Warning: Renewed push of powerful Disinformation!
  • 527 Views
  • Last Post 22 May 2026
Chris posted this 18 May 2026
I am seeing a renewed push of powerful Disinformation! Its very powerful, some with reasonably large budgets showing very stupid Experiments to get others excited and hopeful for new results on old BS that never ever once produced any results. Its a very powerful new push!
Yes, the Liars, Cheats, BS Artists and general Trolls, you know: The Spooks and Freaks, are out, trying to have one last push before they completely fail!
I will tell you: Very soon we will have:
In terms of energy, they talk about up a box with a new technology, and it gets warm, but not hot, and you get a different size box, to power a building, or to power a car, so I don't know what the box is.
It sounds like a battery.
No I don't think so I think it's a new technology but I didn't know enough when I first heard this to ask them to describe it in greater detail.
The Muppets that had control of the globe, now losing control very fast, will not be able to stop this.
Let's not forget what Floyd Sweet said to Mike Wattson:
He also says "Magnets are spaced 2" apart in traction mode The excitation coil is inside the and is bifilar and wound to cause space stress in the magnets. The excitation is very weak but apparently moves the traction flux. The kernal flux of the conditioned magnet is cancelled out at least 1" from the pole faces, the central airgap flux is made to appear and disappear in step with the space stress caused by the excitation coil."
Ref: Letter from Mike Wattson
Now we know, from experiment, that this statement was very accurate!
FYI: Traction Flux:
In classical physics and early electrical engineering literature (late 19th and early 20th centuries), the term "traction flux" (often referred to interchangeably with tractive flux) designates the specific lines of magnetic force responsible for generating a physical pulling, gripping, or attractive mechanical force across an air gap.
Depending on the specific sub-discipline of vintage engineering—whether dealing with electromagnets (relays, brakes, lifting magnets) or electric rail transit (electric traction motors)—the term carried distinct contextual meanings.
1. The Electromagnetism Context: Tractive Force Flux
In early texts on electromagnetic mechanisms (such as Silvanus P. Thompson’s seminal 1891 work, The Electromagnet and Electromagnetic Mechanism), traction flux refers to the magnetic field lines that cross directly from a magnetic pole face into a moving iron armature to pull them together.
The Mathematical Foundation
According to classical electromagnetic theory, when magnetic flux crosses an air gap between two parallel ferromagnetic surfaces, it creates a mechanical pull known as tractive force. This is calculated using a simplification of the Maxwell stress tensor:
$$F = \frac{B^2 A}{2\mu_0}$$
  • $F$ is the mechanical pulling force (tractive effort) in Newtons.
  • $B$ is the traction flux density (flux per unit area crossing the gap) in Teslas.
  • $A$ is the cross-sectional area of the pole faces in square meters.
  • $\mu_0$ is the permeability of free space ($4\pi \times 10^{-7} \text{ H/m}$).
Because the force scales with the square of the flux density ($B^2$), early designers focused heavily on concentrating the traction flux into the smallest possible area to maximize the gripping or pulling capability of clutches, relays, and telegraph sounders.
2. The Electric Heavy Machinery Context: "Traction" Motor Flux
In the literature surrounding early streetcars, locomotives, and electric trolleys—collectively known as electric traction systems—the phrase took on a slightly altered, system-level meaning.
In a traction motor (typically a series-wound DC motor), the "traction flux" refers to the primary field flux generated by the stator field coils to produce high starting torque.
Why Traction Flux Was Managed Differently:
  • Massive Starting Torque: A locomotive requires immense force to move from a dead stop. In a series motor, the input current flows through both the armature and the field coils. At startup, low speed means low back-EMF and high current, causing the "traction flux" in the stator to surge instantly to its maximum capability, creating the necessary mechanical pull.
  • The Air Gap Constraint: In standard stationary industrial motors, the air gap between the stator and rotor can be microscopic. In early rail traction motors, the air gap had to be physically wider to withstand the heavy mechanical vibrations, bumps, and debris of rail travel. Consequently, engineers had to drive significantly more magnetomotive force (MMF) through the coils just to maintain a stable traction flux across that wider physical gap.
3. Historical Distinctions from Other Flux Types
To keep their calculations clean, early electrical engineers carefully segregated traction flux from other structural magnetic fields in the machine:
  • Leakage Flux: This is flux that spills out into the surrounding air or loops back early through the housing without crossing the active air gap. Because it fails to pass through the intended armature or rotor path, it performs zero mechanical work and reduces efficiency.
  • Armature Reaction Flux: As a motor turns, the current flowing through the rotor creates its own magnetic field. In old texts, this field was noted for distorting and opposing the clean "traction flux" coming from the stator, which could lead to heavy sparking at the carbon brushes if not properly neutralized.
And for Kernel Flux:
In late 19th and early 20th-century electrical literature—particularly texts translated from or heavily influenced by Germanic engineering nomenclature (where Kern means core and Kernfluss means core flux)—the solid or laminated iron center of a transformer, inductor, or dynamo was frequently referred to as the "kernel" or "kern."
Consequently, kernel flux (often written as kernel-flux and conceptually synonymous with mutual core flux) refers to the primary body of magnetic lines of force that remains entirely confined within the high-permeability iron path to link the electrical circuits.
1. Definition and Practical Purpose
Unlike traction flux, which is deliberately forced across an open air gap to execute physical mechanical work (like pulling an armature or turning a rotor), kernel flux is intended to remain strictly inside the closed ferromagnetic loop. Its purpose is purely electrical: to maximize mutual induction between independent coils according to Faraday's Law of Induction.
2. The Physics and Mathematical Framework
In early machine design, engineers calculated the magnitude of the kernel flux ($\Phi_{kernel}$) using Hopkinson's Law (the magnetic circuit equivalent of Ohm's Law):
$$\Phi_{kernel} = \frac{\mathcal{F}}{\mathcal{R}_{core}} = \frac{N \cdot I}{\frac{l}{\mu A}}$$
  • $\mathcal{F}$ is the magnetomotive force produced by the coil turns ($N$) and current ($I$).
  • $\mathcal{R}_{core}$ is the magnetic reluctance of the iron kernel.
  • $l$ is the mean geometric path length of the iron core loop.
  • $\mu$ is the absolute magnetic permeability of the core material.
  • $A$ is the cross-sectional area of the iron core.
Because the magnetic permeability ($\mu$) of engineered transformer iron is thousands of times greater than that of the surrounding air, the magnetic lines of force naturally pool inside the iron structure, creating a highly dense, concentrated core of flux.
3. Historical Distinction from Leakage Flux
In classical literature by pioneers such as Charles Proteus Steinmetz and Gisbert Kapp, heavy emphasis was placed on mathematically separating total structural flux into two strictly defined components:
  • The Kernel Flux: The mutual portion of the flux that stays perfectly within the boundaries of the iron core and successfully cuts through both the primary and secondary windings to transfer power.
  • The Leakage Flux: The stray portion of the flux that escapes the boundary of the iron "kernel" and completes its circuit through the surrounding air space.
In early transformer design, maximizing the ratio of kernel flux to leakage flux was the ultimate goal. Excess leakage flux meant poor voltage regulation, unwanted inductive reactance, and phase displacement.
4. Constraints: Magnetic Saturation
Old engineering manuals focused heavily on the limits of the iron kernel. If the excitation current ($I$) was driven too high, the iron would hit a point of magnetic saturation.
Once saturated, the domain boundaries within the iron kernel could no longer align any further. Any additional flux generated could no longer be contained within the core matrix, causing it to force its way into the surrounding air as leakage flux. This crippled the efficiency of the transformer and generated severe thermal stress due to localized hysteresis losses.
While the historical term refers to the primary magnetic fields within an iron core, the name has been revived in modern neurotechnology; you can watch CONTROL YOUR MIND with BCI | Kernel's Non-Invasive Brain Computer Interface to see how modern magnetometers track tiny magnetic fluxes produced by neural activity.
So, I ask you all to be very careful what you see and hear by some Muppets! They actively try to get you all excited by a bunch of shiny nothings! Don't be a Kia and get Dazzled by Shiny Nothings!
Chris posted this 22 May 2026
I offer you Reason and Evidence to show those out there pushing pure Lies, are nothing but Trolls and Liars.
From First Principles, or Diakoptics, we need to derive the working principles of these machines!
For example:
Floyd Sweets VTA
The Output was in the order of 120 Volts at anywhere around 0.24 amps, or 25 watts, to 40 odd Amps, which is close to 5KWs.
We know for a fact the VTA consisted or Magnets and Coils, and Floyd Sweet referenced many time Faradays Law, so from an Induction point of view, the maximum Power Coils Impedance must have been: 2.92683 Ohms.
Defining Operating Requirement
The VTA, Vacuum Triode Amplifier operated at 60Hz, but at one point we saw 62Hz on the Counter, with an Input of 10 volts and a Current anywhere from 7 Micro Amps to 33 Micro Amps. The Output was in the range from 25 Watts to 5+ Killowatts.
The fact that the VTA, Vacuum Triode Amplifier operated at 60Hz, but at one point we saw 62Hz on the Counter, also provides another nail in the grave for the "Conditioning" Hoax. This means, the input Frequency was tunned to 60Hz, which shows a Resonance of sorts was important, as Floyd's other machines operated at 403Hz and 388Hz.
The Requirement is:
  1. The Input Coil is Driven at 10 Volts.
  2. The Output Power is not Inductively Coupled to the Input Power. E.G: Output Power Draw has almost no effect on the Input!
  3. Bucking Coils, which Floyd Sweet referred to as Bifiler coils were the main focus on all of Floyd Sweets work.
Evidence to support the Requirements
Question: Is there any experiment that can show some or all or the above Requirements in an Electromagnetic Machine?
Answer: Yes, we have experiments that show most of the Requirements, from Start to Finish in our work.
Floyd Sweets papers, the papers he wrote and gave to his colleagues, and that made their way out to the public, also support Electromagnetic Induction, and make no mention at all, ever, anywhere, of Materials Science and "Conditioning" his permanent magnets. This, except for one line at the end of Floyd Sweets Paper: Nothing is Something
The fundamental magnets have been broken free of their binding forces which constrained them to be steady-state single pole uniform magnetic flux devices. They are now able to simply support mass, as demonstrated with the  transformer steel illustration. They can now easily be made to adopt a dynamic motional field by applying a tiny amount of excitation. Specifically, 10V @ 1 mA (10 mW) of excitation at 60 Hz. will enable the coils of the triode to  receive from the Dirac Sea in excess of 5000 watts of usable negative energy; how much more can safely be removed has not yet been determined.
This paragraph is the only mention of: "magnet conditioning" that Floyd Sweet ever wrote. There is no mention anywhere at all, of anything even close to this statement, or related topics! Zero mention of any materials Science, nothing. Zero mention of the Barium Atom! Nothing! Floyd Sweets Number One focus was on Electromagnetic Induction, Voltage and Current.
Magnetic Resonance provides us the answer we need, to solve the Requirements above:
You will note, this is exactly the same as Floyd Sweets original diagram:
Reasoning using First Principles for the Conditioning argument
We know and can very easily prove, that "IF" Floyd Sweet "Conditioned" his Magnets, the "ONLY" way a Stationary Magnet can Induce a Voltage in a Coil is if the Magnet's Poles change from 800+ Gauss North to 800+ Gauss Sound and so on at 60Hz.
We know for a fact, that Floyd Sweet did not do this in his video, he focused entirely on the Lateral movement, or the Sweeping left to right of the Flux, which again, we can prove from experiment, does not induce any Voltage at all in the Coils that were entirely under the Pole face of the Magnets. We know, the Flux Cutting the Coil "Must" have a difference in Gradient to induce a Voltage:
There you have proof, that Laterally moving Flux, from a uniform source, does not Induce a Voltage in a Coil! So there is proof one that Conditioning is a Massive Fake Ruse, a Hoax, a Red Herring!
We know, we have Video Evidence that Floyd Sweet turned on his VTA by switching on the Oscillator:
Now, if the Magnets were Conditioned, like I explained above, the VTA would always be on, and never be turned off. So there is proof two that Conditioning is a Massive Fake Ruse, a Hoax, a Red Herring!
Reasoning using First Principles for Simple Electromagnetic Induction
A small Voltage applied to the Input, 10 Volts, started the VTA, the VTA came to life, the Output instantly operating, applying a Voltage across the Load and a Current through it.
