Observation
  • 1.9K Views
  • Last Post 11 November 2025
Chris posted this 11 July 2025
You have been lied to, mislead, and swindled, by self proclaimed gurus, you those members of other forum's, they are absolutely NOT qualified, never will be, yet they have had a grasp on your direction for decades.
The Power of Observation, key to understanding and furthering our technologies, advancing as a Species, hopefully together.
We all know the Floyd Sweet VTA Schematic, we have seen it a million times, but have we closely studied and made critical Observations:
A short list of some Key Observations:
  • P1 supplies a Voltage and therefore a Current to one coil in P2 and vice versa.
  • At-least two signals at any one time is present, one from FB1/2 and another from the opposite Power Coil.
  • The Arrows indicate the Bucking, which ties in with the below quote.
  • The VTA was started by a battery, and stopped by momentary disconnection of the Power Coils.
Quote
FIELD SUPER-POSITION AND THE VACUUM TRIODE
Electromagnetic induction with no measurable magnetic field is not new. It is well known that in the space surrounding a properly wound toroidal coil there is no magnetic field. This is due to the superposition of the fields. However, when alternating current is surging through a transformer an electric field surrounds it. When we apply the principle of superposition to the vacuum triode it becomes more obvious how the device is in fact operating.
The principle of superposition states that; "In order to calculate the resultant intensity of superimposed fields, each field must be dealt with individually as though the other were not present". The resultant is obtained by vector addition of each field considered singularly.
Consider for a moment the construction of the triode which includes the bifilar coils...
When the current in one half of the conductors in the coils (i.e., one of the bifilar elements in each coil) of the device is moving up, both the current and the magnetic field follow the right-hand rule.
The resultant motional E-field would be vertical to both and inwardly directed.
At the same time the current in the other half of the conductors in the coils is moving down and both the current and magnetic field follow the right-hand rule.
Thus, the resultant field intensity is double the intensity attributable to either one of the set of coil conductors taken singularly.
Expressed mathematically: E = (B x V ) + ( -B x -V ) = 2 ( B x V )
You will note: E = (B x V ) + ( -B x -V ) = 2 ( B x V ) is this statement, in long form:
Quote
My Friends, can we Cross Reference these observations? Yes we can!
Andrey Melnichenko's GLED uses the very same facts, also the same with Kapanadze's machines.
I already tried to show you all, Tinman's RT V3 also uses the very same effects by injecting a small current into one POC at the right time:
I said:
Look For Effects - I have always said this, this is how I found this path! Some effects to look for:
Ref: Chris
I gave you all, a very simple experiment a long time ago:
Some of my Pulsed DC work was documented here: Akula0083 30 Watt Self Running Generator.
The CLOSE Observation of this experiment was a real blessing for me! I found some very important aspects to Bucking Coils in the experiment! Other very bennificial Experiments also helped!
You will obtain success if you follow these key observations, which are Intuitive yet contrary to what we know. I will have more on this very soon!
skzt234 posted this 06 October 2025
Does anybody know how transformers work?
Why does the primary take more current when the load current is increased?
How does it know to increase the current?
There is no electrical link between primary and seconday.
The only link between input and output is the magnetic field in the core.
If you can answer the question why the primary takes more current when the secondary takes more current then this is a starting point for moving forward.
Of course the answer is that the load current generates a magentic field in the secondary coil which is opposite to that from the primary.
Thus, as in any linear system, the superposition theorem applies and the two fields (forward and reverse are summed together).
Thus the primary field is reduced as the secondary back mmf is subtracted from it.
But the field cannot go to zero because then there would be no reverse field to cancel the forward field, so it goes to some lower value.
Thus the net field is reduced for the same input current therefore the input iniductance (ratio of current to field) is reduced, hence the input takes more current.
Okay! How can we get around this?
THe secondary field only cancels the primary field because they are at the same frequency.
If a voltage at frequency f is applied to the primary, the magnetic field is at frequnecy f and so is the output emf.
And there is no law that says you can't take a million amps from the secondary .
Faradays law only states that a changing magnetic field will generate a changing emf, it doesn't specify the maxmimum current in any way.
So our output emf is at frequency f - we cannot get around this. But we CAN engineer the current to be at a different frequency.
What if we switch the output sine waveform to chop out the middle third of each half-wave.
Then we generate a waveform with a strong 3rd harmonic component.
Apply bandpass filtering at 3f so the load takes current at this frequency.
Apply bandpass filtering at f at the primary side so that the generated 3rd harmonic at the secondary sees a high impedance at the primary and does not drive into the source.
Switching the output waveform makes the circuit relatively simple and minimises losses in generating the new frequency component.
There will be many other harmonics generated by switching of course, but to a crude estimation you would have generated a different frequency which then will not clash with the primary frequency, and hence the secondary field will not cancel the primary field.
Comments? suggestions?
Will it work?
Thanks for reading!
  • Drasko
Wait .. no. It wouldn't give third harmonics. I think only 2nd and 4th so it wouldn't work. But anyway you get the idea- you can play with the load current to try and generate other frequencies
  • Drasko
skzt234 posted this 09 October 2025
A couple more thoughts.
Why does the turns ratio rule always appliy to transformers, whether open-circuit or loaded?
An open circuit transformer is an inductor, effectively. So you would think that if you double the frequency of the input voltage, the primary current would be half (due to the reactance being double), therefore the magnitude of the magnetic field will be half and hence the output voltage would be half. But why doesn't this happen?
It is because the output voltage is proprtional to rate of change and hence is doubled due to this, hence the turns ratio is maintained. Isn't it interesting though how it always maintains the voltage!?
Also remember that a transformer works both ways. Just because we call one side 'primary' and the other 'secondary' doesn't really mean anything and this just arbitrary. A current in either coil will produce a magnetic field in the core and hence a voltage (emf) at the other winding(s).
Thus current in either coil will contribute to the magnetic signal in the core. Multiple magnetic frequencies can co-exist in the core at the same time, just like currents at multiple different frequencies can co-exist in a wire, without interfering with each other.
The current in the coils is like the 'input' to the magnetic core and current translates directly into magnetism. And the 'output' from the magnetic core is the voltage developed at the winding (all windings in fact) due to the rate of change of magnetic flux - at any and all frequencies present in the magnetic domain.
Chris posted this 10 October 2025
Yes, we have studied in detail and there are threads here on this forum about this.
As the Magnetic field's in the Transformer increase, the Coils loose some of their Impedance, as the Impedance reduces, the input Current goes up, because: I = V / Z which is the same as I = V / R, at saturation. Of course at Saturation the equation is: I = V / R. This is because all of the Coils Impedance is lost, Inductance is gone, and the only thing limiting the Current is the DC Resistance. This is the simplified version.
Yes, all correct, youre on the right track!
The issue here, is the Symmetrical Nature, which is by design, of the Transformer.
I am pleased someone else has noticed this hole, where it is easy for assumption to creep in!
 In my experience, the only way, properly, is to introduce Asymmetry to the Transformer. This forum does have many detailed experiments showing our successes in this field: Non-Inductive Coil Experiment
Will it work?
Thanks for reading!
There are many ways to try to "Generate" an excess in Electrical Energy. Most I have tried in the past have failed. I only know of the one approach, again Asymmetry, appears to be the only successful path forward.
At a basic level, the fact stands, any Symmetrical System is always below Unity, because: Output = Input - Losses, never can we get more Output due to this limit.
The Prime Mover in any Symmetrical System, doing all the work, is the total work done and once we account for losses, the work then is reduced, and the work done is always greater that the work out.
We have many machines that have been shown to be Above Unity, but there is a bit of work first to learn, then to build them correctly, and them measure correctly. But, we have them. No one else has ever achieved this.
  • Plasmonic
  • Drasko
skzt234 posted this 10 October 2025
Thanks Chris for the detailed response, it is much appreciated and nice to get some feedback!
Had a quick look at the non-inductive coil exp and will have a more detailed look later. But what immediately sprung out at me was the 'something is nothing' statement which reminds of what Bill Alek said- that when two magnets of like poles face each other, the field is 'zero' (not measurable) in our space but goes into 'imaginary' space. By this he talking about space as a complex  coordinate system with real and imaginary parts which gets rather interesting.
So many different angles and approaches to all this stuff. But your website is a valuable resource which I  shall continue to use as a source of information and inspiration. And I'll keep learning and experimenting as any good engineer should.
best wishes
David
  • Drasko
Just on the subject of asymmetry..
By 'symmetry' in a transformer, what you are referring to - I think- is the fact that the load current destroys the source magnetic field from the primary which caused the secondary emf that created the secondary field. In other words the load destroys the source.
But my suggestion changes the frequency between output voltage and output current. I thnik that is the key and that should break the symmetry because the output can no longer destroy the input if they are on different frequencies.
  • Drasko
skzt235 posted this 11 October 2025
The words of Tom Bearden are becoming ever more valid and clear to me, when he said that
not a single watt of power from the power line ever reached the electrical loads in your house.
And that all you have to do is create a dipole in the vacuum and nature pours out all the EM
energy you could ever need, and that our circuits today use half the energy to destroy the dipole.
Another analogy is like trying to lift a board while standing on it.
People talk about transformers as if power goes in, passes through the core and then comes out the secondary
(plus core losse & winding losses etc).
But this is total nonsense. I'll admit it does appear that this is what's happening, but really
the power out has nothing to do with the power in, it has only to do with the magnetic field in the core and the load resistance.
Poeple talk about efficiency as power out divided by power in, and while this can be useful practically,
it completely hides the truth of what is going on. Power talk about 'power' in the magnetic core but again
this is complete nonsense. The only thing in the core is magnetic field.
What happens is that the input current creates a magnetic field in the core and that is all.
The magnetic field does not have a 'power' rating. There is no 'power' in the core, it is magnetic potential.
Yes it has magnitude but that bears no relation to output power, only output volts.
THe magnetic field does not know anything about how much power you are taking from the secondary coil,
and as a consequence neither does the primary since that is the only link between the two, therefore once again the power out is not related to power in.
The magnetic field in the core sets up a dipole in the secondary coil and produces a voltage across its terminals.
From this you can take as much current as you want. This power is being GENERATED in the secondary coil due to the magnetic field. It does not come from the primary. It comes directly from the vacuum and not from the watts that you put into
the transformer.
This false idea that people have of energy passing through the transformer is what limits their thinking and beliefs and
this is why they cannot conceive the idea of overunity in relation to a transformer, because naturally if I put x watts in
and they pass through to the output then I can't have more than x watts coming out.
But this is to misunderstand how transformers work.
  • Drasko
On the practical side of things I am thinking that generating f/3 would be a better way to go, i.e. generate a lower frequency current from the voltage at frequency f on the secondary side.
This means switching at a lower frequency which makes it a bit easier, and you can simply enable the load current every third half-cycle, for a duration of one half-cycle. This will give you an alternating waveform at f/3.
The load operates at f/3 and is band-pass filtered at this frequency. Again the source is filtered at f so as not to let the f/3 see the source voltage.
There are a few questions remaining though..
1) will it work!?
2) Will it be stable (or safe)?
3) What is the COP?
It would be ideal to model this mathematically and see what would happen. Or just build it .
Using 50Hz  is not really practical for this design, because the filter inductors would need to be so large and you wouldn't get a good Q factor due to the long winding resistance. You can maybe operate an iron-core transformer at upto 1kHz though, and that might work. Otherwise ferrite is a good choice. Square waves can be used to drive the primary and these will become siney after passing through the input filter.
Another question is, if the load is filtered at f/3, how will the thing start generating f/3? because only f/3 gets throuygh the filter.
It may be necessary to switch a load as described above enabling it every 3rd half-cycle of f and then this will always generate asn f/3 magnetic field in the core. Then the main load will receive power from the volts generated at f/3.
This is all speculation at the moment but I remain hopeful and will build something as soon as I am able to .
But I'd really like to hear if anyone can see any obvious, glaring reasons why this won't work !!?!!
I'll put my hands up and admit it!! and then go back to the drawing board.
  • Drasko
  • Drasko
Chris posted this 12 October 2025
Hey David,
Symmetry in a Transformer refers to every aspect of Electromagnetic Induction inside the Transformer.
As an example, in an Ideal Transformer: M.M.FSecondary = M.M.FPrimary
Of course, we know a real Transformer: M.M.FSecondary = M.M.FPrimary - Losses
So, you can see, there is a nearly perfect Symmetry between the Primary and the Secondary, Magnetic Fields are Equal but Opposite. Electromagnetic Induction, specifically Lenz Law, requires the Opposition, and equal E.M.F. Electromagnetic Induction, with incorporated Lenz Law, will always be Equal and Opposite. You can also use a Power analogy: Every WattOutput = WattInput - Losses. The very same analogy can be applied here, because of this Symmetry. Electromagnetic Induction requires Symmetry at a base Level. Asymmetry incorporates Symmetry!
This video shows output Voltage Symmetry:
However, this machine is Asymmetrical.
Antenna Theory relies on breaking symmetry to convert electrical signals into electromagnetic waves.
A perfectly symmetrical transmission line, such as parallel wires with no breaks, would have balanced electric fields that cancel each other out and would not radiate. By intentionally breaking this symmetry, for example by creating an opening in the line or by using different geometries like a flared end, the electric fields no longer cancel, leading to the emission of electromagnetic radiation. Symmetrical systems don't radiate: In a perfectly symmetrical system, such as a pair of parallel, unbroken transmission lines, the electric fields from the opposing conductors are equal and opposite. They cancel each other out, and no electromagnetic wave is radiated.
Breaking the symmetry: Antennas work by creating an asymmetrical structure. When an oscillating signal is applied, the broken symmetry allows the electric fields to become unbalanced and cause the oscillating charges to radiate electromagnetic waves.
Examples of broken symmetry:
  • A dipole antenna: This is a common example where the two arms of the antenna are designed to be asymmetrical, such as by being of a specific length to resonate with the signal.
  • Flared transmission lines: If you flare the ends of a transmission line, the parallel geometry is broken, and the fields no longer cancel, causing radiation.
  • Dielectric resonator antennas (DRAs): These antennas rely on the polarization of a dielectric material to create an oscillating dipole moment. This oscillating dipole then radiates electromagnetic waves.
When your EM Machine breaks Symmetry, is Asymmetrical, then you no longer need to abide by the Rules a Transformer is Bound to! An Asymmetrical System can output more Electrical Energy when you are in Resonance:
  • Drasko
  • Plasmonic
skzt235 posted this 12 October 2025
Thanks for the replay again. It is useful to have these conversations as it stimulates ideas and progress.
You mention something which I had forgotten about: resonance.
With that in mind I would modify my circuit to the following..
  • Drasko
Maybe put a diode in series with the switch. Then switch on for one cycle every 3 cycles of f.
The diode will allow the capacitor in the tuned circuit to charge up with a pulse of current and then the tuned circuit will oscillate at f/3.
Without the diode the tuned circuit would leak current back into the transformer secondary.
Chris posted this 15 October 2025
Hello Skzt235,
I believe an experiment with the proper measuring techniques will provide your answer.
My gut tells me it wont work, not as you're hoping, but hey, please prove me wrong.
The reason I say I believe it wont work is because of the Symmetry I described above, instantly turn off the input, the Output will instantly also be turned off, except for a little fly-back. As you're no doubt aware, a DC Fly-back Transformer is not Aboveunity, no one has shown results that show AU, but I am open, if you can show that it is, then great.
  • skzt234
  • Drasko
skzt235 posted this 15 October 2025
I too have doubts that it will work - but I can't quite pinpoint why!
With most things in electronics there are two ways of looking at it: time domain and frequency domain.I think the key thing here is the input filter, although it sounds trivial. Normally any harmonics generated in the load current will propagate directly back to the input as you say, and they will see a short-circuit at the source and then this is wasted energy.
But if a filter is employed then these back-fields which cause a voltage at the primary at their respective frequencies , will just be driving a high impedance and will not cancel because they will not get through the filter.
Similarly - to quote Tom Bearden again - he says that sharp impulses in voltage or current will give extra 'negative' energy which can be transduced into positive via capacitors. So I often think, why do switch mode power supplies not exhibit any of these phenomena? Maybe just a few design tweaks and they could achieve it.
With the frequency change idea between volts and current this could possibly be analysed by a simulator. I think it comes down to the exact frequency composition of the waveform coming back, and this could be determined by computer program, if one had the time!
But there is no doubt in my mind that the secondary current can be made to deliberately generate a sub-harmonic at a lower frequency than the fundamental, and that this would cause a magnetic field comonent at said lower frequency.
The load voltage is a sinewave, that is fixed, at least to start with. It is a pure single frequency, a spectral line in the frequency domain. The load current however can have harmonics & subharmonics, a whole slew of spectral lines. Each spectral line in the current at the load will produce an identical and proportional spectral line in the magnetic field signal (magnetic potential) in the core. (Amperes law)
Correspondingly then that will cause voltages at all windings to replicate the differential of the field following Faraday's law. Thus if you take a current at f/3, now the output voltage will have this component in it, because it was in the field! So the output volts will look messy with f plus f/3 and whatever other harmonics. If you only allow one freq into the transformer at the primary from the source then this is the only one you pay for , and if the dominant load current component is a different freq then input current will be less at f.
Its also worth remembering that the output power does not come from the input power as I explained above. How can it? when the only parameter linking pri & sec is the field, and yet the field determines only magnitude of output volts, it has nothing to do with ouput power! So in my view the system is ripe for overunity phenomena. The fact that output current causes the field to diminish and this causes the input inductance to reduce hence increasing input current - is purely circumstancial as far as I'm concerned.
Anyway the only proof is to build it. (else use a circuit simulator)
best wishes
David
(Apologies for the two usefnames by the way. I forgot my password for one account so had to start another!)
  • Drasko
Here's another way of looking at it..
Lenz's law is the SOLE reason that transformers are always under unity.
If you do ANYTHING to break Len'zs law then you must be in OU territory!
  • Drasko
skzt234 posted this 15 October 2025
All you need to generate volts is a magnetic field.
Once you have the volts, ohms law says that the current depends on the resistance. i.e. no limit to the current you can take!
If the volts is there, you will have as many amps as you want.
If you have a field, you will have volts, Faradays law.
As long as the current you take from the volts does not destroy the field that caused the volts, then this is overunity.
  • Drasko
The Magnetic Field must vary in Time, E.M.F = Bvl for Flux Cutting. E.M.F = -NδΦB/δt for Flux Linking. Electromotive Force is measured in Units of Volts.
Yes, a Hole in Science exists here, but you're not quite coving the whole picture here. Again an Experiment will show you that the Secondary Magnetic Field must be Supported. There is more to it than you're alluding to.
Technically, no, this is not true. Every Coil of Wire, an Inductor, has DC Resistance, AC Resistance, which is Impedance, to the Output Current depends on these values and the Coil Geometry. Output Power Density is linked to the Inductor properties.
Yes, the Changing Magnetic Field in the proximity to the Conductor will "Generate" an E.M.F measured in units of Volts.
A simple ten minute Experiment will show you why these statements are only partially correct and do depend on interpretation.
A Voltage is the Potential Difference in Charge, a fundamental Charge difference between Terminal One and Terminal Two, where the Positive Terminal has greater Negative Charge than the Negative Terminal, that could be considered to have more Positive Charge if you're viewing this problem from Capacitor theory, or no Charge if you're viewing this from EM Theory. Another hole exists here, no one ever covers this properly or correctly.
I have 11 videos showing, providing answers to all these questions, miss-understandings:
You can watch the Play List here: &list=PLz0hV4NkTSsMCI7l2ARV0o50KYo_jtDr2&pp=gAQB
  • skzt234
  • Drasko
Thanks again. This does bring up a question that I kind of have in the back of my mind:
If a magnetic field is 'magnetic potential' (MMF) in a magnetic circuit in an analogous way to voltage being electric potential (EMF) in an electric circuit, then what is it that determines its 'impedance' or its strength ?
What is the 'source impedance' of a magnetic field / potential? i.e. if another equal but opposing field is present, which one wins . Or do they always cancel exactly?
  • Drasko
Hey Skzt234,
I believe Reluctance is the term you're looking for?
Force F = NI, so the Ampere Turns of the Coil is also the M.M.F when Reluctance is 1.
There is no such thing as a "Source Impedance" for the Magnetic Field, in EM Theory, but there is Superposition.
  • Drasko
  • skzt234
ERTW posted this 19 October 2025
I've been thinking about this schematic last couple of days and would add the following observations
  • P1, FB1 are shown connect with a dashed line which traditionally means core. but i thought in later VTA versions (which this one is because it includes the self starting circuitry) sweet used air core
  • DC battery, T1/EX1/FB1 are used to start the system. at startup, FB1 acts like Coil A or L1 in Chris's standard POC drawing. the voltage on FB1 must be very high due to T1/EX1 turns ratio. really, its unnecessarily high because we already now POC work well even at low L1 coil voltage. Why did Sweet feel the need to kick-start at such high voltage?
  • after system starts up, the T1/EX1/FB1 is no longer forward biased by battery because the battery is DC. Essentially this means there is no more input power. so how does Sweet maintain a 120V 60Hz output?  does he still apply a 60Hz input signal (microwatts input power) through a pure sinewave generator, if so its not shown on this schematic
  • FB1, FB2 .. i read this to mean "feedback 1, feedback 2". so during normal operation when the input DC battery is no longer able to do anything (previous statement), that's when these coils are somehow used, as feedback.. taking 120V 60Hz power from P1 then backwards towards EX1/T1 .. to what purpose i don't know. the voltage at T1 will be tiny since it started as 120V and went backwards through massive step down turns ratio.
anyway, that's my first post on this forum
- as an aside, i am currently building a lab and ordering materials to catch up to you all. i've watched all of Chris' vides as i watch and learn while treadmill jogging. will be starting with MrPreva and then POC experiments to prove out the basics first!
Chris posted this 19 October 2025
Hello and Welcome ERTW,
Thanks for posting and sharing your observations! Yes, there are many, and some critical, to make sense of the VTA!
Once the Flux of the Magnets is moving, and if it is moving in the correct way, we have Voltages "Generated" in the Excitation Coils Ex1 and Ex2, that then drive the system, or act as the Input:
Walt never lied and never made up an exaggeration as far as I can tell:
From what I can tell, as Walt pointed out, the Drive Coils were Ex1 and Ex2, these coils kept the VTA in operation and also regulated the System Frequency because of expert design, by Floyd Sweet.
The VTA was one of the best Energy Machines History has ever produced in my opinion:
  • Drasko
skzt235 posted this 01 November 2025
By turning the output off for 2 cycles and on for 1 cycle (or on for a half cycle and off for 2.5 cycles), you are creating a brand new frequency component which wasn't there before in the current waveform,
Lets say output voltage is at frequency f and we turn control output as just described, there will be generated a new frequency component - a new spectral line - at f/3. This is now the fundamental frequency of the current. Of course it will have all its harmonics at 2f/3, 3f/3 etc because it is not a pure sinewave.
But the point is that the frequency of the current waveform is now fundamentally at f/3. This means the output takes power from from f/3 as well as all its harmonics, including f ; -yes, so there will be some cancellation at f but nothing will cancel at f/3.
It is essential to not see this as simply a time domain signal where you get 100% opposing fields for a half cycle (meaning you have to put all the power into the transformer), and zero field for the remaining 2.5 cycles.
A 50Hz sinewave driving a resistive load generates a 50Hz current wave and correspondingly a 50Hz back emf field and hence the input field is fully cancelled so you have to supply all the power to generate output power.
This is correct. But now keep only a half cycle of the 50Hz and chop out 2,5 cycles (output off). Your current wave is no longer simply a 50Hz sinewave that is chopped. Yes it appears so in the time domain, but having knowledge of Fourier series you will realise that taking a waveform (pure sine, for example) and switching it on and off generates a whole new gamut of frequencies, harmonically related.
So the actual result is that you are taking energy from f/3 (which doesn't get cancelled, hence doesnt suck more current from the input due to lower inductance i.e. field cancellation), as well as its harmonics ; and of course f will get cancelled because it is the primary frequency. So only parts of the current frequency spectrum cause cancellation, so this must put you in OU territory. It will depend on the exact harmonic coefficients as to how much overunity you get, i.e. the proportion of current is at f ve the proportion that is at f/3 and other frequencies, and this will depend on the waveshape of the current. f is the only frequency that gets cancelled becuase the input is at freq f. Any other frequency components in the current don't get cancelled.
I still haven't had tine to build it yet!
  • Drasko
Chris posted this 02 November 2025
Hey Skzt235,
I am sorry, I don't agree with your thesis on the topic.
At Time t, at any frame you choose, the Reflected Impedance will always result in more Current being drawn from your input Coil, as you continue to load your Output Coil. My Thread on Reflected Impedance explains more on this.
If I am missing something, then please provide the experimental proof showing what I missed, but as you describe your idea, there is no way for this to work. At least not the way you describe. I am sorry, I don't like shooting others ideas down, but I need to be honest.
You must have the MMF Required, in the System, to supply the load Current, so, for example, if your Secondary has 100 Amps going to the Load, through 100 Turns, that's: 100A x 100T = 10,000 Ampere Turns ( NI )
So, you must have the same, plus a little more, to over come the I2R Losses, and so on, present in the System, this must be the Symmetry in the System, its a requirement, if you Study Electromagnetic Induction, you will further understand this requirement.
Partnered Output Coils keep this Balance, each Coil must have the same NI as the other, and we have consistently shown this:
Where each Voltage is identical, already shown.
If you want to build Aboveunity machines, you need to use the typical known, proven laws and fundamental subject matter, the correct way. It does not work, if you just decide that the fundamentals all or a sudden don't work, you cant do it that way.
I have shown, in great detail, many times, how you can build AboveUnity Machines, if you follow my threads, you will succeed, like so many have to date.
I am still happy for you to prove me wrong, so if I have not understood you, or if I missed something, then please post your data.
Most everyone knows how hard it is for me to be patient with others, when they are not following the data given, because I feel readers are actively being mislead by people coming here to create a distraction, however, I am trying to be more patient.
  • Drasko
Jim Mac, aka FloodRod, has posted a post about the use of Coils to produce a speedup effect:
I am creating a "Paradox" for Lenz drag with this generator build.  Either Lenz Law OR Faraday's Law of Induction must bend.  No permanent magnets.
Here is the result..
a stock armature and commutator (rewound in a special way) slapped inside a crappy induction motor stator as the output.  There is more happening than shown.  More to investigate..
and over on his website:
I have been working on a new idea that I think is original.  This one kind of scares me because I think the idea has real potential to work. I have also consulted a few others skilled in the art and the consensus is encouraging.
Before releasing, I needed to make sure the idea was written-up and properly released into the public domain to protect from patent vultures.
Below you will find the original PDF of the disclosure before notarization, a copy of the notarized seal, and a video giving a brief explanation of the proposed method. I also included the below Youtube video in a zip file so those who wish to further protect the idea can share on their channels on various platforms.
Quote:This is now officially released into the public domain and can not be patented.
The WebArchive address of the document before the notary stamped it is https://archive.org/details/orion_202510
The official notarized copy is available in the attached zip
The PDF Hash is AD43CE82A135E974FD29113B1DEA525976DDDDB2ED465684EFC41841F2ECFE90
This video along with the presented documentation serves as the official timestamp to prove prior art.
For those looking to monetize on this invention, this disclosure does not absolve the duty of verifying possible patent infringements on active patents.
I also have the full notarization process on video, uploaded to several places with undeniable timestamps.
No guarantees are given.
I am in the process of building this now and will post updates here.
This is great to see, however, the approach comes across as somewhat egotistical, as I am sure I also have in the past. I hope he realises, and observes, what he is seeing, is not new, we have been showing this for years in one form or another, even Tinman showed this, in his RT. Lets see how Jim moves forward with this.
Jim IS onto something, he has this same effect occurring:
I predict one of two things will occur:
  1. He will get stuck and give up.
  2. He will take steps forward and start hiding his progress and his arrangement for obvious reasons.
My Friends, there are some good researchers out there, and some really bad ones. I consider Jim a good researcher. I believe he will get some positive comments and he will get some very negative ones, from Trolls.
I hope his path forward is not as troublesome as mine was.
  • Drasko
FringeIdeas posted this 02 November 2025
Interesting!
I signed up to get his pdf. I'm not sure I like, or maybe don't understand, his explanation. However, it does seem like he is getting some interesting effects! And I like that no troll policy on the forum, nice. I hope he keeps making progress. It will be interesting to see where he takes it.
Chris posted this 04 November 2025
Sadly, but predictably, the silliness and bickering has already started, in regards to the FloodRod's thread that I posted here.
Isn't it silly, there is ZERO Progress on those other forums, because the Debate turns into just stupid non-sense that is pointless and just is a waste of everyone's time! No wonder no one posts any of their progress over on the other forums! They are a magnet for idiots!
Anyone up for listing the facts on FloodRods experiment, because no one has come close to listing any simple facts about the experiment?
The fact of the matter is, there is an effect there, but the input power, not yet provided in full, is known to well exceed the Output.
  • Drasko
skzt235 posted this 11 November 2025
I appreciate your feedback and would love to iron out exactly where I'm going wrong but I'm not seeing it yet.  I'll try and simplify my theory.. and see if you can point out my errros:
The only reason a transformer is underunity is because the output current is at the same frequency as the field generated by the primary and therefore cancels it 100%.
But if I switch the output on and off at a sub-multiple of the input frequency (say a third), a new frequency component is generated in the current, and hence in the field in the core. This frequency does not cancel with the primary field because it is at a different frequency. The output takes part of its power from this frequnecy which does not cancel, hence you must get overunity.
The secondary current translates directly into a magnetic field in the core. Only the frequency components in the current waveform (and thence the field) which are at the input frequency will oppose and cancel each other; the rest will not. It is only when the output cancels the input that extra current is demanded from the input.
I think if you analyse your design in the frequency domain you will see what I am talking about.! maybe!?!
best wishes
Chris posted this 11 November 2025
Hello Skzt235,
No, I don't agree with you. That's not how MMF works!
Please feel free to post any experiments supporting your theory, however.
  • Drasko
MMF can support multiple frequencies simultaneously. Think of an audio transformer for example..
Thus you have to use frequency domain analysis to understand what is going on.
Fourier series tells you that a chopped sinewave will have new frequency components that were not there before.
Hello Skzt235,
I am sure, you would be happy to post videos of experiments supporting your theory.
Again, I have expressed my opinion, I disagree with your interpretations, but show us the experiments, let them speak for Truth!
  • skzt235
  • Drasko
