Title: Miska’s Non-inductuive coils experiments (Aboveunity)
  • 331 Views
  • Last Post 02 October 2026
Miska posted this 01 October 2026
Dear Friends,
I am a curious-minded hobbyist from Tokyo. I happened to find this site and conducted experiments with non-inductive coils based on the instructions provided here. They produced some positive results that I think are worth sharing with you.
I have found the Aboveunity site a few year ago. I have been studying Electromagnetism and Electric and Electronic Circuits ever since and finally enabled myself to build this machine, and conducted related experiments. Unfortunately, though I have found myself having some issue which prevents me from further experiments. I have but to give up everything including my machine , measurement tools and etc for that reason. So, I have decided to do things that I could do to support your activities. Besides this report, I have some theoretical ideas that I am planning to up-load in the future post.
1. Circuit schematic and its graphical explanation
   The schematic I used is almost identical to the one introduced in the builder's guide.
Schematic
graphic circuit
2. Settings and Specifications
CORE: AMC320, 4 blocks (CSR doubled with cores paired in parallel)
COPPER WIRE DIAMETER: 1.2 mm
INPUT COIL: Length 7 mm, 44 turns
OUTPUT COIL: Length 24 mm, 175 turns × 2
INPUT FREQUENCY: 33 kHz
DUTY: 25%
3. Results of the First Experiment
(1) The effect was verified:
When both VR1 and VR2 were set to zero resistance, sawtooth waveforms were observed,  and the Lenz’s variant effect was verified.(the COP was below 1.0)
Results: I/P: 19 mA × 10 V; O/P: 17.5 mA × 8 V + back EMF.
The other coil’s O/P is negligible
oscilo toothwave shapes
(2) A gain above unity is achieved with the resistances of VR1 and VR2 each set to 1 kΩ. The waveforms were distorted simultaneously.
Frequency: 33KHz Duty: 20%
Result: I/P: 25 mA × 12 V; O/P: 20 mA × 9 V + 14 mA × 5 V + 4.6 mA × 12 V (back EMF). COP is slightly above unity.
deformed wave shape currents
(3) Some funny results
In the first place, I started this experiment with a single pair of AMC320 cores. The results were actually better with a single CSR and more turns in the O/P coils than with a double pair and fewer turns. I am not very confident in this setup because of the strange waveform of the O/P voltage, as shown in the photo below. The problem disappeared after I fixed the self-made signal generator. However, I decided to retain this result as one piece of evidence because the combination of the O/P current and VR1 resistance approximately follows Ohm's law, supporting the otherwise controversial measurement of the current value. My idea is that as far as COP is below 2.0, O/P should follow ordinarily Ohm’s law.
CORE: AMC320, single pair
WIRE DIAMETER: 1.0 mm
INPUT COIL: length 20 mm, 90 turns
OUTPUT COIL: length 50 mm, 350 turns × 2
I/P FREQUENCY: 17.7 kHz, DUTY: 25%Result
With VR1 830_Ohm and VR2 zero, COP is around 1.7 .
Result: I/P: 21 mA × 9.8 V; O/P: 20 mA × 16.7 V + back EMF
The other coil's O/P is negligible.
Strange double bumps of O/P voltage were caused by settings of my DIY signal-generator module with a variable resistance to control I/P voltage.
a) A photp below is I/P current, strange double bumps can be seen which is fixed later:
IP wave shape current
b) Wave shape of O/P current for the above I/P:
O/P wave shape current
c) Wave shapes of voltages :
wave shape of voltages
MY MACHINE:
my machine
Self made PWM module(IC:TC74HC14AP )
pmw module
Chris posted this 02 October 2026
Hey Miska, Thanks for sharing!
If you find yourself in a situation where you can start experiments again, I and other members here, are happy to help you through. Switching is pretty good by the looks, no major issues. Anyway, let us know when you're ready.
Again, thanks for sharing!
Miska posted this 02 October 2026
Hey Chris, Thanks a lot for your kind message!
Yes, I will let you all know when I am ready again.
I hope a miracle comes my way.
Besides experiments, I have some topics that I think are worth sharing with this community, such as  achievements by Japanese inventors in this field. I am also a patriot like you (chuckles), or some findings that I have made while reading Floyd Sweet's document or etc.
Anyway, I feel very glad that I have finally been able to contribute to your site, which seems very significant and almost monumental to me. I am a zine writer, too, and I have written an article introducing your activities that will be published later this year. The zine's circulation is not very large, but its readers are good folks who I think will be interested in activities like this.
Well, I will keep in touch. Ciao!
