Mathematically proven Overunity mechanism
  • 837 Views
  • Last Post 18 February 2018
vikram_gupta11 posted this 18 February 2018
See the video.
See the sketch as per my video. The ball weight is 400 gram Distance from fulcrum of tube 0.35 meter The ball is resting 1 meter Now use pythagoras equation to calculate exact distance of ball. It will be 1.060 m. Now use torque formula Torque= rf=rmg So torque of ball is 0.400*1.060=0.424 So counterweight will be only 424 gram to Balanced the seesaw. But I took 500 gram to take advantage of heavy counterweight. So seesaw will be tilted . Now if I am releasing the ball from 1 meter height and it will travelled 2 meter. Calculate bthe kinetic energy. Mgh=0.400*10*2=8 Joule And counterweight will be rotate more than 180 degree and device will get back it's initial position and ball again fall down anti clockwise. Two lock and Spring based latch pin will work to hold the device and ball. I am interested in impact energy of ball.if ball fall down and compressed a spring after each stroke and spring release it's energy at the time of falling down of Ball then? The reason is that the ball will have to lift up only 24 gram weight As counterweight is 424 gram so the will do two work at first it will work to balance the seesaw then the energy will work to lift up only 24 gram weight. This is the main reason of overunity.
I would like to tell that I am interested in impact energy of ball.it is an Oscillating device. The energy laws will work only at initial stage but after that the device will oscillate on it's own. See more sketches.
The very interesting point is that the tube length is 2 meter but the only 1 meter will be calculated in input as it is mounted in middle with the arm.but in the output 2 meter calculate as ball is travelling 2 meter distance vertically.
I have tested the work of latch pin .please don't consider the video as a perpetual motion as I just tested it to know the work of latch pin and momentum.
Chris posted this 18 February 2018
Hello and Welcome Vikram_Gupta11 - Thank you for sharing!
Please pay special attention to Links you are posting.
All Links need a New Line
I can fix most of this sort of stuff, but not all, all I can do is delete if I am not able to edit.
Dear Sir,the link is working.
If the incorrect format is placed in the post window, the formatting of the entire page can be changed, sometimes making it unreadable.
Please see: Help with using the Forum for further help.
Looking at your work, it reminds me somewhat of the following video: @ 6 : 09
With exception of the complete ignorance of some individuals in the Video, maybe this can be of some help? Most certainly your work is very good!
Dear Sir,there is big difference in my work and the video you presented.in my work the ball will work to get the device it's initial position (though it will be anticlockwise in second stroke) and there will be no problem of connecting a load as the Ball is working to run the piston generator and we extract energy after mounted two generators on each side of long tube.the device will oscillate forever.
There is no flaw in this mechanism and no one can debunk it.
