still together, but only with a few new members!
Their way of thinking is antiquated and outdated:
We have completed Science's holes and have working Machines:
  • Fact: We have given you the answers to Free Energy Machines with lots of Independent Replications!
  • Fact: The answer is extremely Simple once you understand the Simple Science!
  • Fact: Its very cheap to build a Free Energy Machine!
To many damn Homer Simpson Scientists in the community! Total Rubbish Science! From Brain Dead Scientists that cant do science unless they read it from a Textbook! Non-Thinkers!
You have a very easy opportunity to change the path your life is on! Imagine, Free Energy! Imagine the possibilities! Imagine Plugging In and not worrying about the Bill! Imagine the new Science to come once we all gain this new, very Simple, very easy Science!
When, Energy becomes Free Globally, we will see a change like never before! Its coming, they have tried to stop us, and been relatively successful, but their time is running out, because they simply can not stop Progress!
Free Energy Machines are Cheap and very Simple, they have one very simple Rule, Asymmetry, because Symmetry can not ever be Above Unity, because Input equals Output minus Losses, with an Asymmetrical System, which I have given to you all, you dont see this Rule apply, because we do not have Symmetry, its an Open System! Your Input is not tied to your Output, your Output depends entirely on the Machine Design and Specification! Your Input is ONLY an Excitation for the Output! If you like, a Frequency Regulation, or a Catalyst for Machine Operating Frequency!
The Answers you seek are right here: Builders Guide to Aboveunity Machines
Very Simple and very Cheap to make your Future Independent, become free of the Induced Slavery they hold you to by making you dependent on their Fake System!
Bird_eye posted this 23 August 2023
Hi Chris and everybody,
I am true researcher and following this community for long period, I was usually inactive due to life conditions but sometimes active,
The image like science fiction you have shared above was exist before and will be exist in future,
I believe if this image already streamed to someone’s mind that mean it already found chance to be exist,
I would like just to add,
We ask from environment to perform some work on behalf of us, and energies our needs, in other words  we are asking if our machine can be energy absorber from environment to obtain cold energy, as manifesting reactive power itself,
What are you thinking ? Are we really deserve this? While we are polluting water sources, ground and other life forms of nature, just as the idea of use and throw out, as satisfying of our self-egos conversely trying to understand what is the real self-sustain system and what its deeper meaning as well.
This is not about the having working machine or independency of matter world,
Look at trees what they are doing and how gives service for others? Are we really able to give service for others? Are we able to give service for our loved ones against our ego while commanding on us?
People who really desire to achieve this end is required both, matter world and spiritual world independency together, otherwise never able to give service for others .
So, by having physical result also awareness is necessary about our ego.
This is the path who want to walk sincerely  and aware of what really stand in our hearth as idol we worship for,
Chris posted this 23 August 2023
Hello Bird_Eye,
Thanks for posting!
Regarding your comments:
The Electric "Generator" is currently NOT understood by Science! Todays Science Establishment can not explain 'where' the Electrical Energy comes from in the Electric "Generator", but I can!
The Magnetic Field is an Inverse Square Force Field. The Science Establishment tells you the Magnetic Field can NOT do 'Work', but that is total lies!
The Magnetic Field comes from Sub Atomic Particles, so it only makes sense, that it also Reacts with Sub Atomic Particles, and it does! We know from the very same Science Establishment that The Magnetic Field does Contain and Direct and Accelerate Sub Atomic Particles, from machines like the LHD:
The Electric "Generator" is the same basic process!
The Electric "Generators" Stator Coils are filled with Sub Atomic Particles, Protons, Neutrons and Electrons, and it just so happens, that Voltage is defined as 6.241509 × 1018 e, where e is defined as Elementary Charge, which is Electrons and any other Sub Atomic Particles that hold a Charge! Also One Ampere of Current is defined as 6.241509 × 1018 e, Charges, moving past point P1 in one Second!
So we have a situation here, where the Electric "Generator" is actually very easy to explain, The Science Establishment is simply holding you all back by playing the Dumb Card on you all, and making up Lies!
The Magnetic Field, which is an artifact, created by Moving Charge, works on Stationary Charge, to Accelerate it at Velocity, down your Insulated Copper Conductor and through your Load, at a rate, where One Ampere of Current is 6.241509 × 1018 e, Elementary Charges, moving past point P1 in one Second!
There is always more than One Magnetic Field in the Electric Generator, and the Magnetic Field of the Stator Coil, being the Secondary Magnetic Field, your Primary Magnetic Field being that of the Rotor, the Spinning, or Moving Magnetic Field, the Secondary Magnetic Field is the Field that creates the Drag in the "Generator"! All of this is very easy to prove on the bench with a few minutes study!
So we actually are building a Charge Pump! Electromagnetic Sub Atomic Particles are stripped away from the Outer Orbitals and Accelerated down the Wire! We Pump Charge.
We have a Direct Connection to Quantum Realm here! The Magnetic Field is a Tool we can use to manipulate the Quantum! We do it all the time!
NOTE: The Electric "Generator" is designed to be, and is Completely Symmetrical! This means: Input = Output - Losses, in other words, an Always Below Unity System! Because of the Symmetry!
Is this a rhetorical Question?
Honestly, why do we do these things? Would it be because we have no other options? I think the Answers here are actually very simple, don't you?
This part:
Honestly, I think you have a lot to think about here. The current situation in the world, it is dire! We have too many damned evil people aiming to enslave everyone else, and treat them as cattle! I am sure you can see this already? If not, perhaps a read of the News today may help you see this, watch some of the Davos Interviews, that may help!
We have three groups of Human Beings currently:
  1. Fat Dumb and Silly, happy to be Slaves,
  2. People that are sick of how we are being treated, sick of the establishment, and looking for alternatives,
  3. and the small group trying to lead others, trying to be the Cattle Herders and Slaughterers.
We no doubt will see a Break Away Group of Humans, soon, if things don't change for the better, and the Break Away Group of Humans, will become the Race of Humans we all were meant to be! Free and Independent, a Space faring Race, that lives like the Star Trek characters did.
The rest, will be Slaves, and when they become useless to their Masters, they will be Slaughtered!
The very reason you all are being lied to and held back, is because they want you all to become Slaves! They pay Dumb Asses to lie and cheat you out of the truth, the same truth I share with you here! That's why we have so many Trolls come here and be Idiots! That's why I had to lock New Account Sign Ups! That's why I have had to remove so many Trolls from My Forum!
All of you have a Choice!
Either become Slaves happily, or NOT!
I know what I want, and I am going to fight them all the way! I am Free and they have no Power over me! Maybe you can call this a Spiritual Awakening?
We still have too many damn Homer Simpson Scientists in the Community! Dumb asses that have no idea on half of what I just shared! And, they have been active researchers in the community for decades, this speaks volumes to what their actual goals are!
Making the Electric "Generator" Asymmetrical is your Answer, I have given all of these Secrets in my Pages, you all have the answers! Its up to you to implement Freedom!
Yes, the Homer Simpson Science club are idiots and want to keep you all idiots!
Chris posted this 26 August 2023
Yup, Beyond Stupidity.orgasim is full of Banned and Discredited AboveUnity.com Ex-Members! You know, the Trolls, Cheats, Hoaxers, Morons, Spoof's, Liar's, Idiots, that I weeded out and got rid of! You know, Real Brain Dead Drongo's!!! Their work is 99% Rubbish, Bull Shit and Lies! Only 1% is valuable, but its all old and already known by 99% of the community! Nothing of Value over there! That's for sure!
Jagau's recent thread, its Total Non-Sense and is NOT Above Unity! Its Non-Sense! But they try very Hard, Propaganda Pushers! Jagau should be ashamed of himself!
While they have proven themselves to be completely useless and Brain Dead, however, they are not the only bunch of Homer Simpson Scientists, there are many more out there!
There are a LOT of Self Proclaimed Guru's that cant navigate their way out of a Paper Bag, let alone work on the edge of the Science Frontier, discovering New Science!!
OMG no wonder the Energy Industry is well known for Hoaxers and Scammers, they all are in one way or another!
Chris posted this 10 September 2023
The more I see from people on the other forums, the more I realise, they are completely Clueless!
They are Idiots!
They have no idea whatsoever about this very simple and very easily provable concept! Electromagnetic Induction stumps these morons! Charge Separation, ignored by Club Dumb Dumb! Club Dumb Dumb, they are never going to achieve anything! Ever! They are dumb asses focusing on copious amounts of Nothingness!
Evidence, Proof, and Independent Replication is the only Path Forward!
The TRUTH is ONLY found Here! www.aboveunity.com!!! The Proof:
Proof, and the Dumb Dumb Club cant see the Forest for the Trees! When too many Idiots flood the Forums, they make a mockery of the Truth! Right here, it's been here for nearly a Decade, you can SEE The Truth:
Cite: Master Shi Heng Yi
Tinman was the first:
Lighting up the Darkness!!!
Fact is: Not many Researchers are Pragmatic! Most are irrational and illogical!!!
There is only One Truth!
The worlds dumbest people seem to congregate as Energy Researchers on the Other Forums! We regularly expose how Dumb they really are!!! Some are so Dumb, that every time they open their mouths, all that pours out is Dumb! No Idea Whatsoever!
Chris posted this 21 September 2023
There is Hope! There is always Hope!
We must be patient, but what Clif High says in this interview, I absolutely 100% agree with!
I have given you the Power System that can Power your Future while the System Collapses! All the knowledge you need is right here!
