Hi All, not sure this is the spot for this post so please let me know. I'm looking to source the necesary equipment to start my replications and experiments at looking at scope options. I see the Rigol DS1104Z in a few videos which is great, just wondering given I'm new to this space if there is a more suitable option? Also what specs are a must have. Thanks in advance
Tinker's Scope Research
- 544 Views
- Last Post 12 January 2024
Hey Tinker, I guess the post was moved ![]()
My two cents here. I have a Siglent SDS 1104X-E. I'd put it on par with the Regol, pretty nice. Probably the same price range as the one you mentioned. Though the Regol, from what I can tell, seems less cluttered on the screen when showing measurements. Other than that, the only other advice I'd give is you can get away with 2 channels, but 4 is nicer if you can swing it. Also, my scope has 100 MHz bandwidth, which is also nice if you can swing it. But looking back now it's overkill, as most of these experiments are in the low KHz, some extending to mid range KHz I guess. So a 50 MHz would probably be just fine. And although probably standard in scopes these days, the basic math functions are very useful. For example, CH1(V) * CH2(A) will give you a instantaneous power measurement plotted on the screen. Then you can grab your mean or rms values from that.
I messed up and got a 2 channel first and found out quick that the others are needed. I would even spring for a 6 if they made it. You just have to be careful not to exceed the limits of input and what I call the phantom grounds that can bite you. I have both 2 and 4 and have used both concurrent .
Hello Tinker,
We believe, it should be your decision, when you decide to spend that sort of money on equipment. We all have made our own educated decisions on our own equipment, and of course, it cant be our decision, it must be yours.
We try not to advise anyone either way when it comes to spending this sort of money.
Please understand, it is up to you to do your own research here. We have stated this in many places here on this forum already!
Thanks Chris, sound advice. I'm less concerned on a brand at this stage and more on what things are must haves. For example 50Mhz or 100Mhz, number of Channels etc... To be honest part of me thinks the cheapest option that meets MVP is best just in case I cook the thing, not that I'm planning to but just in case. Thanks again.
T
FringeIdeas
20
