Words of Wisdom
  • 828 Views
  • Last Post 25 April 2017
Chris posted this 20 April 2017
I think it is so important to Reference and Cross Reference, Hard Data, Undisputable Data can be obtained by this method!
This is just three examples of many! Floyd Sweet, Clemente Figurea and many others have all said the same thing.
The portions of the Electromagnetic Cycle need to be thought about. The Electromagnetic Cycle needs to be thought about:
Chris posted this 22 April 2017
Hi Cd_Sharp - Yes Right - Voltage is only a Potential Difference, it is the Potential for Current to Flow and is necessary for the Current Flow, but...
For Time Changing Electromagnetic Energy, we can have Voltage Potential with no Current and we can have Current with no Voltage Potential, its just phasing.
However, on the Terminals of an Electromagnetic "Generator" we can have a Voltage Potential Difference and not ever have a Current Flow, E.G: The Switch is Open and no Current can Flow.
In saying this we can not have it the other way around! As far as I know, there exist's nothing in Nature where we can have a Current Flow and No Potential Difference, or Voltage, a Voltage or Potential Difference is Necessary for a Current to Flow.
A Current Flow is the Magnetic Field, they are one and the same things!
So by working with the Current Wave Forms we can better visualise the Magnetic Fields in our Devices!
For it is the Current, and the Work that Current does, but not in the Form of Current, in the Form of Magnetic Fields, remembering that the Current and the Magnetic Fields have a 90 Degree Shift in the Electromagnetic Spectrum, that does the Work on the Charges in the Wire, Separating more Charges as More Current Flows:
The Electric Field is often thought of as a Voltage, however its not, it is Current Directly as pointed out! Current and the the Magnetic Field are in Phase (Mostly) in Time, but Orthogonal in Space! Or 90 Degrees out of Alignment in the Cartesian Plane.
Chris posted this 23 April 2017
In the Following diagram:
We can see, from Zero (0) to the Green Arrow, we pay for a Magnetic Field in the Form of Current, applied Voltage and the Current then follows, or Power (V * I  * Cos(theta)) - This process is unavoidable, its the cost we have to pay for the Magnetic Field - B = NI/L
However, from the Green Arrow to Zero (0) We have a period of Zero Cost - We have a Decreasing Magnetic Field and often Power coming back out of the Inductor @ 1/2 LI2
This Time Frame can be utilised, it is an Open Door for Maximising the Electromagnetic Induction occurring in our System!
Why? Because this is the Point we have Maximum Magnetic Field for the Total Input We have put in! - This is a very important time to use!
Chris posted this 25 April 2017
Hi Cd_Sharp - Yes
There are many ways to approach this, many ways work! Another example is Tarial Kapanadze and all the replications of his devices. At this point, the Green Arrow, a very sharp Pulse is injected:
The Spark Gap, when it fires does this at the Wave Peak, is at the Peak of this LC Resonant circuit. Nikola Tesla, whom Tarial Kapanadze gives Credit to for his devices and also Andrej Melenchenko for his work:
Whats the significance of the Peak Wave?
  • We have a Magnetic Field Changing in Time.
  • We have a Current in the Coils
  • We Induce excess Electromagnetic Induction
Another example of this Peak Trigger is Ruslan Kulabuhov:
We don't always need this Peak Trigger, some devices can be configured to Start the Excess Electromagnetic Induction Process at this point however. This is the Point of Balance, where we can choose to Do More if we want to!
 So, from Zero to Wave Peak we pay for, this is our Input, at Wave Peak we can then take advantage of methods of Excess Energy "Generation" or Electromagnetic Induction, all methods we already know very well, Partnered Output Coils or some call them Bucking Coils.
