Hi team,
I just joined this forum to share with you all. I have been studying Akula's work since around 2016. I had to give it a break because all my time was being consumed by it. However, I noticed that there are a few persons still keeping the fire burning for freedom and I am glad to join the party.
The diagram above comes from Tesla's patent No. 685957 dealing largely with capturing energy from the aether.
If you notice the device itself it should be clear that the main component is the CAPACITOR. It is responsible for the capturing and storage of the charge received from the "air".
I now understand the reason for tesla's bifilar (largely misunderstood) coil. Tesla's bifilar coil was (from my own assessment) intended to form part of a capacitor plate. It is necessary therefore that the coil be arranged in the "bucking"/partnered arrangement and set to resonate (magnetic resonance). at resonance such a coil becomes a receptor of protons (positive charges) from any source that radiates it.
Examine this from: http://awakeningtimes.com/nikola-tesla-free-energy-unraveling-the-greatest-secret/
In order to utilize this high-voltage energy you must do two things — make an energy sink and then devise a way of making the “sink” oscillate.
“Zero Point Energy?”
Such a “sink” has to be at a lower energy state than the surrounding medium and, for the energy to continually flow into it, the energy must be continually pumped out of it. Additionally, this “sink” must maintain a lower energy state while meeting the power requirements of the load attached to it. Electrical energy, watt-seconds, is a product of volts x amps x seconds. Because the period of oscillation does not change, either voltage or current has to be the variable in this system’s energy equation. Bifilar wound coils are used in the system because a bifilar wound coil maximizes the voltage difference between its turns, the current is then minimized.
A coil in our system, then, will be set into oscillation at its resonant frequency by an external power source. During the “zero-point” portion of its cycle the coil will appear as one plate of a capacitor. As the voltage across the coil increases, the amount of charge it can siphon will increase. The energy that is taken into the coil through the small energy window (zero-point), call it what you will, appears to be the key to the success of this system. It is at this zero-point where energy is condensed into positive and negative components of current. When energy escapes from the “sink” the magnetic field collapses and a strong magnetic quake is created in its wake. A properly tuned system can capture and convert radiant energy in such a prescribed arrangement.
The following is exactly what Akula did with a few misleading notations:
The green coil (partnered/bucking) is one plate of the capacitor which acts as the receptor for the radiant energy being emitted from the antenna of the kacher/tesla coil . The red coil is the other plate of the capacitor which must be connected to the ground as Tesla describes. Once resonance is maintained, there is a constant flow of energy into the system.....
That was a mouthful for an entry......
I have been scrutinizing quite a few of his schematics and this is the common thread that i have observed. Please examine and give feedback.
