Quick intro
  • 1.1K Views
  • Last Post 07 December 2020
redline84 posted this 21 October 2020
Hi all,
I came across Energy from the Vacuum series around 8ish years ago.It's fascinated me since then, even though I didn't really have the means to explore further. I've come around this site every now and then as well. Lots of great information.
Fortunately, I'm in a good place now. I have the means to purchase equipment and start learning and experimenting.
I'm extremely interested in the MEG primarily, and the Bedini SSG to a lesser degree.
The core for my MEG is on order, and I am planning out purchasing the remaining items.
I'll be pouring through the threads here, lots to brush up on. Any tips or resources that you more experienced guys have that you can point me towards would be much appreciated.
Thanks!
-redline84
Chris posted this 21 October 2020
Hello and Welcome Redline8!
Thank You!
We really try to make an effort to make a difference! Many Members here are very advanced! We like to think we are all still learning, but in saying that, most here are very advanced!
The best thing to do, as you say, is read the existing threads, we have a help thread here: Builders Guide to Aboveunity Machines that is a good starting place!
There are many other, very good highly advanced threads here that are not mentioned.
If you start a Thread, share your work, we will help!
  • YoElMiCrO
Hey Munny and all,
In reference to: "architecture and design", this is a good point!
The Magnetic Field is Symmetrical in its conventional, natural form. This is important. Two Magnetic Fields opposing, in their Natural form are relatively Symmetrical also. Ideally, building Symmetrical Machines "May" be ideal, but I can not say this for sure!
In my video series, I have shown Symmetry between the Magnetic Fields:
One Coil on each side of the Core, in an even, symmetrical path, equal distance each side.
I want to stress, this is not essential, not critical! However, could be beneficial due to the following reasons:
  1. A Magnetic Field has two Poles, North and South and generally there is Symmetry between them.
  2. The Interaction between two Magnetic Sources, may be better to Act, React and Counter-React with each pole at the same time in the same space.
  3. Simultaneous Interactions at each Pole, may double the total Voltage, compared to a single Pole.
I believe there are interactions that extend past the boundary of the Magnetic Field! Observing this simulation by MIT:
Noticing, that the Magnetic Field Lines never actually touch each other, one must wonder, what makes the Electrons in the Wire act under this external influence? The A Vector Potential is the answer!
Number of atoms = N * density * volume / Molecular Weight
Ref: How many atoms are in the human head?
The Mass of 1 Mole of Copper is 63.546 grams, and there are 6.022 * 1023 Atoms per Mole. There are 29 Electrons per Atom!
One Cubic Centimeter of Copper = 8.94 grams per cubic centimeter.
In one Cubic Centimeter of Copper, we have: 84720800679822500000000 Atoms x 29 gives us: 2,456,903,219,714,852,500,000,000 Electrons!
If we were to extract these Electrons in One Second, we would have: 393734.490338919 Amperes!
This is according to the current definition of the Ampere of: 6.24 x 1018 Electrons per Second = 1 Ampere.
We can see, according to Science, we have a massive amount of Energy in Mass and this is already known! All we need do is use it!
Greywolf47 posted this 07 December 2020
This is Greywolf47, I joined the group about a week ago. I am 73 years young and live in Tennessee. I've been working on energy devices off and on for 15 years. I've been concentrating on building Figuera's device for about 5 years. I started by building the part G and using 12 volt DC for power. I used a 50 inch heating coil as the resistor and made taps the vary the current to the primary coils. I was able to get this working very well and did so great studies of magnetic flux changing at slow speeds so I could see the movement of iron filings to understand the movement of the magnetic flux. When it is sped up to 60 Hz, everything is just a vibration and very difficult to visualize. I have since learned that the part G and the resistor taps can be entirely replaced with a toroidal transformer with a center tap outut. I am using a Hammond 1182 L 30 that is 120v input with 2 30v outputs 180 degrees inverted with the zero center tap between. I am using heavy capacity diodes on each output of the toroid to get back to DC voltage at about 14 volts and 4 amps. I am running this through my coil set up that has bifilar wound 16 guage primaries with 136 turns wound clockwise on 2 inch by 1/2 inch thick laminated steel cores that are 10 inches in length shaped like a square C. The center coil is shaped like a capital i. There are 2 of the C's facing each other with the i in the middle. These are overwound with 900 turns of 22 guage copper magnet wire. I am getting 405 volts from two sets of cores wired in series.
Chris posted this 07 December 2020
Hello GreyWolf47,
Welcome! I hope you find information here, on this Forum, helpful.
It sounds like you have a very extensive setup! Impressive!
To this day, it still astounds me, that a simple helix of Conducting Insulated Wire can do so much! In combination with neighbors, it can be the source of Great Energy! Kinetic Energy, bodies in motion, like marbles down a pipe, but very much more than just a few marbles! Where 6.24 x 1018 Electrons per second past Terminal T1 is equal to One Ampere.
This astounds me! beyond Words!
This gives us a Direct Connection, a direct coupling to the Aether! Moray's Sea of Energy!
Electrons, in outer Orbitals, are where we must focus, Science has forgotten the basics, gone down a path of Vo Doo Science with no real legitimacy in its very foundation, and its time for Us, to bring them back!
Great Work, cant wait to see Images and Videos, let us know and we can help with that stuff! Its very easy now, see: Above Unity File Manager.
PM me if you need help also.
Welcome aboard! nice having you here with us!
