The Physics of Un-Generating a Voltage
  • 929 Views
  • Last Post 07 June 2026
Chris posted this 04 May 2026
We have covered Voltage in Many Places!
Voltage as a Scalar Value is equivalent to 6.241509 x 1018 Electrons, as is the Coulomb, and One Ampere is this same number, moving past point P1 in one second.
We have covered previously, that the Differential Mode Choke filters out Voltage Transients by, what I call Un-Generating Voltage, in Electrical Engineering, this is just called 'a filter'🙄
I am sure most of you have done the experiment, and it is well known, Bucking Coils don't allow you to Generate any Voltage, which is well known in the Auto Transformer Step Down configuration.
The Auto Transformer
In an autotransformer, "windings that are wound and connected non-inductively" typically refers to special arrangements (often bifilar or opposing windings) where the magnetic fields from current-carrying sections largely cancel each other out. This minimizes net inductance for certain currents or paths, preventing unwanted voltage drops, inductive effects, or interference while still allowing the transformer to function. The phrase "this ungenerates voltage" likely means that these sections produce no net induced voltage (or minimal self-induced EMF) due to the cancellation, unlike standard inductive windings.
This image depicts a step-up autotransformer configured for boost (adding) voltage.
This image depicts a step-down autotransformer configured for bucking (subtracting) voltage.
Why This Is a Step-Down Configuration
Subtractive Polarity: Unlike your first example where the secondary added to the primary, this circuit is wired so the secondary voltage (\(V_s\)) opposes the primary voltage (\(V_p\)). You can see this in the Secondary Phasor Diagram, where the red dot (\(V_s\)) is on the opposite side of the axis relative to the input.
With a 5:1 ratio, the 120V input (\(V_p\)) creates a 24V secondary (\(V_s\)). Because it is bucking the main voltage, the total output is:
\[ V_{out} = V_p - V_s = 120\,\text{V} - 24\,\text{V} = 96\,\text{V} \]
Result: Since \(96\,\text{V}\) is less than the input \(120\,\text{V}\), it is functionally a step-down (buck) operation.
How an Autotransformer Works
An autotransformer is a special type of electrical transformer that uses a single continuous winding acting as both primary and secondary. A portion of the winding is common to both input and output circuits, unlike conventional transformers that have electrically isolated separate windings.
Basic Operating Principle
The voltage transformation depends on the turns ratio. If the total turns from one end to the other is \(N\) and the common/tap section has \(N_1\) turns, the relationship is:
\[ \frac{V_{out}}{V_{in}} = \frac{N_{out}}{N_{in}} \]
Bucking (Step-Down) Mode Explained
In the buck configuration:
  • The secondary portion of the winding is connected in series opposition (subtractive polarity) to the supply voltage.
  • The voltage induced in the secondary section (\(V_s\)) opposes the input voltage (\(V_p\)).
  • Only the difference between the two voltages appears across the load.
For the 5:1 ratio example:
\[ V_s = \frac{1}{5} \times 120\,\text{V} = 24\,\text{V} \] \[ V_{out} = V_p - V_s = 120\,\text{V} - 24\,\text{V} = 96\,\text{V} \]
Key Advantages
• More efficient power transfer because part of the power flows conductively through the common winding.
• Smaller size and lower cost compared to a conventional two-winding transformer of similar rating.
• Ideal for small voltage adjustments (buck or boost).
This autotransformer setup efficiently reduces the voltage from 120 V to 96 V using the bucking configuration shown in the image.
Key Advantages of Autotransformers
• Only a small portion of the power is transferred inductively (transformer action).
• The rest is transferred conductively through the common winding.
• Higher efficiency and smaller physical size compared to conventional transformers of the same rating.
This explains why the circuit produces a stepped-down output of 96 V from a 120 V supply in a bucking autotransformer setup.
Conclusion
We have an Applied Voltage of 120 Volts, but the Step Down Voltage is 96 Volts. So the Quantity of Electrons is Reduced, Choked off simply by using Bucking Coils. This is what I call Un-Generating a Voltage, again, the Differential Mode Choke works the same way.
Un-Generating Voltage literally means that the 6.241509 x 1018 Electrons x 120 has reduced to 6.241509 x 1018 Electrons x 96. We have Un-Generated 24 Volts, or to 6.241509 x 1018 Electrons x 24 Volts.
Now, if we have a Reduction using one Configuration, how do we get an increase using another configuration?
Chris posted this 05 May 2026
I want to cover an Experiment I did a long time ago, that I shared:
Hi All,
Re the NMR Ideas, Maybe. There may be a Quantum component to this but not sure I would say NMR even though I did investigate this. I personally think its 99% Magnetic in Nature, which is directly related to the Quantum in my opinion.
I Posted my first post here: http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg398250/#msg398250 Here I have shown the Coils as I have them working. There are a few Characteristics that once you see them you will know you have something very special. I detail some of the Characteristics in the above post.
In my opinion, the best way to describe this 'MAGICAL' effect is in the paper by Paul Raymond Jensen: http://www.hyiq.org/Research/Details?Name=A%20Free-Energy%20Device is where I have published the copied paper.
The quote: "An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields." is in my opinion the best description of what is going on from what I have seen.
If you take 1 hour out of your day and replicate what I have shown then you will likely also find the Paul Raymond Jensen paper just as important as I have.
See here: http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg398250/#msg398250
All the best
Ref: Akula0083 30 Watt Self Running Generator.
The thing is, very few to none paid any attention to this Experiment.
This Experiment is the very foundation of what we needed to learn and understand, back in the day. My Opinion is, if you dont understand this, you simply cant understand the next part thats comming!
Chris posted this 15 May 2026
I have tried to point out for a very long time, that Magnetic Resonance is the Key to Aboveunity Machines:
And a different version I did for Vidura, which I had to Ban when the romanian thing went down
I think it is important to note, these coils should be resonant at 100's of KHz and NOT at a few hundred Hz! This is a VERY Important Fact! Remember Floyd Sweets Sponge:
The Noise in the video, its very obvious and the Sponge would have dampened this noise.
I was hoping everyone would take not to the similarity and the working operation to Tinman's RT
I did some experiments on the RT and did verify a lot of info:
Chris posted this 20 May 2026
If you study and then ponder this page for a few minutes, you will realize, it contains the answer you need to build your own Free Energy Machine! It is very easy and very cheap!
A very simple Coil Arrangement can produce many Kilowatt's or more, of output for very little, to no, input! Please use what I have given you! It works!
-ra- posted this 07 June 2026
General physics says there are some cases where pent up energy becomes available, which normally is impossible ; it's called catalyst, in chemistry. Impossible phenomena do happen, like tunnel effects (electron or photon re-positioning). In mechanics there is a plague to obtain (large) movements, it's called friction, the anti-movement force, an energy eater. But there is a way to remove friction and mass inertia, it's called resonance. Imagine throwing away an object, when the object has virtually no mass at all? If your arm had no mass either? This is what happens under strong resonance, at a precise frequency.
Friction all along the oscillating sine wave damps and 'kills' the resonance. But Moray (i believe) says it's possible to help yourself only at the tip(s) of the wave, and keep the oscillation.
- I just repeat Tesla's words.
  • strape
