Main Stream Scientist acknowledges...
  • 555 Views
  • Last Post 14 May 2025
Chris posted this 14 May 2025
The changing of the old guard:
DUP, we made a mistake, it appears Free Energy is Confirmed and proven, some 120+ Years after many thousands of people tried to tell you all so! Whoops! Big Mistake! See what happens when you ignorantly listen to Dumb Assho**s!
Words Eaten:
Remember this:
Yes, many Idiots have made a mockery with pathetic Hoaxes!
Some people can see past the dogma, intrenched ideologies of an idiot regime, and some people are only now waking up to it! Better late than never!
Main Stream Science is starting to admit the Ignorance that so many have held onto with such vigor and arrogance, is not a healthy position to hold, when a system is not bound to narrowly defined set of requirements: A CLOSED System.
In other words, your narrow minded, self-imposed limitation, is only valid under a very small set of conditions and you failed to observe this fact!
The video starts off:
It may be the most sacrosanct principle in all  of science – something you learned in elementary
Here in lays the mentality we have had to deal with: regarded as too important or valuable to be interfered with (especially of a principle, place, or routine).
Now, If I tell you The Human Body must not Breath, its essential, a sacrosanct principle - Would you want to break this principle? Of course, right!
There are some total idiots out there in the community that simply are Ignorant Idiots, that clearly have no skills to verify Truth on the Bench! Why do so many PPL listen to them? Instead, they should listen to their gut feeling which is nearly always right.
Electrical Energy, as we have already been through, is Charge Volume multiplied by the rate at which the Charge Flows, a Volume-Metric Quantity, and we know a Changing Magnetic Field Generates a Voltage, and that Current is Pumped from Source, which is the Atom, the Subatomic Realm, thus the Term Quanta was used by Floyd Sweet, because the Electron is a discrete quantity of energy proportional in magnitude to the frequency of the radiation it represents.
The Tide is turning, the Old Guard is being replaced and a New Guard is entering!
Now we get to ridicule the Old Guard for its short falls and inability to achieve simple experimental milestones. You were given chances and did not make steps forward, so replacement is necessary. Your belief's were never enough to do Science and have cost you your futures, at the same time opened doors for a new and glorious stage for true Science to take place!
You have just been Violated!
