IMPORTANT: Energy, For the Survival of the Race
  • 1.1K Views
  • Last Post 26 October 2020
Chris posted this 25 October 2020
This is really important! I don't want to scare anyone, but it is past time now! This is as important as Air, Water and Food for the Survival for your Families. We all need Power!
Other people really need to get onto this Technology before its too late!
In my Series: Chris's Non-Inductive Coil Experiment, I had shown the following image:
Why is this bit, the Ramp Up Phase, so Important?
I have shown straight wire, to indicate a Coil, and the Polarity of the Coil and how the Source of Energy Generation can be Asymmetrical:
Ref: The Future is now, Energy, Space, its here now
The above Image is the same as this image:
We have a very important configuration here, a Configuration that Science is completely missing and is generally oblivious to! An Asymmetrical Induction Machine!
What is the Process:
  1. Short Red Coil: Input Coil puts a Pulse into the Machine, a DC Low Duty Cycle Pulse, Frequency and Duty Cycle Specific.
  2. Long Red Coil: Input Brings the Voltage up on this coil and the Diode Conducts, a Current Flows, Changing in Time = Magnetic Field Changing in Time.
  3. Long Black Coil: Change of Current of Long Red Coil, induces a Voltage on Long Black Coil and the Diode Conducts, a Current Flows, Changing in Time = Magnetic Field Changing in Time, Assisting the Input.
The Rate of Change of Current = Change of Magnetic Field, at which the Long Red Coil and Long Black Coil determines the Voltage and then, therefore, the Current in the System. This all happens at the same relative time frame, relative to the Input Pulse and the Delay of the Diode Conduction.
Delayed Conduction occurs between the Input, Long Red and Long Black Coils.
The Input Coil must be off after the short Duty Cycle, you will see something like this:
This is important, you will see why when you build this very simple cheap machine! Basically, nearly all of your Input, can be sent back to the Source Power Supply, and sometimes more, the Input can go into a Negative Power Reading in some situations.
Think Simple!
What ever you do, don't over complicate this, that's when things don't work! Focus on the basic things, like the area I have shown, why this occurs and what can be done to improve this simple cheap machine!
Its not hard, it is easy, it is cheap, it requires you to think simple, and look at each Coil and Current in each Coil as a Force!
How do we lift Ton's of material, by off Setting the Weight, or Force of Gravity. We do the same here.
Floyd Sweet gave us two configurations:
Both work, both are basically the same, and the same basic ideas work with different Circuits. I gave you two separate Coils, because they are easier to grasp initially, thinking of each Magnetic Field with each Coil.
The source of energy is unlimited, the virtual vacuum of space itself structured by a
motional electromagnetic field
is the powerhouse.
Ref: Floyd Sweet - Nothing is Something
Remember, Current through Turns is a Magnetic Field! Change of Current, Change of Magnetic Field, or a Motional Electromagnetic Field, using Asymmetry, the Generator Shaft Torque can be entirely negated! That's why Figuera said this:
The voltage from the total current of the current dynamos is the sum of partial induced currents born in each one of the turns of the induced. Therefore it matters little to these induced currents if they were obtained by the turning of the induced, or by the variation of the magnetic flux that runs through them; but in the first case, a greater source of mechanical work than obtained electricity is required, and in the second case,
the force necessary to achieve the variation of flux is so insignificant that it can be derived without any inconvenience,
from the one supplied by the machine. Until the present no machine based on this principle has been applied yet to the production of large electrical currents, and which among other advantages, has suppressed any necessity for motion and therefore the force needed to produce it.
Ref: Clemente Figuera
Figuera had, 100 Years ago, offset the Magnetomotive Force, or Shaft Torque on the Dynamo, and found by offsetting the Magnetomotive Force, very little force to Drive his Coils! Again, he built an Asymmetrical Transformer!
This technology can power your House, for Free! What I have shown is the very start, basic for all to follow! Humanity will not survive without this Technology in the coming years!
Chris posted this 26 October 2020
Hey CD, and All Readers,
Yes, The Input Coil can, under some circumstances, shown in the thread: The Input Coil, can become an Output Coil!
The Argand Diagram is important to understand:
Similarly, if we take a mass with a gravity field around it and we move the mass and create a mass current, a new field is also created. It is a different kind of gravity field with no source and no sink.
What is Floyd Sweets: "mass with a gravity field around it", yes that's right, it is the Electron.
Shown in the Four Quadrant Argand Diagram, we first of all Source Power ( Quadrant 1 ), and then Sink Power ( Quadrant 2 ).
Every time we have Positive Voltage and Negative Current, this is Power sent back to the Power Supply, we have covered this many times here on this forum, other forums do not cover this at all:
So you can see, in this example, a large portion of the Input, is sent back to the Power Source! How much?
This is why we must use Average or Mean Measurements on the Input!
The Average power used in this case is: 95.7mW
Total Power in the Input Coil is: 1.28 Watts.
An estimation: 1.28 - 0.0957 / 2 = 0.59215 Watts, is being sent back to the Input! 0.59215 + 0.0957 = 0.68785 is sent from the Power Source to the Input Coil.
NOTE: 0.68785 + 0.59215 = 1.28 Watts. Note RMS is counting Returned Power: 0.59215 Watts, as used power when it is NOT! This Power is "Negative Effective Power"! V x -I = -P.
Total used power is only 0.0957 Watts, Un-Recoverable Power, I2R Losses, because all the rest is being sent back to the Input, so we have Work done in the Coil for a fraction of the actual input: 0.0957 / 0.68785 = 0.13912917060405611688594897143273 = 13.913%.
86.09% of the Input Power is being Returned to the Source.
NOTE: 85 - 90% is approximately Transformer Efficiencies, not a Coincidence here! Electromagnetic Induction Standard and known efficiencies!
The other forums have no idea what so ever, of 99% of what we are talking about here!
Its early and I have not fully woken up, so please check my math and reasoning, I think its pretty close however...
The following Image is a very good example:
Notice the four Directions of the Two Axes:
  • +R
  • XC
  • -R
  • XL
-R is Negative Resistance, or the Reduction in Resistance, and other very nice Equations in there also!
I find the easiest way to think about this is Generator Mode and Powering Mode.
