Nigel Cheese
  • 1.5K Views
  • Last Post 27 May 2024
MJ.nfl posted this 25 May 2024
Hello to all...
I'm looking for information about Nigel Cheese's research and experiments... I guess a site about overunity is good place to ask... 😀
Nigel had a lot of his work published on the internet, most of it on Youtube and Linkedin, but also on other platforms and forums....
Good deal of his videos is still available on youtube and other video sharing platforms, but his linkedin page that had numerous articles and pdf books he shared has been deleted...
Since I can't find it there, I'm looking for the help from the members if they by chance have something saved up in their private collection....
If you have any of his work, I would be most gratefull if you could share it here.
Thank you to all and all the best...
MJ
thaelin posted this 25 May 2024
Had to see who this was. Never heard the name. Seems he has 3 different names he goes by. Bit of a red flag for me. PCAM vid was stating some wild output values to me.
Classic posted this 26 May 2024
Not sure why someone can see a red flag about Nigel and do not see a red flag on those who make eronate conclusions like Robert Murray Smith. With my little understanding I managed to replicate some of his setups … if I could have access to all files he published probably I could replicate almost all his setups.
Also his statement about yttrium is correct to be used instead of gallium for enhanced performance … just look at specialised semiconductors where gallium have been swapped for yttrium.
I think he is the first one whom managed to show how to use permanent magnets instead of bucking coils. Mainstream science does not admit that permanent magnets have their own energy. If anyone bother to read old patents, inventors say that instead of iron core, permanent magnets can be used. But, if permanent magnets are too strong a piece of iron must to be interposed between them. See, David Davis Jr Manual book experiment with bucking coils on one iron core where single pole is created in the middle and can be either south or north depending on polarities applied to the coil. North pole magnetic indicate where output should be and you can collect in middle point or extremities depending on your needs. Anyway in this case a second source of the opposite polarity should be employed, which can be air or earth ground.
Many people get confused about alternative current and currents that alternate, like when current alternate means switching polarities at input or keep the same polarity but interrupt.
In one of the experiments of Nigel using 2 iron nails, 2 permanent magnets, 1 coil and 2 different ground connections … he just don’t disclose switching mechanism, but show electric energy generated in both forms as AC and DC in the same time and despite high voltage of 60 V an ordinary LED don't burn. His explanation is just common sense and logic outrageous simple where the 2 magnets are placed at ends of iron nails with their south pole facing ground input.
I don’t understand why is so difficult for many people to visualise an iron bar with (at least) 2 windings on it and powered up in consecutive sequences will just simulate a movement of a magnet inside a coil and depending how is power up we can simulate in-out or just one way like a diametrical polarised ring magnet which rotate inside a coil. It seems that almost everyone are looking just to electric flow and utterly ignore magnetic flow … only speaking about induction instead of analyse magnetic
Alex ⋐˙⋮⋮˙⊃ posted this 27 May 2024
hey Classic,
I'm sorry if I'm talking non-sense here, @admin ... feel free to delete my post if it's gibberish
POC:
summarization:
1. North vs North = POCs ( oppositely wound coils )
2. Iron nails  = 2 C-cores ( preferably nanocrystaline because of their magnetostrictive property )
3. Nails aren't touching - only magnetic  = a dielectric spacer between the 2 C-cores
I saw the same NvN ( oppsing magnetic fields ) principle used in many other devices:
#WO2009065219  Magnacoaster (Richard Willis) , below is a quote from the patent:
#US3504321A  Westinghouse Electric Corp , below is a quote from the patent:
The magnetomotive force in leg portions 14 and 16
is, therefore, in opposite directions, which aid each other
in the core loop.
Nigel Cheese on Yttrium:
https://en.wikipedia.org/wiki/Magnetostriction
Has anyone tried a different better core material , than MetGlass ?
I noticed Don Smith's use of Turfenol-D ( very expensive ) but there are other materials easier to make:
>> Galfenol ( Ferrite + Gallium )
>> YFenol ( Yttrium and Ferrite )
In YIG, the five iron(III) ions occupy two octahedral and three tetrahedral sites, with the yttrium(III) ions coordinated by eight oxygen ions in an irregular cube. The iron ions in the two coordination sites exhibit different spins, resulting in magnetic behavior.[2] By substituting specific sites with rare-earth elements, for example, interesting magnetic properties can be obtained.[4]
YIG has a high Verdet constant which results in the Faraday effect,[5][6] high Q factor in microwave frequencies,[7] low absorption of infrared wavelengths down to 1200 nm,[8] and very small linewidth in electron spin resonance. These properties make it useful for MOI (magneto optical imaging) applications in superconductors.[9]
Thanks,
Classic posted this 27 May 2024
For electricity generation I wouldn’t look for expensive and exotic cores. If heat treated iron isn’t good enough for your design just use air core.
Pure iron magnetisation/demagnetisation instant. Carbon steel (iron+carbon) instant magnetisation/retained magnetism. Again: see David Davis Jr Manual book.
But, pure iron should be the base for any type of magnets (permanent or electro) and instead of steel a small permanent magnet can be added OR little DC straight to the core from any source (including Earth or Air ground) from a separate connection.
Also, an alternative method to bucking coils is use of standing waves where we pay energy for one way while the opposite way is provided for free by reflection.
Any method that use 2 currents flow against each other will generate excess electric energy.
  • Alex ⋐˙⋮⋮˙⊃
