Partnered Output Coils are just a Blocking Oscillator
  • 965 Views
  • Last Post 10 January 2024
Chris posted this 03 January 2024
Partnered Output Coils are simply a Blocking Oscillator in their basic Function, the difference is, they require Power to be Drawn to make them become a Blocking Oscillator in their basic Function!
In the Thread: We have working Energy Machines!, and in many other threads also, I have shown you exactly how Electrical Energy is Generated and Pumped! Now, we need to observe, Partnered Output Coils become a Blocking Oscillator, when in Magnetic Resonance!
Because Partnered Output Coils Buck each other, the same way a Blocking Oscillator uses the Bucking function of the Coils to Oscillate at a specific Frequency, Partnered Output Coils do the exact same thing!
The same as Floyd Sweets VTA, Vacuum Triode Amplifier, where a Triode is a form of Diode, the Triode was a Gate for the Vacuum, or a Gate of the "Orientated Space Quanta", the terms Floyd Sweet used, clearly was Generating Electrical Energy, simply by Operating with a Load attached to the machine!
Triode definition:
A thermionic valve having three electrodes.
This is why Walt Rosenthal said:
The VTA "likes" to always see a minimum load of 25 watts.
And to shut down the machine:
The operation is stopped by momentary interruption of power to the power coils.
It is not hard to see, that the very Extraction of Electrical Energy, use's the Magnetomotive Forces as a Blocking Oscillator, as the basic function! Partnered Output Coils must Buck, in their very action! Bucking, shown by the big Red Arrows, is a very important aspect to the Energy Generation of these machines!
The Blocking Oscillator is a very simple circuit, and most of you will be well aware, the Joule Thief is a Blocking Oscillator:
NOTE: All Partnered Output Coils need, are Diodes, no other Circuitry is required, except for on the Input Coil, the Input Coil is your Input Excitation, the Partnered Output Coils do the rest by themselves and by your chosen design specs! Partnered Output Coils use Asymmetrical Electromagnetic Induction, which we have shown and proven, as the Source of Energy!
What are the basic requirements or specifications for a Blocking Oscillator to work, can we apply the same basic principles? I have given you all a thread: Coil Geometry which will help you further!
Chris posted this 06 January 2024
I am very surprised, in all the time we have been working on Partnered Output Coils, I am very surprised, not a single person has ever worked on, and calculated the Magnetic Fields, not even using the free Aboveunity.com Member only Calculator, I have provided free? Why is no one working on the most fundamental aspect of these machines? I have Threads on this topic, Videos and I make comments on this topic all the time!
I have said many times, get your voltages up and your Current will follow, Get your Magnetic Fields Up, and many other comments like these.
Yes, I agree, there is a lot to learn in this field! Because High School and university education is pretty much as basic as basic can be in this field, it really is very poor, no doubt for the reasons we have already laid out to you all, because they don't want you to be versed in Magnetics because it is the primary area for us to be able to Break Science! At least point out major Holes!
Science is Incomplete and all Scientists that have not been brainwashed to hell and back, will admit this Fact!
So, You need to work on getting your Magnetic Fields Up!
Coil Geometry is the best thread to learn how to do this!
Energy Density is linked to this very topic, because the Higher the Magnetic Fields, the more Energy Density there is in the Machine!
Coils are very simple, but yet can get complex in the Scientific understanding.
Bucking, the SLAP, the Opposition of Partnered Output Coils is a critical thing to study:
We were all told, its very simple not hard and not complex:
It truly is! This is exactly true!
All of the answers, I have given you, right here, with many videos showing you working machines:
Proof, and the Dumb Dumb Club cant see the Forest for the Trees! When too many Dumb Stupid Idiots flood the Forums, claiming to be Guru's, and the truth is, they have no idea what so ever, they make a mockery of the Truth! Right here, it's been here for nearly a Decade, you can SEE The Truth:
Cite: Master Shi Heng Yi
I have provided an entire Thread: Chris's Non-Inductive Coil Experiment and 11 videos on this showing you how to approach this Technology! I have given you all of the data to make this work, and more, to make this, not just a TOY, to make this Power very much more than just a few Globes!
My Friends, when I see 10 successful replications, I will release another Video showing a bit more work, again we have had quite a few successful replications already!
Do the Math in these videos! COP > 1.6 in both Machines!
Technically, My Friend Wistiti was the first, but for undisputable numbers, we have to see Tinmans effort.
Tinman was the first: COP = 1.7
Others followed, like Captainloz: COP = 1.9
If people watch your videos its all in there. My experiment is proof of that. I was feeling very frustrated for a long time but then I stumbled on to your youtube channel and it inspired me to keep going. I actually have your book from way back, I wish now just stayed with it but I went down the Ruslan and Akula rabbit holes for too long without understand Asymmetry and the re-gauging process. Anyway mate I'm just trying to say you should be proud of yourself. You are doing a great thing here!
Cheers,
Loz
Ref: Captainloz COP = 2.0
COP = ∞
Lighting up the Darkness!!!
Many threads explaining to you how it works!
YOU CAN DO THIS, we will help you!
Chris posted this 10 January 2024
A small experiment, and you should see many similarities in this arrangement:
Here, you can see, I have a single I lamination, sitting in place, cut from the I Laminations I shared here.
In this configuration, I will have a small gap in the middle, 2 or 3mm gap between top and bottom POC. I have shown this arrangement before, here:
In this very early series, I show you how the VTA Worked:
I showed you how the blocking, or the gating part works:
NOTE: This was released Nov 5th 2013! WAY before anyone else was even remotely thinking about the Magnetic Diode, Magnetic Gating or anything similar!
