JenkoRun's Research into Partnered Output Coils
  • 487 Views
  • Last Post 12 October 2023
JenkoRun posted this 12 October 2023
Evening all, I'm probably missing something obvious (it's late over here I'm tired) but what are the reasons for this?:
First Layer: 88 Turns.
Second Layer: 43 Turns.
In the 2018 post https://aboveunity.com/thread/how-to-build-your-own-above-unity-machine/?p=1 Chris said the coil ratio between L1/2/3 should be at least 1, this ratio is 88:43 and way off from the former, especially since the first is higher in turn count than second, I was under the impression each preceding coil needed to be lower in turn count as stated in the other post for the device to operate correctly, is that ultimately incorrect and just down to the inductance relationship between the 3 coils?
I also have 2 extra questions:
1, Is the model of the POC on the site image functional? I see most of the experimental POC's here have electrically isolated L2 and L3 coils where that one is series connected, what's the effect from the difference in the design?
2, Along with Magnetic Resonance, is it also a requirement for the MR frequency to match or be close to the circuits LCR resonance frequency, or is the latter unneeded compared to MR? And to add to that is the resonant frequency change caused by the connection of a load an issue to POC's power generation?
Cheers, I need to sleep now.
Chris posted this 12 October 2023
Hello JenkoRun,
I think maybe you should have done a little more Research before posting.
Your statements are way off:
No, this is not true! I have said many times in the past, that we see a Turns Ration of around 1 : 4, for example, Floyd Sweet used a Turns Ration of 1 : 5, Akula used similar ratios. Don Smith also used a 1 : 4 Ratio, which turns out to be 4 : 16 which is not even close to your statement here!
NOTE: if you divide both side of the Ratio by 4, you get 4 / 4 = 1, and 16 / 4 = 4, this means we get a 1 / 4 ratio, or a Quarter Wave Ratio. Very simple, very easy!
Yes, for the most part, although it is not necessarily complete, it is accurate and we have many experiments here that show you this, again if you choose to do some serious Research, you will see this!
No! This is not true and is misleading!
Magnetic Resonance is simply the Partnered Output Coils must have Equal and Opposite Magnetic Field, approximately Equal in Magnitude but Opposite in Phase, 180 Degrees Opposite. 120 Degrees is not Magnetic Resonance. It needs to be as close as possible to 180 Degrees!
Again, if you put in a good bit of Research, you will very quickly realise, Antenna Resonance is the same as Magnetic Resonance! The Frequency at which an Antenna Resonates can be predicted very easily!  Mathematically, the Length of the Antenna is used:
L = 468 / f
l = L / 2
  • L - the length of the total dipole antenna in feet (ft);
  • l - the length of the arm of the dipole antenna in feet (ft); and
  • f - the desired frequency.
Because the Antenna is a Wave Guide of sorts, it has a Resonant Frequency within the parameters of this Wave Guide structure, thus in any other Antenna of the same Design, another Anteaan becomes Resonant at the same Frequency!
It is true, the Dumb Asses on the other forums are a million miles away, because they are either:
  1. Too damn Dumb!
  2. Being paid to deliberately be misleading in this area!
Fact of the matter is, Don Smith was 100% Accurate in his statements, he told all of us, exactly how he did it:
Ref: Don Smith P.10 of 92
Club Dumb Dumb are lying to you all, they have Zero Idea, Zero Clue, and they are Fakers, Hoaxers, Liars and Bull Sh*t Artists, all trying to Control your direction!
You really need to do some solid Research on this topic. I will help you, if you are Genuine, because I have Banned many Trolls, many Fakers, many Hoaxers! Sometimes I make mistakes, and I am happy to discuss and negotiate a truce if I am wrong, but I am not putting up with Brainless Drongo's, Bought and Paid for Shills that want to lie to the World!
I will help all Genuine Researchers Succeed! My Track Record surely speaks for itself by now! 2015 I started doing this! Its now 2023, and I am still doing it! We have had Many Successes:
Proof, and the Dumb Dumb Club cant see the Forest for the Trees! When too many Idiots flood the Forums, they make a mockery of the Truth! Right here, it's been here for nearly a Decade, you can SEE The Truth:
Cite: Master Shi Heng Yi
Tinman was the first:
Lighting up the Darkness!!!
No one else, anywhere, ever has achieved what I have achieved! I have helped more people succeed than anyone else, ever! Period!
It is up to you to put a little bit of hard work in, to make this make sense!
P.S: I am sorry if this post comes across as aggressive, it is not meant that way, I am serious and I want people to see that, and, I am sure everyone is aware, I get a massive amount of attacks from Bought and Paid for Shills! I am the target of many troll attacks all the time.
