Tibetan singing joule thief update part deux
  • 678 Views
  • Last Post 05 February 2023
MichaelJamesSmathers posted this 26 November 2022
Please pardon the low quality camera, LOL. (its from 8 years ago) It was among the first of my tinkering and dabbling of "bucking coils" made by basically winding magnet wire around a steel bowl form glued onto a "lazy susan" rotating food tray.- I thought it was pretty rough too but i had to try to make a similar replication of the YT'er: zerofossilfuels channel where he demonstrated increased inductive magnetic coupling on the bowl shaped winding he had made..(his does look better) But my train of thought was.. if the bowl shape can induce increased induction..maybe also it can increase voltage/saturation..? Currently, i am trying to replicate this hybrid joule thief circuit (once again) with my increased maturity and understanding of electrical phenomena.
I have a 446A Mini-Ubiquitous full spectrum analyzer and i intend to show screenshots of the resonant coils when i have confidence that i have re-created my experiment shown in this video from that time.
here again is the video link:
MichaelJamesSmathers posted this 05 February 2023
In an attempt to keep my profile from getting deleted,.. tonight, I am attempting to show my due diligence and limited progress in showing what i have done with the time I have had. I hope this can serve as an honest effort in showing that i am not "sitting idle" and doing nothing, but this is not a replication by anyones standard, I fully understand that. Please be patient I have a LOT of 'juggling' of my time just to pay the bills. Here is a description of what is shown in the picture:
~4 inch toroid Silicon Laminated steel inductor cut with a ~1.5 mm gap (non-grain oriented/oriented- is "unknown")
(Protoboard has some components that were left on it from a previous experiment and not part of the oscillating circuit.  ) The ONLY ACTIVE component(s) making the LED's light up are the 2N3055G NPN with a black heat sink radiator and the 10k Ohm potentiometer used as a "Joule-Thief" which is activated by a LONGWEI Brand 30/10A adjustable DC power supply which reads 00.6 volts  with 0.00 amperes (probably to low to register a value on that power supply.
The bifilar coil is twisted and hot-glued as 24AWG magnet wire with 30 wraps unto a sliding adjustable foil covered plastic which facilitates later 'tuning' the inductor for reactance in distance to the inductor gap. (I intend on wrapping a paralleled bifilar coil over it later -as time permits)
the other wire shown is a white 18 AWG single conductor wire with 12 wraps (on top of the inductor)
on the right-side of the inductor are a coil of 9 wraps of 20 AWG magnet wire (left open -"i.e. not shorted")
another "fixed" coil of 20 AWG magnet wire with 12 wraps (left open-"i.e. not shorted")
lastly a fixed coil of 24 AWG  magnet wire with 3 wraps.
The load shown is 24 white LED's in series
Check out my images here; https://postimg.cc/mhmQCHDD  and https://postimg.cc/9D7T6gBR
Chris posted this 05 February 2023
Hello MichaelJamesSmathers,
I do not appreciate your Spiteful Comment!
You have been warned on several occasions for posting Spam! Off Topic content, nothing to do with this Forum and its Topics!
Yes, that will get you Banned if you continue that behaviour!
Stay on Topic and keep your posts Respectful and of a reasonable standard, then you will be fine. I will Ban you if you keep posting your Spiteful Comments!
Perhaps a little more effort to abide by this Forums Topic and Rules and a little less of the other stuff?
