We're Back, Better, Faster, Stronger than ever!
  • 1.3K Views
  • Last Post 31 December 2018
Chris posted this 07 December 2018
Our recent problems with Crazy Domains is over.
Intermittent session timeouts should be a thing of the past! Site Downtime should now be minimal!
We have a Dedicated Server:
My Friends, I am sorry for the recent problems. We should now be able to continue, and I would like to apologize to Vidura, Prometheus, Zanzal and others with recent Threads that have been disrupted.
My Friends, lets continue and show the world what's possible when we work as a Team!
Vidura posted this 07 December 2018
Great, it work's fine now. Really much faster and stable. Thanks for the effort ,Chris!
Cornboy posted this 07 December 2018
Looking Good Chris Thanks,
 Cornboy.  smile
Marathonman posted this 07 December 2018
Life is always better with a fast processor.. my computer has a 3960X processor, 16 gig DDR3, 2 Kingston Hyper X SSD's, three 2 terabyte back up and storage on a Gigabyte Motherboard.  unfortunately my Asus board Died so i had to use the back up.
My server/Firewall is an 8 core C 2758 Atom proc with 32 Gig DDR 3 mem with three 2 terabyte HD's.
Thanks Chris, life can be much better when one is dedicated to one's conviction.
Jagau posted this 07 December 2018
thank you chris for everything you did
i greatly appreciate.
Jagu
alohalaoha posted this 07 December 2018
Thank you Chris
Finally you made it - got one DED.
Keep the fist up Chris !!
Take care and good luck
Thank You for all your support!
WOW, Aboveunity.com is amazingly fast and so much easier to use now! It has that feel, fast, stable, and reliable now, I just didn't feel that before! I am a very happy man, to go from a bad situation with endless problems, to a fast stable and WOW Website is great!
Thank You all! I really appreciate your patience and support!
wow really faster, great
Prometheus posted this 08 December 2018
Loads pretty fast and I don't have to log in again every time I try to post. OnTheNet seems to be much better than Crazy Domains.
Load time for 493 KB landing page could be improved, as the connection negotiation process seems a little slow (the first byte was delivered at 1.105 seconds, first-paint was at 2.769 seconds and the page had a total rendering time of 5.2 seconds due to slow connect on loading images).
You could also look at compressing the code... the images seem to be compressed pretty well, the code not so much.
You've got 13 requests out to gravatar.com, not sure what those are for. Seems to be a bunch of small images of various geometric designs. Doing away with those would lower load time by ~0.707 seconds.
You've also got 9 calls out to revolvermaps.com, which is a javascript geoIP widget showing the connections on a rotating globe... you might nix that to reduce load time by ~1.798 seconds.
So you could reduce load time by ~2.505 seconds, bringing total rendering time down to a super-fast ~2.695 seconds.
That'd also lower the server load and bandwidth, so if you're on a bandwidth-limited hosting plan (where you pay more if you go over a certain bandwidth total usage) that'd be a boon.
Chris posted this 08 December 2018
Hey Prometheus,
Thanks, excellent suggestions!
I think the actual page is loading much faster than before. External Domain requests are always dependant on may other factors. Hard to regulate those factors.
However, the reported 5.2 seconds is far too slow. I will look into connection load.
P.S: After a little testing, I am getting around 2.6 seconds, full load time. Is anyone else getting slow load times?
Use F12 for developer tools. Go to performance and reload the page. Look for start, Blue in Edge, Load, to page finish.
I am no web developer, however, I do try to know a bit about it, even if I do fumble through it now and again.
F12 on your keyboard will give you developer Tools. You should see a "Performance" Tab. If you hit the Green Play button, and then refresh the page.
Once the page is fully loaded, give it a little longer, just to make sure, then hit the Red Stop button. Then analyse the data. Look for the HTTP Request: (/) - This is the initial request. It looks like this:
The time is around 4.5 seconds, where we refreshed the page. Now look at the page Paint, the last one, after the Layout and before the Garbage Collection. It will look something like this:
The time is around: 6.6 Seconds. So we have a page load time of approximately: 6.6 - 4.5 = 2.1 Seconds. The time will vary, it may be longer sometimes compared with others. But, please let me know, this is important to me.
Critically, we have fixed the Session Timeouts. I was getting so annoyed with that problem!
Please keep me updated on how this is going for you, on your end!
P.S: Prometheus or Zanzal may be able to provide an easier way to do this assessment of Page Load Time.
P.S:
Mostly for Prometheus, can you try the pages again please?
I have done a Server Connection Speed Test and its pretty good for Australia:
Now, of course, other countries have many Gigabits per/second. So we are slow in comparison. However these speeds should be very good for My Website. Its only small and most of the content is Text/PDF/Images.
Refreshing the page will show a faster load time, since some of the code is loaded from the browser cache. Your best bet is to flush your cache and load the page from the server to get a good idea of the total rendering time.
Not sure if you need the forced reflows, but if not, doing away with them will decrease rendering time. I count 11 forced reflows.
Look in your Performance Report for any red triangles on the upper-right corners of the timeline boxes. You might have to zoom in to see them.
There are several website testers online. Here's one I ran:
https://gtmetrix.com/reports/www.aboveunity.com/wMQAhbwv
Hey Prometheus,
Yes, thanks for pointing that out. Perhaps I should put some time aside and try to resolve some of those little issues soon!
Issues aside, its faster and more stable now for you?
P.S: Gravitar are profile images I believe. This is third party software. I only modified an original package as you already know.
Yes, faster and more stable.
I was surprised when I got home from work today and I was still logged in! Before, I had to log in again due to the intermittent time-out problem. Thus far, no problems on the new server.
That's great to hear! Excellent!
Any advice, if we can fix those issues you mentioned without to much hassle, would be much appreciated!
So far, I am very happy, very happy!
Chris posted this 13 December 2018
I am SO HAPPY with the way our forum is now running! This is a magical experience.
Our progress is great. Some are reporting great successes, both here on the forum and through private message.
It is a real pleasure to be here with you, at this point of time!
Already we have changed the world!
Jagau posted this 13 December 2018
Hry Chris
We are a wonderful group.
I can not wait to tell you that, I took a big step yesterday.
Chris posted this 14 December 2018
Awesome, great to hear about your progress!
Chris posted this 28 December 2018
I am absolutely loving the stability and speed!
We have had a lot of problems, email, session timeouts, posts being lost, slow problems.
Getting rid of Crazy Domains is the best thing I could have done! What a waste of money, time and it cost us members also!
Thanks for your patience, but we now have our result!
alohalaoha posted this 31 December 2018
Happy New Year to Chris Sykes and all members of >1 forum!
