Nerv Ferro Reactor
  • 741 Views
  • Last Post 27 September 2017
alohalaoha posted this 26 September 2017
FISH СЭ IS HERE = FISH IS OVERUNITY....
arrows up = CCW windings = 40w , 2mm in insualtion
arows donw = CW windings = 40w,  2mm in insualtion
output are 3 pairs of Hooper Tensor coils in parallel - source of scalar magnetic field.
begining for every Hooper pair is at top of coils.
inductor brown wire = 4 mm diameter meassured with insulation, 19,5w. inductor between plus and anode d1.
ferrite reactor made from two halves 2 x 98 mm, with MnZn ferrite rings with air-gap 3-4mm. tune gap for best output. each ferrite ring dimesnion 38 mm x 24 mm. each reactor halve 98 mm wounded with 46w, 2mm diameter with insulation. inner blue tube is for stacking ferrites.
Current consumption 24V/1A.
Load = light bulb 60W, 220V. Output is impulse current with 2.5 COP.
generator based on PCM SG3525 with freq, pw, and duty control.
mosfet irfp 460, diode any hv high speed, high current, fast recovery.
PS.1. Attached 2 videos, one is tuning ferro-resonance to maximum brightness of light bulb, and second is charging and discharging microwave owen HV capacitor 1uF/2100V with rectified current vai two HV, high speed, high current diodes. Spark gap is at top of L3 coil - begining of coil. Cut wire and put spark gap.
PS.2. Only one big and unsolved problem with Nerv reactor. Curren sintering technologies are very miserable and poor. After several hours work ferrite cores has gone to decomposition - precisely to dust. What need to be solved for ferro-resonant generator with cop > 1.
Informations for those who want to try a luck. ))))
Reg.
Zanzal posted this 27 September 2017
I have some MnZn cores that will fracture with almost no force when a strong magnetic field is applied. Not really sure why that is, but some epoxy would likely solve the problem.
On L3, does the plate represent a shared ground with L2 or are L2 and L3 joined with a capacitor?
alohalaoha posted this 27 September 2017
Shared.
If you have lot of fractured cores, try to mill them in fine ferro-powder add epoxy and pour that in two identical cylindrical reactor forms. if you can, try that variant.
