PROJECT: Project Welcome Swallow
  • 683 Views
  • Last Post 19 August 2026
Chris posted this 27 July 2026
Lets start a Fun Competition: Project Welcome Swallow
Project Welcome Swallow, will be a Competition for all entrants to show the best POC Bucking Experiment!
Entrants must register here, put down and agree to the competition, "Name, Yes I want to enter and I will have an Experiment ready by the Due Date" sort of thing.
Entries that have not Registered will not be accepted.
Due Date: 21 August 2026.
You must create your own thread, post your own work, Text, Images and Video, including Circuits and test results. Votes on entrants Experiments will determine the winner. I will enter, but will take myself out of the draw, so everyone has a fair chance!
If you're all keen for this, I will put up Prize money for top three Threads.
This could actually be a bunch or fun eh!
  • AETHERIC_MIND
  • Drasko
Chris posted this 29 July 2026
I was thinking of deleting this due to lack of interest. No one interested?
Floyd Sweet said something that caught my attention:
In the specific case of positive charges moving to the right and negative charges to the left, the effect of both actions is positive charge moving to the right. Current to the right is: I = da+ / dt + da- / dt. Negative electrons flowing to the left contribute to the current flowing to the right.
We saw this in the Mr Preva Experiment. In saying this, there are a lot of problems, getting the Voltage up to a Usable Number, where the Bucking Fields can actually do useful Pumping of Current is another problem in itself.
I thought this thread and competition, I thought might be a good way to figure out the best method. I know of a few ways, but do not know all, that's for sure!
  • Drasko
FringeIdeas posted this 29 July 2026
Hey Chris!
Yes this definitely sounds like a cool idea. Would be nice to see what other people come up with, see some things from a different angle etc. Though maybe a lot of people just want to stay quiet?
I myself have just been super strapped for time lately, which is why I have not spoke up to participate. I think maybe next week some time I'll have a better idea of my availability. I will update.
Thanks,
  • Drasko
AETHERIC_MIND posted this 29 July 2026
I'm  definitly interested to be part of the ''competition'' of bucking expriment to make voltage up. It will be very helpfull for everyone to participate.
Are we gonna have the same experiment at the same time or multiple setup in competition?
We have seen the voltage up by interrupting the conduction of one coils in an sychronous rectification on the Magnetic implosion generator of Graham Gunderson. This technics is one that you already know. It's all about NON-Linear inductance at the right moment.
But there is a problem of motivation to reach the final goal of useable output over the input. I know that Aetherholic's was able to achieve such thing and it greatly motivate  other and me to go further.  On your side, you are offgrid and you are able to generate enough electricity to be autonomous. Need motivation of what is capable of, without explicitly putting numbers.
Thx for the futur great competition.
''Change is never easy but it's worth inertia''
  • Drasko
Oh good, I am glad you're interested in this. Yes, I think sharing ideas, will help move past the Stale Phase we seem to be in as a community. If we get enough interest, this could be quite beneficial to all of the community!
@Marcel - Hope you get some time free up soon Marcel, we are always busy, its a tactic they use against us, and we always allow it, because that's life for 99.99% of us now.
@AETHERIC_MIND - Yes you're right, the concept of "Synchronous Rectification" is a valid method to move forward, and as you point out, first was Graham Gunderson, then Tinman, perhaps by pure luck, and as I understand it, he has not been able to make anything work quite like the RT V3 since.
If I may, posted before:
A long time ago, in a galaxy far far away...
Ok, not so far away actually back here on Earth, at my home, I do the Vacuuming around the house. A long time ago I went to press the on button on my Vacuum Cleaner and just tapped it with my foot, fast and not with a solid push, and my Vacuum cleaner popped, a hydraulicing and a arching noise and no more Vacuuming on this particular day...
As a kid I always took everything apart, never got anything cool or expensive for Xmas or birthday because I "destroyed" everything, always interested to see how things worked, so true to nature I explored this popped vacuum cleaner...
I took the Vacuum Cleaner apart. In the housing I found a wire had completely disintegrated, about a centimetre and a half, completely gone, nowhere to be found. It was right on the terminal, off one of the Stator Coils.
I very much wish I have documented this, took pictures and so on, but alas I did not.
Many I have told do not believe me about this.
Anyway, sure enough the Current to achieve such a thing must have been huge, more than the 10 amp fuse could bare to handle, but no fuse popped, in-fact a closer look at the power board showed no sign of anything strange going on. This issue was completely isolated to the Vacuum Cleaner as far as I could see.
That feeling inside, when you see something and seem to have an immediate understanding, I got that, mentally seeing a large Magnetic Field Build, and because I did not switch on properly, a huge collapse, and the Could just happened to be in a configuration that shorted the huge collapse back on itself.
Thus, a huge "Generation" of Electrical Energy...
Many years later, I learned that an Antenna can sometimes see a similar thing under certain circumstances. Very high Currents can occur and then at a particular point, there is a Burn Out...
Over the years learning more and more, connecting the dots, I made progress and understood more.
I hope this gives some insight as it did for me!
Ref: Charge Separation
Here are Diagrams of the universal motor:
Now, if you take this image, and when you understand that the Rotor Coil Opposes both Stator Coils, and if one imagines a very large Magnetic Field Build up, then a Collapse, and again the Opposition, then one MUST take into account the "Generation" of Electrical Energy, exactly the same as a "Generator" or a Transformer "Generates" its Power.
Lets not forget Floyd Sweets original Schematic:
If we combine this image with this statement:
Then I think we have a pretty good basis for understanding, especially when you also understand the Mr Preva Experiment, we get an idea on what Floyd Sweet was thinking. Truly, he was fixing to Break Symmetry, moving toward an Asymmetrical System!
We do know from Antenna Theory and Experiment, that the Coils must be Excited at the Resonant Frequency.
Resonance frequencies may be maintained quite constant at high power levels so long as the load remains constant. We are all familiar with AM and FM propagation,  where in the case as AM, the voltage amplitude varies, and with FM, the frequency is modulated.
However, the output power sees a constant load impedance, that of the matched antenna system. If this changes, the input to the antenna is mismatched, and  standing waves are generated resulting in a loss of power. The frequency is a forced response and remains constant. Power is lost and efficiency becomes less and  less, depending on the degree of mismatch. Let’s assume the Jensen amplifying transformer is in a resonating condition.
Floyd Sweet TELLS US: "Let’s assume the Jensen amplifying transformer is in a resonating condition"
I think it is very important to start thinking beyond the veil of "simple experiments" now, and to start thinking of Useful Experiments.
Yes, when you see this website, it is running from Off Grid Power, and yes we are down sometimes, we do have issues from time to time. We are 100% off Grid, the only thing we rely on is the local Council taking our Rubbish, and that's intermittent at best also. So, for useful experiments, we need our Partnered Output Coils to actually do useful work, to Pump useful Current and for useful Current we must have a substantial Voltage, we done need to go crazy, maybe 24 Volts, or 48 Volts, to power an Inverter, to power the Fridge or a Pump or something.
I hope others join in, it would be nice to see, and this could bring the community together in many ways.
GuruNandan posted this 03 August 2026
I really appreciate this initiative. This will definitely help people like us to learn more, who are currently struggling with the replication.
Looking forward to see what people come up with
Thanks!
  • Drasko
Chris posted this 19 August 2026
Hey Everyone,
No one wants to enter this Project and submit any work?
If people are still a little stuck, I will release a new set of videos to help others along. I honestly thought more would be experimenting with the: "Chris's Non-Inductive Coil Experiment", especially the Seventh Video:
Honestly, this video gave a huge step forward, and should have changed the direction of all serious researchers in the field.
I had hoped more people realised the importance, what we have shared, it proves Symmetrical Electromagnetic Induction is only the start, some 200 odd years to learn Symmetrical Electromagnetic Induction, and I share Asymmetrical Electromagnetic Induction, and no one takes it seriously, what a shame!
At Time t, the Magnetic Fields have three Directions: MMFPrimary + MMFSecondary + MMFTertiary = MMFPrimary which has never been shown Publicly before, especially in such a simple, provable, repeatable Experiment, this should have changed the entire Playing Field for Science! In this video, I have shown you, what I have tried to tell you l for years.
Anyway, rant over, I will release some more videos soon, showing you the Asymmetrical Coupling Results, and how the Coupling of Coils creates an Imbalance in the Systems Symmetry automatically.
