Pulsed Induction Generators (Prior Work)
  • 1.3K Views
  • Last Post 21 October 2020
Kerrow979 posted this 21 October 2020
Hi all,
I’m new to this site but felt it right to present the work I have done over the past few years should it serve as a trigger for someone, or indeed elicit some ideas from the members on how to make it function as hoped.
My interest is in ZPE coherence and has been, in particular, in ways to draw that into electrical circuits to access a net power gain. This is an area of major interest and many of the systems reported on this site I imagine are exploring this under different labels.
One of the primary ways this has been attempted by many is in using HV transients, such as those resulting when inductors are rapidly shut off, causing a back EMF pulse. It is suggested that these pulses distort the space-time metric and cause a temporary alignment of ZPE flux with our 3D space and then enter a circuit. This is often referred to as cold electricity, radiant energy, longitudinal waves and so forth.
What I want to do here in a compressed form, is to show some schematics and images of what I constructed in an attached file, since that would be easier than trying to hold ones attention span for that long
The Dropbox link at the end contains some build images and a couple of documents, one a more detailed report on the devices and the other a theory document I prepared as part of a larger report that, in the end, never got finished due to the results I had achieved. However, this might serve as a useful theoretical framework for others to examine.
Since working on the device I have tried one major modification based on some feedback from Patrick Kelly (shortly before he died this year) but got the same results. For this reason, it sits quietly awaiting some inspiration while I explore HHO, EVO’s, Plasma Ignition and related topics (I will share progress and build work on those in due course).
Here is a video of the rotor version running:
Since this site says my 9Mb pdf is too large to upload as an attachment here I have included it with the additional image and files at:
https://www.dropbox.com/home/%25Energy%20Systems/%25Water%20Fuel%20Cell/Shared%20Files%20(AboveUnity)/Pulsed%20Induction%20Generators
Julian
Vidura posted this 21 October 2020
Hi kerrow979 IMO a very important topic, I would like to have a look at it, but can't view the Dropbox file, I get promoted to open an account, but I'm reluctant to do so. If it's possible for you to post some of your work directly on the site, maybe with some comments it would be great. You can find instructions how to upload images and edit the post in the " help with using the forum" section. Best regards Vidura.
No reason why you should have to join Dropbox. This site wouldn’t let me post all the text and pics etc despite being only 1300 words so I have had to resort to holding most of it offline. Another option is for me to give you a link to a folder in my Mega account where you should not be ‘forced’ to open an account. I’ve seen DB offer an account but there was always an option to just go to the link. Let me post later when I have set that up.
Julian
Ok, it didn't take that long so here it is for anyone - an alternative link to a relevant selection of my files.
https://mega.nz/folder/pZ1AWIpa#ZLNhwdcnbsgmz4l5IhkHZQ
Incidentally, Mega is free and gives you a lot of encrypted space so it's a safe place with good facilities.
Julian
Chris posted this 21 October 2020
Hello and welcome Kerrow979,
If I may suggest a few things to try to help:
  • Your first post have html formatting inside the html code. formatting reduced the total Characters you can have. Select all your post, Ctrl + A, and hit the Ix button to remove all HTML Formatting. Total Characters is 23,000.00 including formatting.
  • Add images into your posts, see here: Help with using the Forum. Size limit is 2Mb.
  • You can attach files, there is a size limit, to get around this, shrink the file size down, or post multiple files.
  • If you need me to do it, let me know!
I will delete my post, this post, to free up your thread, when you have read it.
Great work and Thank You for Sharing! Very nice to see such wonderful work, we have so many highly skilled Members here all sharing exquisite work!
I could play around with these factors but as you suggested it’s probably better to have the bulk of the data and info off site so now there are two links to it. I’m still not sure how this html formatting got there as I’ve only used the option in the text box. Live and learn eh!
  • Gucio
