Hey Galaxyman,
Hello and Welcome!
I have a guide here: Builders Guide to Aboveunity Machines
I definitely don't recomend putting the output pins on your raspberry pi under this sort of inductive load.
The easiest way to think of Partnered Output Coils is the same way as an Electric Generator works, but Static, Stationary, using the Increasing and Decaying Magnetic as the source. Like the Electric Transformer, but instead, we don't input the Driving Force, we only provide a tickle under the chin and the Partnered Output Coils do all the work. Thays why Magnetic Resonance in important, each Magnetic Field must be equal in Magnitude but Opposite in direction.
We have many independent replications, just follow the AboveUnity Tag. Read through a few of these threads and all your questuons will be answered, but then there will be many more.
Its ok to have questions, and over time, I have learned that Bench is the easiest way to get answers.
A Voltage is Generated and a Current is Pumped, from Source, the Atom and the outer orbitals, charge, is accelerated down the wire according to the Right Hand Grip Rule.
What's described here is Asymmetrical Electromagnetic Induction! Currently, main stream science only accepts Symmetrical Electromagnetic Induction, which is flawed, because the Output always is equal to the Input minus Losses! Always a below Unity System!
We don't so it this way, you can learn more here: Chris's Non-Inductive Coil Experiment
Many of my videos on this subject explain how to do it and what to look for!
All videos prior, show how to get to this point! All of it has a purpose, and it depends on how far the Viewer is along the path. This experiment proves with no doubt that Asymmetrical Electromagnetic is real and works on the bench! Its a Fundamental Experiment!
After this, the goal is to get POCOne and POCTwo equal in Magnitude and Opposite in Direction which we have covered in many placed also. We have just shown two input coils HERE to do this.
Once you have a basic understanding, this is very easy, initially, it may seem a little difficult! Look at the big picture, try not to focus in too small, the easiest thing on the planet, but everyone has been trained out of seeing it, trained Symmetry is curtail/critical, when its NOT how Nature Works!
