Lead Zinc Alloys
  • 834 Views
  • Last Post 13 December 2023
Nano posted this 01 April 2022
During my research, I've come across a variety of promising materials that have been suppressed, but this is certainly the most exciting one!
The properties of Lead Zinc Alloys are truly astonishing. These alloys have a very wide range of unbelievable uses, and the material itself is an infinite above-unity energy source.
Alloys were patented in the late 50s that could split water into hydrogen and generate electricity on contact with no external electrical input and no chemical changes in the metal itself. Scientists observed electricity being generated for 7 continuous years, so it can presumably generate energy indefinitely. In a finely powder form, each tiny grain submerged in water produces hydrogen gas and 0.5 V @ 200 μA of electricity.
I discovered the substance thanks to this footage of Peter Lindemann talking about it:
Production
The patents listed below contain detailed instructions which should be sufficient for anyone with the tools and motivation to recreate these alloys.
In preparing the alloy of the present invention, the following metals and metal alloys are melted together in a crucible in the following proportions to provide the metallic ingredients:
(100 pound batch....)
Yellow brass (30% zinc and 70% copper): 8 lb
Aluminum: 8 lb
40-60 solder (40% tin 60% lead): 1.5 lb
Silver (.1%) or Nickel (0.1%): 0.1 lb
Zinc, to make up a 100 pound batch or: 82.3 lb
History
In the 1950’s, inexpensive aluminum cookware was just being introduced. Most of it was made from aluminum alloys that were brittle, and tended to crack when heated and cooled. This made a product that allowed people to repair their own aluminum pots and pans quite popular.
Samuel Freedman introduced ChemAlloy in the late 1950’s. By the early 1960’s, most local hardware stores carried it. It was, by far, the best product to repair aluminum cookware that was ever sold.
The first US Patent for the formula issued in 1957. Shortly thereafter, Freedman started noticing that the alloy exhibited some fairly unusual properties. One of these properties was that it could produce electricity when immersed in water. While most metals will do this, ChemAlloy was unique in that it produced electricity while remaining chemically inert. Electricity came from the metal, but no oxidation or reduction reactions were taking place.
But the most remarkable discovery was when the metal was ground down to a fine powder. When powdered ChemAlloy was placed in water, it immediately began producing hydrogen and oxygen bubbles. This process continued until all of the water was gone! But like before, the metal itself remained inert and chemically unchanged.
In 1960, a second US Patent issued that up-dated the 1957 patent by adding the information on the alloy’s special properties. By the mid-1960’s, Freedman reported that he had successfully produced electricity from the same sample of ChemAlloy for over seven years. The implications for the inexpensive production of hydrogen are enormous.
US Patent #2,796,345
US Patent #2,927,856
Lart2 posted this 13 December 2023
I got some of this stuff, from a trade show long time ago..
