Why the Conventional Transformer is NOT Aboveunity!
  • 1.2K Views
  • Last Post 04 April 2023
Chris posted this 18 March 2023
This thread can allow you to power your House, if you understand this thread correctly!
We have covered in the Thread: How a Transformer really works! the basic workings of a Transformer. Its pretty basic, its Electromagnetic Induction 101. However, the method of Electromagnetic Induction is what so many do not understand.
In this thread, a Sister Thread, we will look at the Reason: Why the Conventional Transformer is NOT Aboveunity!
Some say:
Lenz's Law is the reason we cant get Above Unity Machines.
but that's not technically correct.
To put it simply, its about Force and Inductance. Force is the Magnetomotive Force, Ampere Turns ( AT ) which is equal to the Current ( I )  through Turns ( N ), known as NI.
Magnetomotive force (mmf), Fm = NI ampere-turns (At), where N = number of conductors (or turns) and I = current in amperes.
Ref: Science Direct
What occurs in the Transformer, is as one Loads the Transformer's Secondary Coil, more and more, the Inductance of the Primary Coil and Secondary Coil is Reduced and the Current in both Coils goes Up as a Result! There is no Rocket Science here and everyone knows that Inductance ( L ), by definition, is the Coils ability to carry a Current ( I ). We covered this in the Thread: Non-Linear Inductance
Inductance ( L ) is the Rate at which Amperes can flow through the Coil in Time, this is defined as:
L = di / dt
One Henry is where One Ampere transitions the Coil in One Second. With Back E.M.F:
L = ε / di / dt
Where ε is the Back E.M.F, restricting the Current Flow, created by the change in Current  that produced the E.M.F.
Thus, as the Coils Inductance changes, the Coils Current also Changes!
One Must Note:
A Conventional Transformer is Completely Symmetrical! Your Input = Your Output - Your Losses, thus 85 - 99% Efficiency is the practical limit and no more than this can ever be achieved! There is a Symmetry between your Input and Output Coil! Magnetically Opposite, MMF is Opposite and the EMF is opposite, Equal and Opposite!
Why?
Newtons Third Law:
The third law states that for every action (force) in nature there is an equal and opposite reaction. In other words, if object A exerts a force on object B, then object B also exerts an equal force on object A. Notice that the forces are exerted on different objects. The third law can be used to explain the generation of lift by a wing and the production of thrust by a jet engine.
Ref: Nasa
However, this is not true, if one considers a Non-Symmetry!
NOTE: Newtons Third Law is Incomplete, it is not entirely Correct! There is a lot of people that believe Newton's Third Law was changed, or hidden, from the General Sciences today!
Why?
Because it does not cover Systems that are Not Symmetrical!
Newtons Third Law should read:
For every Action (force) in Nature there is an Equal and Opposite Reaction, and for every Reaction there is an Equal and Opposite Counter-Reaction. This Counter-Reaction must always assist the Action (force)
I have been stating this for many years! This completed Third Law, then must Break Symmetry!
Broken Symmetry
The term Broken Symmetry, or Asymmetry, the term I prefer, is by Definition, NOT Symmetrical:
lack of equality or equivalence between parts or aspects of something; lack of symmetry.
Ref: Oxford Languages
So, what is Symmetrical, and what is Asymmetrical? Lets look at a basic example:
So, we see a Vertical Line, dividing a Shape into two halves, in one image, the two halves are Symmetrical, in the other Image, the two halves are Asymmetrical, they are not Symmetrical! This occurs a lot more in Nature than any Conventional Scientist would like to admit! Way more!
There is a known set of terms today, Left Handed and Right Handed, these terms describe different Scientific Concepts. I have covered this in the Thread: Why They Fail!
Today I want to talk about why they Fail! They FAIL because they focus on Symmetry, brain washed into thinking that's the ONLY Way!
It is not, and its NOT how Nature Works!
Chiral asymmetry appears in nature at all levels, form elementary particles to morphology of mammals, and possibly even at the level of galaxies. ... The process of spontaneous chiral symmetry breaking and the high degree of sensitivity has to small chiral asymmetries are at the core of the observed asymmetry.
or:
the asymmetry of life — the fact that most biochemical molecules are ‘left-handed’ or ‘right-handed’ — could have been caused by electrons from nuclear decay in the early days of evolution.
Key Words:
  • left-handed
  • right-handed
Conventional Electromagnetic Induction, entirely lacks Asymmetry! Coincidence? No!
No known Scientist has ever explored Asymmetrical Electromagnetic Induction, in fact you'd be hard pressed to even find a website as of today, that even uses this term! That is except for My Website! Asymmetrical Electromagnetic Induction is NOT Symmetrical Electromagnetic Induction! Its Electromagnetic Induction that uses the basic theory in a manner that does not apply a Singular Input Coil and a Singular Output Coil, which must always have Symmetry between them: Equal and Opposite Minus Losses! Here is the Visualisation:
You can see, the Magnetic Field Lines never Cross, or Touch each other. Symmetrical Electromagnetic Induction! Equal and Opposite Minus Losses!
I have given you an 11 Video Series on how to understand and achieve Asymmetrical Electromagnetic Induction:
I introduce Asymmetrical Electromagnetic Induction at around the 30 minute mark.
Asymmetrical Electromagnetic Induction allows for an Input Coil Assist!
Its a Three Coil Arrangement:
Where the Polarities of the Coils are configured in such a way, as we have a Broken Symmetry, and one Coil, normally considered POCTwo, assists your Input Coil, thus the Input Coils Inductance is not changed, like a Symmetrical Transformer, so much and can stay the same, or even go up as a result and less Current is drawn.
We have Electromagnetic Induction occurring Twice in the One System! Not Once!
Every single Coil carrying a Current MUST have an associated Magnetic Field, and this MUST Follow Newtons Completed Third Law!
We have what I call Partnered Output Coils, and each Partnered Output Coil must Oppose each other, or Buck each other! We have an Input Coil ( Green ) and two Partnered Output Coils or POCs: POCOne and POCTwo in ( Gold ) Green and Gold, Australia's Colours!
We have many Proof of Concepts:
Tinman was the first:
Thing is, many people don't like the fact that we have Succeeded where they have Failed for many years! Some for many Decades!
So, to answer the question: Why the Conventional Transformer is NOT Aboveunity!
Very simply, because no one has ever bothered to add Asymmetrical Electromagnetic Induction into the Scientific Textbooks! Maybe they have just been to lazy, or too Ignorant to the Simplicity of such a Discovery?
The Basic Analogy: We have an overall gain in the process of Electromagnetic Induction, because we are not paying for the Broken Symmetry of Asymmetrical Electromagnetic Induction! We have a Gain in Electromagnetic Induction, normally called Parasitic Inductance, over our Input! We use All Magnetic Fields Changing in Time, to "Generate" Electrical Energy!
Now you have the Answer, its the Answer many have searched for, for so long, but never been able to reach, ignorance, arrogance and just not enough proper, Intelligent investigation, has held them back!
This is the Answer that Haunted Science! We have had it here for Decades and too many people choose to stay Ignorant to this very Simple, very Cheap, life altering, technology!
donovan posted this 19 March 2023
I need to read this again!
But a comment......I think the hardest thing we all need to get our head around.....is, everything in our world, is designed to be under unity......so, unless we have a very strong will, it is hard to move past that......and believe, in above unity.
Donovan
Chris posted this 19 March 2023
Hello Donovan,
Your Comment:
We do have Systems that Require Zero Input by Us ( COP= ) to Function:
No Input by Us, and it Runs. Its Pressure is what keeps it going, much the same as the Magnetic Pressure that we have in our Machines.
Chris posted this 21 March 2023
After the rush of Questions: "How does the Magnetic Field change the Inductance?", I thought I had better elaborate some more.
Answer: Its two Opposing Magnetic Fields, and its the Compression, the equal and opposite M.M.F of each Magnetic Field, under a High Tension, restricting the Change in the others Magnetic Field. Each Coil looses its Self Inductance, remembering it is the Change in Current I that Creates the Self Inductance, that gives rise to Inductance: One Henry is where One Ampere transitions the Coil in One Second. Inductance defines the Flow of Current Through a Coil!
L = di / dt
L = ε / di / dt
Where Epsilon ( ε ) is the Back E.M.F, the Self Inductance, restricting the Flow of Current: di / dt.
Inductance is a Function of the B H Curve. As a Conventional Transformer moves through the B H Curve, the Coils, plural, loose or Gain, in Inductance, depending on where in the Curve you are.
If you don't believe me? Then here is an example:
Ref: Figure 6 - B-H curves and inductances with various frequencies
Figure 6 illustrates the results of the non-linear magnetic properties and differential inductances of the ring frame with various frequencies, where the values of the horizontal axis are the logarithm (base two) of the exciting current. The inductances were calculated by:
L ( i ) = dΨ / di = NS dB / di
Ref: B-H curves and inductances with various frequencies
Truth of the matter is, a lot of very naïve Electrical Engineers have never bothered to check such important things, but it is the flurry of Common-Sense that strikes people now, that make them see that a Coil in a Saturated Core has no Self Inductance, the rest of the equation follows the Common-Sense of the problem at hand! There you have it, another Reference to prove I speak the Truth!
Note: Saturation is NOT Required to observe this artefact!
Saturation, from my experience, never occurs in Asymmetrical Electromagnetic Systems! There is NO BH Curve! To date, I have never been able to prove, or dis-prove any Saturation!
Science seems to be so far behind on Asymmetrical Electromagnetic Induction! The other forums, well, they are not even close to cutting edge!!!
We now see why Epsilon ( ε ) is the Back E.M.F, the Self Inductance, moves to pretty much zero. Here is an image showing you the Self Inductance:
Think of it this way, if POCOne was the Red Current, and POCTwo was the Green Current, there is no Resistance for Current to Flow, because everything is Counted and accounted for!
You will note, in the Thread: Reduced Impedance Effect, we see a VERY Simple experiment that can show you the basic effect, which shows that, Epsilon ( ε ), the Back E.M.F, the Self Inductance, moves to pretty much zero, leaving just the DC Resistance.
Enjoy knowing what 99.995% of Electrical Engineers don't know even today!
Attached below: "Predicting Iron Losses in Laminated Steel with Given Non-Sinusoidal Waveforms of Flux Density", I hope you find this data useful!
Chris posted this 28 March 2023
MOST of the Community Guru's we have seen, have no idea whatsoever on most of this stuff, and thus the reason they have never been able to grasp this very simple technology!
There is only one way to move forward, is small experiments to verify these facts.
It is true, only those that gain an understanding in Electromagnetic Induction and Antenna Theory can move forward, those with poor to no understanding, they will always fail!
Sadly, its the choice to stay ignorant, that holds us back! So many choose to stay Ignorant!
baerndorfer posted this 02 April 2023
two years ago i build a small transformer just for fun. i use 2 e-cores with no gap between and put a primary coil on the middle leg. this coil is in series with a capacitor. so i use a serial tank to drive a magnetic field through the core. as everyone should know this creation uses mainly reactive power.
on the 2 legs i put 2 opposing coils and the output from both is rectified and the energy goes directly into energy storage system.
i put the whole transformer in oil to get a good cooling situation and thats it!
25W of input (real power) is transformed into 58W on secondary.
the key to get this working is the opposing coil connection. you have to connect the legs from 2 opposing coils in a very special way to get this result. it took me 4 days to achieve this, so it is no rocket-science!
i work in this field for a long time and what i see is, that most technicians are lost in their computers and simulators. they have no clue what works in reality. most of them have no knowledge whatsoever but a master degree instead.
everybody with an open mind and a good will can understand this. we have to focus on what happens right in front of our eyes.
and as everyone can see - a ordinary transformer is build to act against its creator (source dipole).
have a nice day!
B
Chris posted this 04 April 2023
Hey Baerndorfer,
Very wise words My Friend!
We would see many more successful replications, if more would think like you. Simplicity, and observation!
For every Watt of Input power, we can achieve 2 Watts of Output Power, or very much more, if we offset the Forces exerted in the Transformer, and its is very simple! Thinking Asymmetry is exactly how its done! The Input Dipole, as you say, is not what we need to Fight against! We can be smarter than this, but so many choose not to be!
I wish more would do the very simple, very cheap experiments, and stop being so lazy!
I have seen some of Baerndorfer's work and I can confirm the output Baerndorfer speaks of! Its very easy and very cheap! Knowledge is useless unless it is applied! So many morons to lazy to apply it, otherwise we would see a lot more!
This thread and many others like this thread explain how to build Aboveunity machines, but only here on this forum! We are Light Years Ahead!
