Charles Proteus Steinmetz - the 1st follower of Tesla?
This man's work had never been discussed before, all his books can be found on archive.org and it needs it's own platform. take it or leave it.
Chris I believe it does. watching your videos i realised the method you are using, the main Maxwell Equations for Classical Electromagnetics, are wrong and this is your alternative.
https://archive.org/embed/theoryandcalcul12steigoog https://archive.org/embed/in.ernet.dli.2015.160695 tell me I'm wrong and I'm out, no arguments
Hi Chris I dont exactly understand how your forum works I will eventually go through your tut, what I am presenting to you is nothing but the only solution to your woes I see in your video, your methods are wrong. You dont understand magnetism:
You dont understand Dielectric Current:
These are two properties of the Ether that need to be better understood if we are to succeed. Master IVO has already reproduced way above unity results, but of the Dielectric, I believe this is because of the use of only pancake coils and not BUCKED Coils :
I Believe he is mistaken on only using the Dielectric induced coils and not Magnetically induced coils. Finally the Phenomena produced in non reversed Alternations also play a specific role, as seen in George's vidoes above. Explained in : Gerry Valsilatos - Secrets of a Cold War Technology Not AC, Not DC but Discharge Current and the Control Thereof :
Everyone has a working Device producing Phenomena but nobody is perfecting it. because everyone is still using CLASSICAL ELECRTOMAGNETICS. There is not only an Electron but also a Positron Electro Dielectric Discharge Magnetic induction The control of these incommensurate properties of this phenomena is my Whole point. we are doing it wrong Thank you. Mike, posting from an underprivileged area of an African country still suffering from white oppression supported by the black governments in their pockets. here we dont know about threads or Big Buttons, but go ahead👌🏽
