Another PureVPN Outage
  • 713 Views
  • Last Post 13 May 2022
Chris posted this 12 May 2022
I am so sorry, we are having another VPN Outage! PureVPN is just the most difficult to get support from now!
It appears the PureVPN Authentication Server has some issue at the moment. Its been approximately 5 hours now.
I have contacted support, but since they changed their support methods, it takes a day or more to get to anyone! Also, if you get Useless Support, they brush you off, trying to tell you its an issue on the clients end, and then you have to wait another day or more, to only hope you get someone that has a little bit of a clue ๐Ÿ˜
Once Starlink is setup to provide Static IP Addresses, this will entirely avoid the problem, and we will no longer need to have a VPN! I cant wait for this day! It will save So Much Time for me! I would spend 2 to 3 hours a day monitoring, reconnecting and managing the VPN Connection!
The slightest Internet Interruption, dropout, or outage, the VPN becomes an issue, sometimes easy to get back online, sometimes not so easy. It gets time consuming when the VPN Session becomes locked, and I can no longer connect back to the VPN Server and obtain the correct IP Address. This makes the Site go offline for extended periods from time to time, along with many other issues we have also experienced.
Again I am sorry for this inconvenience!
Chris posted this 13 May 2022
Oh my goodness, some of these support staff are just useless, not worth a bucket of dung:
Thank you for reaching PureVPN,
I see, I can certainly understand your concerns and I apologize for any inconvenience...
Question: May I know are you using username credentials or email credentials log in on your PureVPN application?
If you are using email credentials to login then and you are getting the authentication error then it is requested that you please reset your password and try again to log in, please: https://my.purevpn.com/forgotpassword
Steps:
Click on the forget your password link above and then insert your email on the column shown and click submit, then go to your email inbox or spam folder and check if you have received any email regarding PureVPN reset the password, click the link available on the email and then it will redirect you to the password reset process where you have to reset your password and confirm the change.
If you are using the username credentials then it is requested that you please login to your member's area and verify the username credentials again and then try login again and check.
Please follow the steps mentioned below to find your Username( purevpn0sxxxxxxx)VPN password and use it for every VPN connection..
Here is the link for the member's area: https://my.purevpn.com/v2/dashboard/subscriptions
From the left tab click on 'Account and Billing'
Click the drop-down arrow (แฏ)
Click "Show/Update/Change VPN Password"
Click on ๐Ÿ‘๏ธ to reveal the password
Use that password along with a username
Guide: https://support.purevpn.com/how-to-easily-find-your-existing-vpn-password
Feel free to contact us for further assistance.
Rafael
Now, as you know, I have been connected to PureVPN for some 9 months!
So, all of a sudden, why would anything on my end change? Especially Username and or Password? Even so, I have checked it on multiple machines already and its the same problem ๐Ÿคจ
I think Rafael has his head on backwards today!
My Reply:
WTF!
I gave it all to you!
<My Email Removed for security>, which you sent this email to! Fix the damn problem and stop procrastinating!
I get so tired of others that are morons! I have waited nearly 24 hours for this response!
A quicker reply this time:
Thank you for considering PureVPN for all your online security needs. We understand how you feel about the situation and we're sorry for the trouble this has caused.
It seems that there is some issue with your current dedicated IP shall we assign you New dedicated IP for same location please confirm so that we may take accordingly.
Feel free to contact us if you require any further assistance.
We are here to help!
Travis
Again, the same problem as last time, unbelievable isn't it!
My Response:
Please do what ever you need to do to fix the issues I am having.
This is urgent, its currently mission critical, so quick as you can please.
Get the feeling, some low life, deplorable drop kicks, are interfering with our Success:
Dear Customer,
New IP has been assigned on your username, details have been sent on your email, please logout and login using and recheck your results and let us know.
Feel free to contact us if you have any questions.
Simon
Melendor posted this 13 May 2022
Hi Chris.
Sorry to see that you are having trouble with them.
Indeed the Support nowadays is not what it used to be in the past.
I hope for the best and hope that you will get a Starlink static IP as soon as possible.
Best wishes
~~~Melendor the Wizard
