We have working Energy Machines!
  • 640 Views
  • Last Post 02 January 2024
Chris posted this 01 January 2024
The first and MOST IMPORTANT Step to Energy Machines, is learning How Energy is Generated!
To Power a Load, requires a Voltage and a Current, these are very specific, measured quantities of Subatomic Particles, specifically, One Volt equaling: 6.241509 x 1018 Electrons on one Terminal and Zero Charges on the other Terminal, thus a Difference in Charge, a Potential Difference, and One Ampere equaling: 6.241509 x 1018 Electrons past point P1 in one second. Thus, you can see, Electrical Energy, like a Flow of Water, is Volumetric in its Nature. Meaning, we have a Magnitude, or a Volume, and a Rate of Velocity.
I have been through that in my Series: Chris's Non-Inductive Coil Experiment
You need to know this, its the first and most basic step, to making Energy Machines that Work and are Practical! Here, I lay out the basic procedure:
A Voltage is Generated
Voltage is the Accumulation of Charge, Elementary Charge Carriers, that are separated from Source, the Atom, and Separated Negative to One Terminal and Positive to the other Terminal! This is known as Charge Separation!
The electron and the proton are the elementary charge carriers, each carrying one elementary charge (e), of the same magnitude and opposite sign.
This is a very well known process in the Scientific Community, the best Video showing this is this one:
I have made a Series on this: Electrical Energy 101 - Faradays Law of Induction
On Wikipedia, you will see:
In electromagnetism and electronics, electromotive force ( also electromotance, abbreviated emf, denoted ε or ξ ) is an energy transfer to an electric circuit per unit of electric charge, measured in volts. Devices called electrical transducers provide an emf by converting other forms of energy into electrical energy. Other electrical equipment also produce an emf, such as batteries, which convert chemical energy, and generators, which convert mechanical energy. This energy conversion is achieved by physical forces applying physical work on electric charges. However, electromotive force itself is not a physical force, and ISO/IEC standards have deprecated the term in favor of source voltage or source tension instead ( denoted ∪s ).
Majority of this text, is complete Non-Sense! It is a misrepresentation to analogies that are not understood! In point of fact, the misunderstanding is non-sensical in itself!
Honestly, how is Mechanical Energy converted into an abundance of Electrons / Protons / Ions? NON-SENSE!
Truth is, the Copper Atom, having 29 Electrons and 29 Protons, is the source of Charge:
You can see, the Copper Atom itself is a source of Charge, and the Magnetic Fields, the Source Magnetic Field, moving, in Time t, Strips away the outer Electrons, Free Electrons, and Separates them, Positive to one terminal and Negative to the other terminal. Thus we have Charge Separation occur, a very well known and already well explained effect:
This is well known!
A Current is Pumped
It is very well known in Quantum Physics, that Electrons pop up to a higher orbital, if they are put under pressure! This is no secret! This means, with enough pressure, we can move all 29 Electrons of each Atom to the Outer Orbital if we wanted to, if we could put the atom under enough pressure!
This Pressure can be seen, observed quite simply, by using a Copper Tube and a Permanent Magnet:
The more Electrons pushed up to Higher Orbitals, the more Electrons can be stripped and accelerated down the Wire as a Flow of Current!
Here, we can see, a Current is Pumped, the Magnetomotive Force of the Permanent Magnet falling, creates a Current in the Tube, making the Magnet fall at a slower velocity, because there is always Opposition to the Source Magnet! This Opposition is the Pump!
Why is conventional Electromagnetic Induction not Above Unity?
Why is current Electromagnetic Induction not Above Unity? The answer, simply: because as it stands, Electromagnetic Induction is entirely Symmetrical, Two Magnetic Fields: M.M.FOne + M.M.FTwo = Zero, or Output = Input - Losses.
Two Magnetic Fields give you a Magnetic Field Vector Equation of: 1 + -1 = 0.
The Input Power into a Conventional Transformer is always the Primary Current Pumping Mechanism, lets say is: 10 watts, the Output on the Secondary Coil is: 9 Watts, this makes the Transformer 90% Efficient! Not a hard, or difficult feat today!
The Input Coil is loaded more and more, in other words, the Input Coils Impedance drops and more Current Flows in this Coil, the more we load the Output Coil, as we draw more and more Current on the Output.
How do we make Electromagnetic Induction Above Unity?
We need to introduce Asymmetrical Electromagnetic Induction, our Input Coil can not be the Primary Current Pumping Mechanism, which I already have done, its very simple, first you need to understand Partnered Output Coils:
Partnered Output Coils give you the ability to make Electromagnetic Induction Asymmetrical! This gives you Three Magnetic Fields, we see: M.M.FOne + M.M.FTwo + M.M.FThree = M.M.FThree, thus we get: Output != Input - Losses. The Output = Design Specifications - Losses. In other words, the Output can be infinite essentially! Because we are directly accessing the Subatomic World, and Pumping Charges directly from Source, and we are doing so, using Magnetomotive Forces, arranged in the same fashion as the Hydraulic Ram Pump:
Three Magnetic Fields give you a Magnetic Field Vector Equation of: 1 + -1 + 1 = 1.
Each Partnered Output Coil becomes the Primary Current Pumping Mechanism for the other Partnered Output Coil, the more we load the Partnered Output Coils, the more MMF, thus the more Primary Current Pumping occurs! Floyd Sweet said:
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.2418 electrons⁄second. Thus the duty factor of the copper changes. I2R Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load. This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field. Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
Now, you see why Floyd Sweet made the statement! We understand how this can occur!
Partnered Output Coils must Generate their Voltages
Partnered Output Coils must Generate their Voltages using the very same techniques as Faraday already explained! Floyd Sweet told us this already:
 The induced voltage in the winding obeys Faraday’s law as quantified by Neumann Eav Φ / t x 10-8 v. This is average value and must be multiplied by 1.11 form factor RMS effective volts.
Ref: Floyd Sweet - The Space Flux Coupled Alternator
Lets think simply about this for a minute, lets say Partnered Output Coil One, or POCONE, represents a Permanent Magnet in a "Generator". We know its Magnetic Field Density and Strength and we know its Velocity.
We can calculate this!
Paul Raymond Jensen said:
The magnetic flux from the two secondary windings cancels in the "outer leg circuits," leaving only one-quarter of the total flux generated by the output current to react back upon the primary. This resulted in a current gain in the secondary, relative to the primary. Lenz's law was bypassed, and free-energy resulted. An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields.
Ref: Paul Raymond Jensen
We know Floyd Sweet studied Paul Raymond Jensen:
Referring to the Jensen machine stated: natural magnetic resonance freq = 2.80GHz the nuclear magnetic resonance of a free electron when charges in magnetic states are induced by magnetic field the changes in states causes a condition called electron paramagnetic resonance, or EPR. The EPR of a free electron is 2.80 H MC. Where H is in gauss. This should be the initial state of the defining mathematical format.
Dealing with Resonance at High Power Levels.
Resonance frequencies may be maintained quite constant at high power levels so long as the load remains constant. We are all familiar with AM and FM propagation, where in the case as AM, the voltage amplitude varies, and with FM, the frequency is modulated. However, the output power sees a constant load impedance, that of the matched antenna system. If this changes, the input to the antenna is mismatched, and standing waves are generated resulting in a loss of power. The frequency is a forced response and remains constant. Power is lost and efficiency becomes less and less, depending on the degree of mismatch. Let’s assume the Jensen amplifying transformer is in a resonating condition. Its output is connected to a transmission line which is X number of miles long. Without any customer load at all, power will be required to change the line.
Ref: Floyd Sweet - Magnetic Resonance
Many just don't see how and why this works, we have it working, many have replicated this successfully!
Proof, and the Dumb Dumb Club cant see the Forest for the Trees! When too many Idiots flood the Forums, they make a mockery of the Truth! Right here, it's been here for nearly a Decade, you can SEE The Truth:
Cite: Master Shi Heng Yi
Tinman was the first:
Lighting up the Darkness!!!
Many low life losers try very hard to keep this away from you, they lie, mislead, misdirect, and just outright troll you about it, fact is, it works!
Chris posted this 02 January 2024
Above Unity = COP > 1.0 = Free Energy Machines
Just like every Conventional Generator in existence today, in the same way they Generate Electrical Energy,
Partnered Output Coils do it the exact same way! The Rotor, on the left, is POCOne and the Stator, on the right, is POCTwo, each Generating each others E.M.F and thus Pumping each others Current! We simply have an Electromagnetic Charge Pump! Solid State, no moving parts!
The Input Coil has a mutual Coupling of Zero, because the Input Coil sees a Net Force of Zero, thus the Input does NOT Generate the Output! No Load is exerted on the Input Coil! We have circumvented Lenz's Law, we have a Free Energy Machine!
This is very simple, no complexities need be introduced here, although the mind seems to have a tough time with it for some reason!
Stress, Opposing Magnetic Fields, Bucking Magnetic Fields, Pump Charge, Charge is Accelerated down the Wire!
